| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#127 | |
Drives: FR-S 10 series
#128 |
265 like a charm!! Very flush... Im looking at it still nice fit... It SHOULDNT rub... Ill see soon Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to Pablitomarrero For This Useful Post: | Bimble Bamble (10-30-2016) |
#129 |
2 finger gap (one on top of the other) from spring up front with 235s, not ganna change that Sent from my iPhone using Tapatalk |
#130 |
Confirmed no rubbing in the rears: lowered w trd springs and on 265s
#131 |
Drives: Ultramarine '13 FR-S
Have any shots of the whole car?
Sent from my SCH-I605 using Tapatalk |
#132 |
Wheel Directory: Enkei RS05RR 18x8.5 +42
I was wrong... I seem to be slightly rubbing on the outside of the wheels as confirmed by marks on the wheels. Cant be too much as i neither hear or feel it and must be when i go over dips at speed. Any suggestions? Prob a bit of camber?
Edit: only on the rears Sent from my iPhone using Tapatalk |
#133 |
Are you on coilovers? Either add a little height or a bit of camber.
#134 | |
#135 |
I wouldn't even know as I'm on coilovers which makes it easier. The meaty thread should be able to help
#136 |
#137 | |
I like to eat!
I think you are correct, the tires are touching the rear fender wells when suspension gets loaded. I would be concerned a large bump could potentially cause fender damage. You could chalk/powder your fender to see where it rubs. It should be evident. Solutions: Roll fenders, more camber, stiff coilovers, 255s, a combination of these, aftermarket fenders, drive only on smooth roads. That's all I can think of. |
| The Following User Says Thank You to Pete156 For This Useful Post: | Pablitomarrero (05-25-2014) |
#138 |
Thanks for the edit lol. Yes 255 did not rub at all but left so much exposed rim its was bothering me (im starting to think brand of tire has alot to do with this as ive seen pics in this forum of 255's completley covering a 9.5 incher without as much stretch... Im gonna try adding a bit of neg camber to see what happens, roll fenders next if i have to
#139 | |
I like to eat!
#140 |
Continental Extreme DW in 255 are a very little stretched. If you look at jive turkeys set up his tires seem perfect.
| Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 | GuerillaRacing | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 221 | 08-01-2019 11:30 AM |
| Gauging interest Enkei RS05RR 18x9+40/18x8.5+50/18x8.5+42 | THMotorsports.com | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 09-19-2013 05:33 PM |
| Wheel Directory: BBS LM 18x8.0 +50 | stoneman155 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 20 | 07-08-2013 08:55 PM |
| Wheel Directory: BBS RE 18x8.0 +50 | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 06-25-2013 09:49 PM |
