#43 | |
Drives: 2012 WRX, 2003 RSX Type S
#44 | |
Drives: Scion FR-S 2013 Raven
Send me a pm with your email and i will send you a PDF
o= FR-S =o |
#45 |
Drives: BRZ limited
I got those rear subframe bushing, LSD bushing, Steering bushing and tranny bushing installed, and the car feel more solid toward the ground and more respond toward the steering
| The Following 2 Users Say Thank You to peebking For This Useful Post: | Grateful Dave (06-07-2014), Mikepage (05-19-2014) |
#46 | |
I have the same setup, I have also the steering bushings, just not mentioned in my first post...
o= FR-S =o |
#47 |
Drives: Toyota 86 TRD Version AT
I ordered the KDT925. The problem is I already installed a diff brace. Would anyone know if I could use the bushings with the brace? If not, I'll just use the outrigger bushings.
#48 | |
I work on submarines and we need to specify exactly when and where the anti-seize goes. If we use anti-seize, we also need to specify a dry (no lube) and wet (lubed with anti-seize) torque. The dry torque is always higher than the wet torque. |
| The Following 2 Users Say Thank You to sshole For This Useful Post: | gramicci101 (05-19-2014), Mikepage (05-19-2014) |
#49 | |
Whiteline differential insert bushings review
Check my pictures... I don't think... Why do you want bushings if you have brace already? Do you have sound like we describe before with the brace? Am curious...
o= FR-S =o |
| The Following User Says Thank You to Mikepage For This Useful Post: | gramicci101 (05-19-2014) |
#50 | |
Off Topic
| The Following User Says Thank You to gramicci101 For This Useful Post: | Mikepage (05-19-2014) |
#51 |
I don't have the sound you guys are having. I'll try installing the outrigger bushings with the brace.
| The Following User Says Thank You to Tye300 For This Useful Post: | Mikepage (05-20-2014) |
#52 | |
Mmm no sound? Interesting... Do you have others bushings?
o= FR-S =o |
#53 |
I have the subframe inserts and the brace. I also have an aluminum driveshaft. With all the noise I get from the exhaust and the other bushings, I may be missing the sound you are saying. Haha! I'll report back after I install the outrigger bushings.
#54 |
The sound is more perceptible windows closed, radio at off and when you shift from the first to the second gears.... After release the clutch not hardly but not too firmly.... It's also possible to avoid the sound if you slowly drop the clutch....
The sound come from the clutch mechanism on the trany like mentioned before and probably just normal but mor perceptible with all bushings installed....
o= FR-S =o |
#55 |
Finally installed the bushings. I was not able to install the rear ones because I have the diff brace already. The outrigger inserts definitely stiffened up the diff as I can hear the noise the other guys are talking about.
| The Following User Says Thank You to Tye300 For This Useful Post: | Mikepage (06-09-2014) |
#56 |
Drives: 2016 STi DGM
It does
-2014 SSM BRZ MT
| DIY - Whiteline Rear Crossmember Mount Insert Bushings | F1point4 | DIY (Do-It-Yourself) Guides | 91 | 01-17-2021 02:23 AM |
| Whiteline crossmember bushing insert review | Mikepage | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 11-09-2016 03:30 PM |
| Rear Shifter/Transmission Mount Insert Bushings | TheseColorsDontRun | Mid-Atlantic | 7 | 08-30-2013 10:29 AM |
| Whiteline diff bushings and trans mount insert. | Simmons | Transmission and Driveline | 7 | 06-09-2013 08:45 PM |
| WhiteLine Positive Shift and Rear Subframe Bushings Review @ Pure Automotive | Pure Automotive | Mid-Atlantic | 5 | 01-16-2013 05:15 PM |
