go_a_way1
Old 05-28-2014, 04:21 PM   #519
1086
1086's Avatar
Drives: UM86 - 6MT
Originally Posted by CSG David View Post
If you plan to tune with OFT, you have to stick to OFT to utilize the tune. If you plan to change to EcuTek, you will need to tune it with EcuTek. Per OFT's website:
Will the OpenFlash Tablet work on a vehicles with a pre-existing Ecutek tune?
We do no recommend trying to read and edit an Ecutek tuned ECU with OpenFlash Tablet. Instead, we suggest flashing your ECU back to 100% stock configuration using the Ecutek programming cable and the proceeding as normal. There is no longer any need for the Ecutek cable or license.
I understand you have to use one or the other. However, all I am asking is, can I use my OFT to run the CARB legal map for the JR kit? Meaning there will be no problems?
Later on down the road, I would like to upgrade to Ecutek, but initially, if I can utilize the OFT's capabilities then at least I know I don't need Ecutek off-the-bat.
1086 is offline   Reply With Quote
Old 05-28-2014, 04:25 PM   #520
CSG David
CSG David's Avatar
No. You cannot run the CARB tune on OFT. It has been configured and locked in the EcuTek setup. Your best bet is to just get a tune done through OFT with an overpipe and front pipe.
The Following User Says Thank You to CSG David For This Useful Post:
1086 (05-28-2014)
Old 05-28-2014, 04:52 PM   #521
mp600
Drives: 2014 White FRS
I'm on 93 octane here in Florida. Looks like someone else is also seeing very very bad MPG on the track. I still can't understand by so poor mpg now at the track when used to get 16-17 at the track prior to the install. ( were not talking about a large increase in HP )
Any one else have a moto-east tune?
mp600 is offline   Reply With Quote
Old 05-28-2014, 05:08 PM   #522
CSG Mike
CSG Mike's Avatar
Originally Posted by Kids Heart View Post
I would like to know the same.
@CSG David or @CSG Mike I have an OpenFlash Tablet. Is it possible to get the TIY kit initially and run it with the OFT? And then later on down the road I can upgrade to Ecutek?
Possible? Yes. I don't believe that has been done yet, but in theory you can.
1086 (05-28-2014)
Old 05-28-2014, 05:08 PM   #523
CSG Mike
CSG Mike's Avatar
Originally Posted by Casey10s View Post
Another question before I get the install done. From one I can tell in the estimate and talking to them, they are changing my oil and refilling with Brad Penn 15w-40. Any comments on this? Brad Penn has a disclaimer for possible damage to catalytic converters from the zinc and phosphorus additives. If not a good choice, any other suggestions?
I have no experience with Brad Penn. We recommend any of the top shelf full synthetics. Redline, Torco, and Motul.
We run Motul in our car, and we are Motul and Redline dealers (we use Redline in CV joints... so we became dealers)
Old 05-28-2014, 05:10 PM   #524
CSG Mike
CSG Mike's Avatar
Originally Posted by mp600 View Post
What MPG are people seeing? I have the jackson kit with Moto-east tune and am getting 16mpg on highway, 12 mpg combined city/highway , and worse of all 8 mpg at the track! Moto-east claims this is normal.
PS: On saturday at the track I had to fill-up after every two 25 minute sessions..
That is normal if... you've got a heavy foot. Amateurs don't use NOS. You don't need two of the big bottles.
Calum (05-28-2014), King Tut (05-29-2014)
Old 05-28-2014, 05:11 PM   #525
CSG Mike
CSG Mike's Avatar
No, you need an ECUTek license to use the CARB calibration. This is a CARB requirement (for those of us that need CARB)
1086 (05-28-2014)
Old 05-28-2014, 05:11 PM   #526
CSG Mike
CSG Mike's Avatar
We saw around 4 MPG on track with the NA car. Oddly enough, because we have more power now, I can't WOT as much, and we actually saw a slight MPG increase...
The stock car just DUMPS fuel at high RPM to cool the engine.
Old 05-28-2014, 05:29 PM   #527
1086
1086's Avatar
Drives: UM86 - 6MT
Excellent that is all I needed to know. I am in California so I would like to abide by the CARB requirement/law. At least I now know that I need to sell my OFT and upgrade to Ecutek to make everything seamless. Thank you!
The Following User Says Thank You to 1086 For This Useful Post:
CSG Mike (05-28-2014)
Old 05-28-2014, 06:19 PM   #528
enivid
enivid's Avatar
Drives: WRB JR BRZED
I
what do you think of the tune so far? How much is it?
enivid is offline   Reply With Quote
Old 05-28-2014, 06:32 PM   #529
kbaxter
Drives: 2014 BRZ
Ordered this kit + oil cooler last Friday from CSG. Quite excited for it to arrive and install.
Anyone using a catch can with this kit? If so, which one?
kbaxter is offline   Reply With Quote
The Following User Says Thank You to kbaxter For This Useful Post:
Jackson Racing (06-11-2014)
Old 05-28-2014, 09:31 PM   #530
loafy777
Drives: 2014 Monogram FR-S
Hopefully this isn't a redundant question for my first post but I was wondering what sort of RPMs are you guys at while cruising on the highway? I'm probably around 3400rpm in 6th going ~70mph (stock). Was curious if the extra power might ease that a bit...
Thanks in advance.
loafy777 is offline   Reply With Quote
Old 05-28-2014, 10:02 PM   #531
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
I believe there is an owner a few breads back that has a catch can. Pretty cool mounting location too. Pics are posted of it...
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 05-28-2014, 10:04 PM   #532
*LongFella
*LongFella's Avatar
Thanks in advance.
Welcome!
I don't believe you will see it change much, if at all. But I'm no expert...
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
