Drives: Scion - FRS
I think I broke the tie rod.......
I need some input here guys! I am really worried now!!
![]() So I was at a Test N Tune today and I i guess I was having too much fun. I spin out during one of the corners and hit nothing (it was a big open space), but I heard a bump. My assumption is that I might have spin out to a bumpy area that break one of my tie rod. So at the end of the event, I drove home and I realize that my car is leaning towards the left when the steering wheel is straight. I have to hop around 15-20 degree to the right to keep my car straight. Its sunday tomorrow, so I probably won't be able to check my car until Monday. I don't think I will drive it until then. If anyone know what might happen to my car, please give me some feedback. I am thinking about it all night. Thank you guys!! Updates in the bottom! Last edited by jshum; 06-02-2014 at 08:56 PM. |
#2 |
Lacking brains
Drives: frz
If you broke a tie rod you wouldn't have driven home.
You did fuck up something though. Have aftermarket suspension? Slotted struts, camber bolts, camber plates? I've screwed up my camber spinning and had the car pulling. In my case it was slotted struts, loosened and put back to desired camber. |
#3 | |
Drives: 2013 GBS BRZ Limited
Let me guess .... you "barely" got it over 55 MPH.... |
#4 |
Drives: AE86, 2x GT86, TE27
You didnt just knock air out of the left tyre? Lol
#5 | |
Drives: Scion - FRS
All stock. lol
#6 |
Drives: Scion - FRS
Well....i have to lol....because I drove 2 hours to the event...and I try to make it back safely (that was before I knew shits gone wrong...I thought I just fuked up the alignment..).....but the thing is I actually got into 75 MPH.....but after doing some research online, I wouldn't drive it now....
#8 | |
If you leave the track for any reason (spin, slide wide, etc), you should do a check of ALL the suspension parts before going back out on the track or driving it home, ESPECIALLY if you can feel something isn't right while driving it. As for what you did, you definitely didn't break a tie-rod. One might be bent, but not fully snapped. You may also have bent a strut or bent a lower control arm. If the car is pulling so hard to the left with the wheel straight you should be able to see what isn't pointing in the right direction with the wheels still on the car.
| The Following 2 Users Say Thank You to wparsons For This Useful Post: | cdrazic93 (06-01-2014), civicdrivr (06-02-2014) |
#9 | |
Drives: Scion - FRS
Thanks for the input! I really appreciate it. And I learned a lesson from this. I will definitly watch out next time whenever I am finish with an event. Ya...I think its bent from what I have seen on people's posting on what a bent tie rod can cause. It has the same symptoms. Will have the car checked first thing monday morning.
#10 |
Just a dude
Drives: Scion FR-S 2013
Jack up front of car yourself, crawl under should take approx 30 seconds to see what is out of place?...
#11 | |
Member of the year - 2016
Drives: Scion FRS
I don't want his mom coming on the forum to tell us little Jimmy was crushed by a car.
| The Following 4 Users Say Thank You to dem00n For This Useful Post: |
#12 | |
Just a dude
#13 |
Drives: BRZ Limited
If you didn't hit anything I really don't see how you would have bent a tie rod.
#14 |
Drives: Scion - FRS
So I jack up the front side....I didn't see anything wrong...
Well..my car will be checked tomorrow. I hope its nothing serious |
| So i broke my wheel speed sensor | bkblitzed | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 11-18-2016 04:04 PM |
| My ECUTEK usb key broke.. | JerryMichaels7 | Software Tuning | 6 | 02-07-2014 12:53 PM |
| Broke down and did the interior. | jybrd | Cosmetic Modification (Interior/Exterior/Lighting) | 20 | 07-15-2013 08:49 PM |
| Broke Screw on OEM FRS mudguard :( | shellslinger | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 06-20-2013 11:29 PM |
| Oh-Oh's, I Think I Broke It! | track_warrior | Issues | Warranty | Recalls / TSB | 232 | 06-12-2013 10:58 PM |
