Old 05-20-2014, 05:19 PM   #267
Dezoris
Dezoris's Avatar
I love this post.
It's easy to say talk is cheap when someone has a shop at their disposal to custom fabricate anything and make custom systems work. @JDL
That means 95% of us who can't do that ourselves and have to buy these kits from the guys who can.
This is no dig on JDL here because I would consider any of their products, but you can't seriously post something defending how flexible a car is and mount your oil cooler on the front of the crash beam where it becomes a fire/safety/oil pressure risk on street and track even in a 5MPH bump.
Old 05-20-2014, 05:30 PM   #268
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
What I think he meant was that, this is currently how the users setup looks like. He even says you can move the oil cooler to a better location for cooling (and safety). This can be done without purchase or fabrication.
I'm by no means an expert, nor do I own a shop. But the guy is right, the car is pretty darn flexible with where you can mount the radiator/condenser/oil cooler should you have one. Even turbo piping has days of room under the bumper.
In any case, any DIY garage monkey can make any configuration work pretty easily.
Ironsquid is offline   Reply With Quote
Old 05-20-2014, 05:38 PM   #269
Dezoris
Dezoris's Avatar
That makes more sense when you put it that way.
I just wanted to throw it out there that "easy" is relative and not synonymous with safe and durable in so many cases.
The Following User Says Thank You to Dezoris For This Useful Post:
CSG Mike (05-20-2014)
Old 05-20-2014, 05:48 PM   #270
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
I love using this quote, technically "There's a risk associated with going outside into the world, but that doesn't stop people from doing it everyday".
There's always safety concerns, and risk/reward plays a big part in that. For the average 'garage monkey' joe, you're willing to sacrifice a small portion of safety to alleviate heating problems, etc.
I'm not totally sure what the motive behind mounting the oil cooler in that particular fashion was, but you can pretty much ziptie the core to several different locations (side passenger fender for me).
I believe my FBM radiator/shroud/fan kit is 1 inch forward on the top, and 1 inch on the bottom. This was needed because the stage 2 downpipe is pretty large. I moved it forward by re-drilling the grommets on the bottom and skipping the first hole in the upper bracket.
Just gotta work smarter my friends. No fab needed. At the time, no FBM Stage 2 customers had done this.
The Following User Says Thank You to Ironsquid For This Useful Post:
jamesm (05-20-2014)
Old 05-20-2014, 05:53 PM   #271
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I'll be at Sebring June 7. Should be a pretty hot day. We'll see how the FBM cooling equipment holds up.
I can't wait to see that video and lap times.
Old 05-20-2014, 06:05 PM   #272
CSG Mike
CSG Mike's Avatar
0 Issues at NCCAR Tracking. Basically Hot Lapping by the end of the day in time attack format
You can see my spinout/recovery around the 4:30 Mark. Car was strong in every shift and felt amazing at WOT. I make sure to hit that 8k RPM every single time and got into 5th towards the end of the straight away. Brakes were Hawk HPS and they were horrible and over heated so I will be switching to HP Plus this week as a temp solution for this season (maybe even another brand) until I get a BBK.
I love that power
kanundrum (05-20-2014)
Old 05-20-2014, 06:06 PM   #273
xwd
Haven't you seen the JDM cars with the oil coolers _outside_ the front bumpers? It's what all the cool kids are doing these days. Well maybe they were doing it 5 years ago and I'm just out of touch.
People will certainly figure out cooling, they always do. The WRX/EVO both have turbos sitting right in the engine bay and have issues cooling with upgraded turbos, people at this point have pretty much figured out what you need to do to cool them.
The Following User Says Thank You to xwd For This Useful Post:
Old 05-20-2014, 06:09 PM   #274
CSG Mike
CSG Mike's Avatar
Originally Posted by Jon H View Post
O hai.
But yeah, a lot of GT-R drivers are pretty bad. I guess it's cool that they are out there at least though.
And of course the guy with a pic of his GT-R at the Buttonwillow gas pump responds...
hai!
Jon H (05-20-2014)
Old 05-20-2014, 06:22 PM   #275
Jon H
Jon H's Avatar
Drives: 2013 GT-R
l33t photo op location imo.
2013 GT-R
Jon H is offline   Reply With Quote
The Following User Says Thank You to Jon H For This Useful Post:
Old 05-20-2014, 07:43 PM   #276
sweetfrs
sweetfrs's Avatar
Drives: 2013 FRS
avo turbo? oil cooler, sebion vented hood
sweetfrs is offline   Reply With Quote
Old 05-20-2014, 08:40 PM   #277
CSG David
CSG David's Avatar
Originally Posted by sw20kosh View Post
So even with the Robispec cooling system temps are not kept in check out there in the dessert heat?
It's doing fine NOW after everything got sorted out. Now we need to figure out long this current setup will last.
Old 05-21-2014, 01:21 AM   #278
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Originally Posted by glamcem View Post
what did I tell you ?
Thanks for posting this vid. Great laptime, and I got to show it to the owner of the white 997.1 GT3 seen in the video.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
CSG Mike (05-21-2014), glamcem (05-21-2014)
Old 05-21-2014, 03:41 AM   #279
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
sure, since I have limited time I was pushing the car a bit more than I normally do I think..I was a bit late and could only do like 1.5 sessions due to my ABS sensor and spin afterwards
glamcem is offline   Reply With Quote
Old 05-21-2014, 03:14 PM   #280
sw20kosh
Drives: 2013 Black FR-S
@CSG Mike what oil cooler do you recommend after seeing some of these kits first hand and in action on the track?
going forced induction ft86me Forced Induction 14 02-05-2014 09:23 AM
So who is running Forced Induction and tracking their car? track_warrior Tracking / Autocross / HPDE / Drifting 88 08-20-2013 11:00 PM
Forced induction for ATs? Lokutus Forced Induction 10 02-26-2013 04:42 PM
NOS or Forced Induction? v3rgil AFRICA 1 11-08-2012 08:17 AM
Forced Induction Primo86 Engine, Exhaust, Transmission 11 05-29-2012 08:50 PM
