Old 06-04-2014, 07:21 AM   #113
Malt
Drives: 2015 WRX
Originally Posted by plucas View Post
I will be having an analysis coming out soon on this splitter paired with the V1 diffuser from Driveway Labs. Hopefully soon after that, I can have one also with the V2 diffuser. This should help people have an idea about how their aero will effect the characteristics of the car.
I think I saw you mention that you were going to be including data for those that are lowered as well. Any chance this information will be included in your analysis that you will be releasing as being lowered increases the effect from both the splitter and diffuser?
Malt is offline
Old 06-04-2014, 09:07 AM   #114
plucas
plucas's Avatar
Drives: Subaru
Yes I can include a ride height aero map also if people would like. Just remember each CFD run takes about 24 hrs to converge so it can not be done super quickly.
plucas is offline
The Following 3 Users Say Thank You to plucas For This Useful Post:
civicdrivr (06-04-2014), JDKane527 (06-04-2014), Malt (06-04-2014)
Old 06-04-2014, 12:21 PM   #115
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
Also consider that it takes 24 hours to run, AFTER Paul has to spend countless hours programming the cad models.
It's not exactly like starting up the Xbox
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline
The Following 2 Users Say Thank You to Wonderbar For This Useful Post:
plucas (06-04-2014), wparsons (06-08-2014)
Old 06-04-2014, 12:59 PM   #116
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
You mean to tell me that Forza isn't an accurate depiction of aerodynamic tuning??
Parting out HERE
civicdrivr is offline
The Following 3 Users Say Thank You to civicdrivr For This Useful Post:
gkubed (07-05-2017), Wonderbar (06-04-2014), wparsons (06-08-2014)
Old 06-04-2014, 01:01 PM   #117
gramicci101
Off Topic
What if it was an Xbox One? Those are supposed to be pretty powerful, right?
gramicci101 is offline
The Following 3 Users Say Thank You to gramicci101 For This Useful Post:
gkubed (07-05-2017), suaveflooder (06-09-2014), Wonderbar (06-04-2014)
Old 06-04-2014, 01:48 PM   #118
JD86
Drives: 2013 Toyota 86 GT
What program is your car model generated in? Is it compatible with CAD and or Solidworks and can I have/purchase a copy? Base car only, don't need your splitter... Although if you're feeling generous I wouldn't say no Haha!
JD86 is offline
Old 06-04-2014, 03:28 PM   #119
plucas
plucas's Avatar
Drives: Subaru
All CAD is done in Solidworks. It is possible to buy my model (to much time and money invested to give it away for free). PM me for details.
For anybody who doesn't know, CAD is computer aided modeling and is used to make 3D and 2D parts in the computer. CFD is computational fluid dynamics and is used to solve math equations for fluid flow.
plucas is offline
The Following User Says Thank You to plucas For This Useful Post:
glamcem (06-05-2014)
Old 06-08-2014, 03:16 PM   #120
Kwaziekeller
Kwaziekeller's Avatar
Drives: '13 Argento MT FR-S
Like @Malt, I am running the FT86SF/Hancha group street splitter and the @Wonderbar V1 diffuser. I think it's a great combo. I haven't been out on a track, but on twisty backroads it is pretty noticeable. I feel the car is still very balanced, and that the limits of understeer and oversteer are both higher than before mods. Most notably, the car feels more stable and planted. Being on public roads, and being an amateur, I don't push overly hard. That being said, I've only been able to induce understeer once and have yet to be able to power oversteer since adding these products. I was able to induce these conditions at will prior to these products, at stock power levels on 30k mile Primacy's.
Kwaziekeller is offline
The Following 3 Users Say Thank You to Kwaziekeller For This Useful Post:
eric6 (06-08-2014), plucas (06-08-2014), Wonderbar (06-08-2014)
Old 06-08-2014, 04:02 PM   #121
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
i've got the splitter on the way and hope it'll be here before satudays mountain drive.
If i'm lucky ill be able to get in on the next batch or two of V1 diffuser.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline
The Following 2 Users Say Thank You to Roadcone For This Useful Post:
Old 06-08-2014, 06:54 PM   #122
eric6
eric6's Avatar
Drives: 93 MR2 Turbo; 2014 BRZ
Glad to hear you guys are enjoying the splitter! As we stated earlier, we have been working on a "race version" that will increase downforce and handle the additional loads at higher rates of speed. Paul has come up with the pieces that will add downforce and I have been working on the splitter ties for reduced deflection.
These are very much prototypes so that I can get the correct tie length and prove design concept.
The final version will put the rod end in double shear for added reinforcement, the tie will likely be a piece of single machined billet, etc. Currently I can stand near the tie rod with minimal deflection.
Question for everyone. Their are two mounting points I can go with on the crash beam. One way will require drilling on a pre-existing hole and then adding a riv-nut. The other will require you to drill holes through the pinch weld (pictured below) and then bolt and nut. Looking for what you guys would prefer so that I can continue to advance the design. If you have another thought, let me know as well.
eric6 is offline
Old 06-08-2014, 07:58 PM   #123
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
The JR oil cooler mounts to the bottom of the crash beam. If the rivet nuts are the same size they can share the same mounting holes. I will have to verify the bolt size, but I believe it was M6.
JDKane527 is offline
Old 06-09-2014, 08:18 AM   #124
Model Citizen
Lacking brains
Drives: frz
Interference with typical fi kit ic?
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline
Old 06-09-2014, 11:09 AM   #125
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I have no input for the mounting holes, but will that stay design route through the FR-S grille without cutting as well?
Parting out HERE
Old 06-09-2014, 12:21 PM   #126
Trac Toy
Trac Toy's Avatar
If your buying the race version then cutting a small notch in some plastic shouldn't be an issue. If it is something you can't stomach then stick with the street version.
.o0+Eric+0o.
2016 Chrysler 200S 3.6
2013 FRS 6MT
Trac Toy is offline
Just Added APR front splitter and side splitter Pekingduck Cosmetic Modification (Interior/Exterior/Lighting) 42 08-31-2016 11:22 AM
What front splitter? Takumi788 Cosmetic Modification (Interior/Exterior/Lighting) 7 04-30-2014 07:20 PM
Perrin Oil Cooler - Impressions, Pics, and Data swift996 Engine, Exhaust, Transmission 36 04-29-2014 10:03 AM
BRZ Front Splitter Jive Turkey Cosmetic Modification (Interior/Exterior/Lighting) 43 01-26-2014 04:29 PM
Front Air Splitter sw20kosh Tracking / Autocross / HPDE / Drifting 6 02-17-2013 06:41 PM
