go_a_way1
Old 05-22-2014, 08:03 PM   #2269
Hmongfrs
Drives: Red
^^^bc racing...
Hmongfrs is offline   Reply With Quote
Old 05-23-2014, 02:09 AM   #2270
Anthony @ 86WORX
Originally Posted by Michael View Post
Nice. What wheels are you getting and also, what base are you by?
I work on Nellis. I picked up a set of work VS-TX and had 5 one wheels in SoCal relip them. Should have them next week. 18x9 +25, 18x10 +13. Still don't have lca's as pbm is backordered. I may just try and pick up some rucas. Still debating on tire size as well. Here's a little teaser pic
"And when I leave, come together like butt cheeks" -Grits N' Gravy
Anthony @ 86WORX is offline   Reply With Quote
The Following 2 Users Say Thank You to Anthony @ 86WORX For This Useful Post:
gramicci101 (05-23-2014), WhiteLightning (05-23-2014)
Old 05-23-2014, 02:21 AM   #2271
gramicci101
Off Topic
That'll look nice. For tires, are you going stretched, or no? If not, you could go 245/35 and 285/30. That would look amazing. You'd probably need a lot of rear suspension work to fit 285s.
Old 05-23-2014, 02:26 AM   #2272
Michael
Lovin' the Low Life
Michael's Avatar
Drives: 2014 Scion FR-S
I went with 245/35 on my 18x9.5 wheels. Hoping to get them mounted this weekend.
I can't wait to see what he goes with for his tires
2014 Scion FRS: Bagged & Wide
INSTAGRAM: @frsmichael
BUILD THREAD: Click Here
Michael is offline   Reply With Quote
Old 05-23-2014, 02:33 AM   #2273
gramicci101
Off Topic
Well, 245/285 would be meaty rather than stretched. He could do 215/245 if he wanted to go stretched.
Old 05-23-2014, 05:39 AM   #2274
Anthony @ 86WORX
I was honestly leaning towards 205/40 in the front and 225/40 in the rear.
Old 05-23-2014, 02:04 PM   #2275
moomoopanda
moomoopanda's Avatar
Drives: Argento FRS
You should run a 215/35 and 225/35 instead. The shorter sidewall will help you lay frame when you air out. A few people I know have 40 series sidewalls and can't fully air out in the front.
In any case, somewhat dialed in the rears.
If anyone has a 20mm 5x114.3 spacer adapter for sale, please let me know.
moomoopanda is offline   Reply With Quote
The Following 2 Users Say Thank You to moomoopanda For This Useful Post:
cfig21 (05-27-2014), nab335 (05-25-2014)
Old 05-23-2014, 03:15 PM   #2276
Hmongfrs
Drives: Red
how much camber you running in the rear?
Old 05-23-2014, 03:36 PM   #2277
moomoopanda
Drives: Argento FRS
Haven't got an alignment, so I'm not sure. My friend was trying to measure with his phone and estimates that I'm around -9.
Old 05-23-2014, 04:04 PM   #2278
Hmongfrs
Drives: Red
do you have ruca too? dam i have cusco lca im kind of scared i might max it out..im at -7 now....how do you drive with out an alignment? lol you eyeball you toe?
Old 05-23-2014, 05:29 PM   #2279
moomoopanda
Drives: Argento FRS
Yeah, I have custom-shortened RacerX rucas (the same one Vic has) and PBM LCA's. Yeah, I eyeballed my toe after I adjusted my camber. I need to get a smaller tire and readjust my camber and toe and then get an alignment once I'm happy with it.
Old 05-23-2014, 05:45 PM   #2280
JdelFrs
Drives: 2013 Fr-S Release Series 10 (MT6)
I just received my Front LCA from Racer X + I am going to switch my 215/40-225/40 for 205/40-215/40
JdelFrs is offline   Reply With Quote
Old 05-23-2014, 06:43 PM   #2281
Hmongfrs
Drives: Red
dam most of you guys have pbm lca..i want them too but i also want to keep my cusco i also need to get the ruca but my fund are so low now..hahaha also how about your front whats the camber up there?
Old 05-23-2014, 07:08 PM   #2282
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
-9?.... that's a lot..
Sent from my SM-N900P using Tapatalk
Kosmos is offline   Reply With Quote
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1738 10-11-2017 05:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 03:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 11:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 11:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 03:20 AM
