Old 07-27-2010, 05:37 PM   #1
Chemist
Drives: 2005 Corolla XRS
Comparison to the MX-5 Engine
Well, I didn't know this before but the current engine in the MX-5 is a 2.0 L direct injected 4 cylinder engine. The MX-5 is also found in a RWD configuration. Therefore, this seems like an ideal comparison to the upcoming FT-86 engine.
The specs for the MX-5 engine and vehicle performance:
167 hp @ 7000 RPM (Redline = 7200 RPM)
140 ft-lbs of torque @ 5000 RPM
10.8:1 CR
Bore x stroke (mm) = 87.5 x 83.1
Displacement = 2.0L
Curb weight = 2511 pounds
0-60 according to Car & Driver = 6.7 sec (MT est)
Base Price $23,560-$30,100
Geez, I think the FT-86 is starting to sound like a hardtop MX-5 with a backseat.
I wonder what kind of tricks can be pulled off to make this thing unique. Higher rev limit? Aggressive tuning? Low weight? Higher CR? Of course, we know none of these things for the FT-86 so I'm just adding to the speculation. I'd like to think the FT-86 will come with a baseline of 200 hp, but how?
Chemist is offline   Reply With Quote
Old 07-27-2010, 09:18 PM   #2
Dimman
Kuruma Otaku
Dimman's Avatar
10.8:1 CR
Displacement = 2.0L
Well if it's going to be an EJ motor, it will have a larger bore and shorter stroke, as well as be better balanced. These can lead to a few things. Bigger bore means bigger valves can be stuffed in and potentially more flow per cylinder. Short stroke and balance means it can rev out better to spin the motor to take advantage of the potentially increased flow. The problem with going for max flow at high engine speeds (max NA power) means poor low-speed cylinder filling, but this can be addressed with tech like cam phasing and variable valve lifting systems. Also variable length intake systems like Toyota's old TVIS and resonance tuning like Toyota's ACIS can modify the powerband. Plus the direct injection will allow for more efficient combustion which can either make more power same fuel use or same power less fuel use.
200 hp will be a piece of cake, but it will depend on what they decide for trade-offs between power, economy, driveability and reliability.
Old 07-27-2010, 09:50 PM   #3
Siriusly.Andrew
Siriusly.Andrew's Avatar
Drives: 1995 Civic DX
200 hp should be a piece of cake, but it will depend on what they decide for trade-offs between power, economy, driveability and reliability.
Fixed.
EDIT : I may end up retracting this statement. Its very likely I'll be retracting this statement lol.
Originally Posted by MatadorRacing_F1 View Post
Anyway, as i was saying, "speed is expensive, how fast are you willing to spend?"
Siriusly.Andrew is offline   Reply With Quote
Old 07-27-2010, 09:52 PM   #4
Matador
hashiryu
Drives: Mk4 Supra
This.
Matador is offline   Reply With Quote
Old 07-27-2010, 09:54 PM   #5
Siriusly.Andrew
and those are the main reasons why I'll be retracting my previous statement hah. It really will boil down to what Toyota wants from the engine. In the end, I don't think it'd be to hard to make more power with this engine, if they decided to go with less power / better economy.
Old 07-27-2010, 10:12 PM   #6
Dimman
Kuruma Otaku
Dimman's Avatar
I think it will be 100hp/L just so people won't have to listen to Honda owners yammer about their motors getting better power to displacement than the new Toyota. (no offense to S2000 owners, 120/L kicked ass)
Old 07-28-2010, 10:51 AM   #7
Mouse
Drives: Miata
One thing I can say about the NC engine, after I added a Fujita intake and removed the muffler and replaced it with 2.5" straight pipe. The car pulled really hard which I would attribute to the torque of the motor. I can't explain how it felt exactly but it felt similar to when a turbo car gets into it's power band. There are dynos of NCs with intake, headers, full exhaust, and tuning(via snipertune software) making 170-180hp to the wheels. Plus there is quite a bit of parts from cosworth.
Mouse is offline   Reply With Quote
Old 07-28-2010, 05:29 PM   #8
Abflug
Abflug's Avatar
Drives: MR2
didnīt know that cosworth upgrades NCīs!
Abflug is offline   Reply With Quote
Old 07-28-2010, 07:31 PM   #9
Dimman
Kuruma Otaku
Dimman's Avatar
Err... really? Intake and muffler (not even full exhaust) makes it feel like boost is kicking in?
What is your turbo car experience?
Old 07-28-2010, 08:26 PM   #10
djohnson
Drives: 1996 RAV4
Don't forget, this car is getting dual injection systems... direct and port for different rev ranges
djohnson is offline   Reply With Quote
Old 07-29-2010, 11:52 AM   #11
Mouse
Drives: Miata
Ive' driven an passat(2002),wrx, sti, mazdaspeed 3, and a mazdaspeed miata. I don't know how to explain it.
comparison, engine, mazda, miata, mx-5
Is anyone else on the fence due to the engine choice? Conor Engine, Exhaust, Transmission 244 04-24-2011 09:33 AM
engine swap thread aspera Engine Swaps 231 03-15-2011 05:10 PM
Any issues with Subaru engine? CyberFormula Engine, Exhaust, Transmission 10 06-26-2010 05:02 PM
Subie rear-engine student-rendering Axel Other Vehicles & General Automotive Discussions 5 12-31-2009 09:12 AM
Accurate Engine Impressions S2KtoFT86 Other Vehicles & General Automotive Discussions 1 12-16-2009 12:05 PM
