#337 | |
Drives: 2013 Whiteout FR-S
Thanks!
| The Following User Says Thank You to kanundrum For This Useful Post: | CSG Mike (05-27-2014) |
#338 |
Drives: '14 FRS White
#339 |
Drives: 2013 Black FR-S
#340 | |
I've read using multiple loggers, gauges, OBD2 bluetooth units with Android/ios software, and our numbers are fairly consistent throughout mulltiple cars... |
#341 | |
Drives: Toyota 86
The new grille allows more air to pass through as it has more openings than the stock one. |
| The Following User Says Thank You to Bl1tzkr1eg For This Useful Post: | estarmer (10-16-2014) |
#342 |
NASA SpecE30 Racer
Why is it that the SC owners don't seem to understand what the word linear means? In order to have "power is linear" you have to have a flat torque curve. I have yet to see a single SC kit that has a flat torque curve. They always build boost/torque as RPM increases producing a non linear power curve. What you have is a more linear boost/torque curve. It isn't like a bigger engine because you still don't have any low end torque as your torque peak isn't till when close to max boost is hit in the upper RPM range.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following 2 Users Say Thank You to King Tut For This Useful Post: | andrewFT86 (05-27-2014), Rosticles (05-27-2014) |
#343 | |
King of Kiwi Palace
Drives: Faster than you
This is mostly what I've observed.
#344 | |
King of Kiwi Palace
#345 | |
Drives: 2013
We do have the shroud only available but our standard option fan is on a national back order, we should have plenty the first or second week of June. |
| The Following User Says Thank You to Carolina Dyno For This Useful Post: | CSG Mike (05-27-2014) |
#346 | |
Drives: 2013 Ultramarine FR-S
![]() Linear means along a straight or nearly straight line. This doesn't mean it has to be horizontal. A vertical line is just as linear as a horizontal one. A linear torque curve can be a flat torque curve, but it doesn't have to be. It can also be a curve that builds torque at a steady rate, creating a straight line. His point about a SC not creating the surge of power that TC's do is valid. The SC's available for this platform absolutely create a more linear tq curve than TC's do.
![]() '13 Ultramarine 6MT FR-S || K&N Drop-In, SpeedFactory V1 Cat-Back || Moto-East tuned Join the 86 Owners Clan on Clash of Clans: "86 Owners" Password: "fa20" || Help us take over the world || Thread |
#347 | |
Linear regression would yield a much better match to a SC power curve, than a turbo power curve, whereas a turbo curve would better fit a non-linear regression. Additionally, turbo response is inconsistent; transient response is important ![]() With a turbo car, you have no/minmal boost, and then you hit your spoolup threshold, and get boost, and then you keep that boost while extra air is bled off. That's not linear. Another way to see if the power is "linear" is to look at the boost graph. The turbo boost graph is not linear at all. It is low, low low, suddenly climbs, and plateaus (or drops off), while the SC boost graphs steadily climb and a near linear rate. You can almost think of the boost curve as a "multiplier" for the NA torque curve. |
#348 | |
NASA SpecE30 Racer
(TQ * RPM) / 5250 = HP Example of 300 ft-lbs @ 4000 RPM and 7000 RPM: (300 * 4000) / 5250 = 229 hp (300 * 7000) / 5250 = 400 hp The slope for those points on a typical RPM/horsepower curve would be: 229/4000 = .057 400/7000 = .057 In order to have a "linear power" or horsepower curve, the torque has to remain a constant so that the slope of the line remains constant and linear as RPM increases. If the torque increases as RPM increases then the horsepower curve is no longer linear. I think you are confusing a power curve and a torque curve. The SCs do produce a more linear torque/boost curve, but NOT a power curve as I stated in my OP.
- King Tut
#349 | |
NASA SpecE30 Racer
- King Tut
#350 | |
The Turbo car is only flat within the boost threshold. If you look at the *entire* powerband, it is not flat. (relatively) Flat torque curve: ![]() Not flat at all torque curve. Well, actually it's flat-ish if you look from 4000 to redline, but in a bad way; the torque keeps dropping from 4000 to redline.:
| going forced induction | ft86me | Forced Induction | 14 | 02-05-2014 09:23 AM |
| So who is running Forced Induction and tracking their car? | track_warrior | Tracking / Autocross / HPDE / Drifting | 88 | 08-20-2013 11:00 PM |
| Forced induction for ATs? | Lokutus | Forced Induction | 10 | 02-26-2013 04:42 PM |
| NOS or Forced Induction? | v3rgil | AFRICA | 1 | 11-08-2012 08:17 AM |
| Forced Induction | Primo86 | Engine, Exhaust, Transmission | 11 | 05-29-2012 08:50 PM |
