#85 | ||
- Andy |
#86 | |
Drives: MT WRB BRZ Limited, 2007 911s
I think your biggest issue would probably be ride-height if you're lowering the car. It's not an answer to your question exactly, but my plan is to go Bilstein B8/RCE Tarmac/HVT camber plates in the summer and then just buy an extra set of rear OEM shock mounts and run the stock setup during the winter. Not much work to swap the whole assemblies over and I'll be able to avoid getting all the salt on the better setup, while giving me maximum ride height. |
#87 | |
i'm sorry, what?
Drives: Canada
well, not to piss in your cheerios but I see a lot of that type of talk this last weekend we had a guy show up to autocross in a 92 Chevy Lumina (or whatever the fuck) on barely legal tires of the same year... and he had a ton of fun if you're gonna do it, do it because for every 1 person I know that autocrosses or tracks their car in whatever form its in, there are dozens of people with modded cars who continuously decide to "sit this one out" so you can be riding on your 265's like a baller.. but a hardparker's gonna harpark... so you gotta be real with yourself
#88 | |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
#89 |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
#90 |
#91 | |
Drives: FRS
I learned the same lesson from building off road vehicles, raising the suspension caused all kinds of gremlins and needed fixes for reliability that caused other problems. A cat always chasing its tail. I have lightweight 18 X 7.5 wheels, r-comp tires. The rears poke 5 mm more than the front. I tuned the handling with sway bars and the car is neutral through the corners on the track. Does being staggered by 5mm require a work around ? What would the work around be ? ![]() ![]() CERBERUS |
#92 |
Car Nut
#93 | |
All depends on how much snow you get where you live. It certainly won't be an issue most of the time but for me it's worth the hour or so twice a year to just swap. As long as you're running good snow tires and don't have crazy camber, you should be fine for most of it. |
#94 | |
( ͡° ͜ʖ ͡°)
#95 | |
Changing where the center of the contact patch is will change the roll center (might be slight, but it'll still change it), it can also increase the gap between the "Dave" point.
#96 |
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Yes, I know and I see what you're sayin. The entire picture combines more than just that...it combines that new contact patch wheel center with the addition of slamming the car. Yes, only slight...Those neg effects shown are not merely just from the new contact patch...but mainly and mostly from the lowering. So yes..only looks slight.. like 5-10% of the pic's neg effects and change in roll center is due to that contact patch you're talking about.
. Last edited by fooddude; 06-05-2014 at 03:23 PM. |
#97 | |
Drives: "14 BRZ Limited - SWP
#98 |
Drives: 2013 Subaru BRZ
Great post!
Hopefully I have not screwed up my cars handling, does not feel that way at least. 17x9 rpf1 with 245 PSS tires. KW v3 coilovers with minimum drop according to the Tuv papers. (Less then 1") Only thing missing is a new aligment with more camber up front. Had a aligment to stock specs done after the coilovers were installed to get the coilovers written in to the cars papers. (EU rules) |
| BRZ Limited Backup Camera Step by Step (WARNING long post, many pictures) | runny_yolk | Electronics | Audio | NAV | Infotainment | 120 | 01-29-2021 06:18 PM |
| step 1 :buy frs in phx, step 2: drive to pikes peak | haymaker | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 15 | 08-21-2012 10:44 AM |
| [StreetFX] License Plate LED light upgrade, and DIY step by step guide (GT and GTS) | WTF | Australia Classifieds | 0 | 07-11-2012 11:38 AM |
| [StreetFX] BRIGHT Boot/Trunk LED light upgrade & DIY step by step guide (GT and GTS) | WTF | Australia Classifieds | 0 | 07-11-2012 11:27 AM |
