#85 |
It's really different markets and preferences + different road conditions as mav and Orbital said.
There have often been different suspension tuning philosophies when it comes to Japan, Europe, and now US based suspension companies. Part of it is based on each of our roads and tracks, not because one is the "best" way. For what it's worth, in the past I've questioned the spring rate choices of a lot of the JDM coilovers because of inconsistencies across different cars and their motion ratios (like GD and GR Impreza having similar spring rates but very different rear motion ratios). Some of them have picked up on this but not all. - Andy |
#86 |
Drives: Toyota GT86
I also notice the Japan Ohlins offer two specs. One is rear pillow ball type and another is rear rubber bush type.
Any idea what's the difference ? The US Ohlins rear is which type, rubber bush or pillow ball ? |
#87 |
Rubber bushing is softer and more compliant than pillowball (metal). Not a huge difference though to be felt in the rear.
US Ohlins are pillowball. - Andy |
#88 | |
Running the 9k springs would really hurt the street manners.
#89 |
driving smoother faster
Drives: Sold
#90 |
Drives: Toyota GT86
#91 |
Subaru Ambassador
Drives: 13 BRZ 18 Silverado
He is running the stock Ohlins setup.
#93 |
Drives: Toyota GT86
Anyone tried 9k/7k setup or anything close to this on ohlins before ?
What effect will it have if the front spring rate is higher then rear ? Sent from my iPhone using Tapatalk |
#94 |
#95 | |
Drives: 04 Toyota Tacoma Prerunner Reg Cab
So I am assuming the Ohlins can easily handle greater spring rates of 7k-9k? 7k or 8k all around sounds nice. |
#96 | |
i'm sorry, what?
Drives: Canada
keep in mind that any high end manufacturer will match the shock to the spring in an absolute sense, otherwise they wouldn't be high end... but the niche question is what application is the packaged valved and whether you actually use the car as per the application or you only think you do... and even more importantly what does the manufacturer assume the application is given its name. Ie, Ohlins says they have a "street" setup but maybe their ideas of street are smooth road and gentle driving? I don't know. I think for many north American cities the japenese/European understanding of "street" needs to be tuned down a notch... or four. The reality is that our roads are shit and what we would all benefit from is rally-focused suspension.
| The Following User Says Thank You to 7thgear For This Useful Post: | chaoskaze (10-24-2014) |
#97 |
@dp1 @Racecomp Engineering @mav1178
Do you guys remember the TQ value for tightening the 5mm allen heads on camber plate bolts?
#98 |
I think all the comparing of US roads to European or Japanese roads isn't a good argument.
You can't really pigeon hole the entire US into one category of having rough sht roads. Same for Asia and Europe as having all 100% smooth roads. They are all big vast lands with different infrastructures per city/state/county/town. There are some parts in Los Angeles which are rough in east, south and north LA, other parts which are "glass smooth" in west LA and Santa Monica. Drive an hour south to OC and SD and it is also different - there's some sht roads in Santa Ana and Anaheim, where as Irvine and south OC has "glass smooth" roads. Go to the east coast and it is the same - both smooth roads and really old dilapidated roads. Europe is the same, if not even more diverse (since we're talking multiple countries that have an even older history). I've seen plenty of sht roads, cobblestone roads, around Italy and Rome, London, Paris, Spain.. while some highways are "glass smooth." Japan would be no different. |
| ohlins road and track shock absorbers | CyberFormula | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 31 | 11-11-2014 06:00 AM |
| >> OHLINS Road & Track Coilovers - First Shipment IN - FT86 Special - FREE Shipping! | Circuit Motorsports | Brakes, Suspension, Chassis | 90 | 08-16-2013 01:39 PM |
| Ohlins Road & Track Coilovers - IN STOCK!!! | RallySport Direct | Brakes, Suspension, Chassis | 7 | 05-28-2013 05:11 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| Ohlins Road & Track Subaru BRZ and Scion FR-S | HP Autowerks | Brakes, Suspension, Chassis | 0 | 04-24-2013 04:27 PM |
