#309 |
Drives: Toyota 86
Can you recommend a fan/shroud that will bolt right up, and that flows more air than the stock fans? What kind of coolant and oil temps are you seeing when testing at 115F ambient?
#310 | ||
Drives: 2022 BRZ Limited
![]() ![]() ![]() With that said, I did remove the panels on the left and right side of the intercooler instead of trimming/putting a hole and put the IC piping through them..I never really thought about that, if we are talking about the same plastic trims.. maybe I should put them back on, good call.. Quote:
10c drop in the coolant temp is huge it actually puts the car in the NA range again.. Other options on my mind; trimming the side vents garnishes and/or get a vented hood to release the excessive heat out of the engine bay..I also ordered some gold high temp foils to wrap the intercooler pipes( not that they become too hot) and the ingition coils as preventive heat control.. Please keep us updated about the coolant temp gauge and OEM sensor
#311 | |
I asked my tuner @moto-mike to lower the fan activation temps to 204F to prolong to effects of the heat by activating the fans earlier but at this point I am not sure if it's functional.. also what kind of fan upgrade I may consider? thanks in advance
#312 | |
I'd recommend the @Carolina Dyno shroud with the largest 12" SPAL fan you can fit. The 20A Paddle blade one is ideal. just *one* of these is enough to keep our 450hp s2k cool on a stock radiator. The stock thermostat should kick the fans on at 195F; the fans should just stay on period while the coolant is that hot, especially when you have a FMIC adding resistance to the airflow to and through the radiator. No heater here; the car's not overheating. Our boosted BRZ has had zero heat issues. We are currently testing prototype aftermarket radiators, but have not had any of the coolant temp issues others are having. Do keep in mind that we make less power (245whp) |
| The Following User Says Thank You to CSG Mike For This Useful Post: | glamcem (05-25-2014) |
#313 | |
#314 | |
However, when you're pushing at high speeds, the FMIC adds restriction and heat, and the rad itself is also adding restriction. While surface area with the Koyo is probably 2.5x larger, the temperature of the air going over that surface area is higher, the density of that air lower (FMIC restriction), and the velocity of the air is lower as well (FMIC + bigger rad + air escaping around the sides). In other words, the net result is that when you're sitting, adding minimal heat to the system, the fans are pulling almost as much air over a great surface area, bringing the temps down faster. But, when you're loading the system, you have less net cooling, so your temps stabilize higher. Bigger is not always better. Just how tires that are too large (wide) slow the car down at the track, even with increased cornering grip, adding a bigger radiator is not always the best solution. |
#315 |
On my car I have the fans turn on Very early, so basically they stay on at all times while the car is running.
I think this is important, because without the fans on, the radiant heat from the turbo can melt things. With the FB shroud and fans, I think most of the cooling comes from the fans pulling air through. With the proper air dams in place, air that normally flows around and above the radiator will be forced through the radiator (and intercooler). I'm not sure, but I think what this does, more than focusing air through the radiator, is it creates the proper pressures so that engine bay air is exhausted more efficiently, possibly? I installed the Drift Armor crash bar, and cut holes in the bumper, which I know lets a LOT more air in through the grill opening, a LOT more air. That, coupled with my skidplate mod, or vented hood (or both) I know will help with the air exchange that is needed for track duty (more air IN, more air OUT) I haven't installed the air dams around the radiator yet. I'm curious to see the difference the air dams around the radiator will make, and whether forcing the air through the radiator, or just pushing all the extra air into the engine bay will work better. If the fans are pulling adequate air across the radiator, I wonder if leaving the air dams off might result in higher engine bay air pressure (with the mods I've done to increase air IN), which might actually push hot air out of the engine bay faster (with the mods to increase air OUT-vented hood/skidplate mod). I've been thinking of some way to measure the engine bay temps and air pressure, maybe with some type of homemade barometer? |
#316 |
Drives: Toyota 86
I would recommend you go with Vortech supercharger for track use. I have personally ran about 4000 hard kms on the track and yet to experience any failure. My water temp never reaches above 110 degrees celcius and oil temp never reaches above 120 degrees celcius after 4 consecutive hard 2.30minute laps.
