Old 06-02-2014, 01:53 AM   #701
inositle
Drives: Subaru BRZ Limited WRB
Is there any way to reboot the unit if touch isn't working? I've had it happen twice now where I can't touch on the screen but the buttons semi-work. Not very reassuring for a new device...
inositle is offline   Reply With Quote
Old 06-02-2014, 03:26 AM   #702
enjoi23
12% Done with the car.
enjoi23's Avatar
Drives: FRS
Yeah something's off guys. I've tried multiple ways to get my usb drives working and no luck. I've even tried using multiple usb drives with some music in folders and others not in folders. it's not working. Also, I have extra harnesses hanging around after everything is pretty much installed. Is there an update that could fix the usb issue because I think it's the HU, not the wiring.
HOUSTON TEXAS FR-S/BRZ OWNERS - https://www.facebook.com/groups/houston86/
enjoi23 is offline   Reply With Quote
Old 06-02-2014, 03:58 AM   #703
chjno86
a/k/a ikuzOtaku
chjno86's Avatar
Drives: Whiteout FRancheSka
sorry if this was already asked since there's 32 pages but is there mirror link?
instagram.com/chjno86 __ #TEAMFRANCHESKA _ #SOCALVALLEY86
chjno86 is offline   Reply With Quote
Old 06-02-2014, 07:47 AM   #704
DC2R
Drives: 2014 Scion FR-S
Reset button.hit it with paperclip or pen
Sent from my SM-G900T using Tapatalk
DC2R is offline   Reply With Quote
Old 06-02-2014, 10:23 AM   #705
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
No, the specific technology called MirrorLink is not on the Dashlinq. From what I know about MirrorLink, we're not missing anything, as we have apps right on our head unit. No need to run them from a phone.
Prog is offline   Reply With Quote
The Following User Says Thank You to Prog For This Useful Post:
chjno86 (06-02-2014)
Old 06-02-2014, 10:24 AM   #706
Prog
Prog's Avatar
Do you have them formatted FAT32? No clue if the Dashlinq reads other filesystems, but it's worth asking.
Old 06-02-2014, 03:44 PM   #707
SPT Legacy
Drives: 2014 Lightning Red BRZ
Maybe a dumb question that I should have asked before ordering, but are the wiring harnesses the same between the FR-S and the BRZ Limited heat units?
SPT Legacy is offline   Reply With Quote
Old 06-02-2014, 05:01 PM   #708
DC2R
I don't believe so. Stock radios are completely different for starters
Old 06-02-2014, 05:29 PM   #709
SPT Legacy
Guess I'm just wondering since it was a joint build with Toyota if it'll plug right into the Subaru harness...I mean the wires are all in the same place, except for maybe the GPS/XM..
Old 06-03-2014, 03:06 AM   #710
enjoi23
enjoi23's Avatar
Drives: FRS
Didn't know what FAT32 was until now lol, but that wasn't the problem. I backed up all of my documents and music that was on the drive, formatted it, and re-downloaded everything back on it, but to no avail.
Old 06-03-2014, 03:28 AM   #711
enjoi23
enjoi23's Avatar
Drives: FRS
Everything plugged up as it should have, but I have extra harnesses in the back. One of them is what I believe to be the Antenna for the radio, but I'm not worried about that. What's the other one?
Old 06-03-2014, 11:17 AM   #712
milhouse
Because Racecar
milhouse's Avatar
Drives: 2013 Lightning Red Subaru BRZ
It plugs right in. I have a BRZ w/ nav and apart from the rear camera, the harness plugs right in.
milhouse is offline   Reply With Quote
Old 06-03-2014, 02:59 PM   #713
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
No, they definitely are, the BRZ just has a few more plugs due to Sat radio and stuff.
Deathalo is offline   Reply With Quote
Old 06-03-2014, 03:02 PM   #714
Deathalo
I can't remember exactly what that one is for but you're going to have at least one stock harness hanging there, at least if you don't have the AUX port adapter hooked up. None of that affects USB functionality though, USB is the easiest thing to hook up on this unit, if it's not working I'd contact them because your unit might have an issue.
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 07:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 04:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 05:58 AM