Good thing about an SC is that power is linear, so you dont get a sudden surge of power like u get when on turbo. It's just like you're running a bigger engine. Mods are: Vortech SC (300whp) Koyorad radiator Tomioka Oil cooler Honeycomb front grille |
| The Following User Says Thank You to Bl1tzkr1eg For This Useful Post: | HRTROB (05-26-2014) |
#317 |
Drives: Toyota 86
Spent the afternoon working on the car. Pulled the bumper for the nth time to stuff some foam around the radiator. I reused the foam that was on the stock radiator and stuck it on the sides and bottom of the Koyo.
![]() ![]() ![]() I also reinstalled the flaps on the sides of the grille. I pulled these off because the driver side was making contact with my oil cooler lines ![]() If these do not help, then I guess the next step would be bigger fans and/or a vented hood |
| The Following User Says Thank You to HRTROB For This Useful Post: | Tye300 (05-26-2014) |
#318 | |
Drives: dark grey metallic Toyota 86 MT
#319 | |
With an Ecutek tune you can easily make the turbo setup look exactly the same as a SC if you wanted. There are quite a few on here using per-gear boost control and also ramping up target boost by RPM (what a SC does) because of traction issues. When I took a look at Doug@TopSpeeds car he has the AWIC which only requires a very small heat exchanger in front, about the size of an oil cooler so it's less of a barrier. I'm not sold on the AWIC system not heat soaking on a track, however they have used AWIC systems for their TT R8 and Gallardo setups with good luck. They were even doing OLOA in the TT R8 earlier this year. He was using what looked like Inconel heat shielding around the stock radiator fans with his front-facing turbo. I know the stuff isn't cheap, it's like $120 for a 12x12 sheet, but it works very well as a heat barrier. If people are using 50/50 water and coolant, especially in a hot climate I would change that for a 80/20 or 70/30 blend. Even going to a 70/30 will make a difference. |
#320 | |
Drives: Toyota 86 TRD Version AT
Do tell us if those things made a difference! Thanks!
#321 | |
#322 | |
As far as coolant temps, I have always had higher coolant temps even when the car was bone stock no mods. On the dyno saw up to 220F after a stock run, again bone stock. I dont know if some cars have more heat issues than others. My car was always bouncing from 200F to 212F with the stock radiator in idle. Track was the same story. After the Koyo, same crap difference was recovery time was faster would go from 212F fan activation down to 195F and more slowly back up. After Vortech was always in the 205-212F during slow speed and idle. Track time it was 208F-215F. With fan speed at 200F is always 192-200F and oil is 10F cooler on track. I have always had in dash tablet gauges installed long time ago before anyone was doing it on this car. Always have monitored the cars oil and coolant temps before and after mods for this reason. Point is you have to set a goal and target temps. i cant and wont start cutting holes in bumper, skid plate adding vented hoods because I need a car that can also get heat into it quickly when the temps go below 50F half the year. If you are in a dry hot climate go for it. But if you can keep coolant temps at 200-210F and oil temps below 250F no need to do anything on a street car.
| going forced induction | ft86me | Forced Induction | 14 | 02-05-2014 09:23 AM |
| So who is running Forced Induction and tracking their car? | track_warrior | Tracking / Autocross / HPDE / Drifting | 88 | 08-20-2013 11:00 PM |
| Forced induction for ATs? | Lokutus | Forced Induction | 10 | 02-26-2013 04:42 PM |
| NOS or Forced Induction? | v3rgil | AFRICA | 1 | 11-08-2012 08:17 AM |
| Forced Induction | Primo86 | Engine, Exhaust, Transmission | 11 | 05-29-2012 08:50 PM |
