Old 05-18-2014, 02:14 PM   #645
fredfromnh
Drives: 2013 scion frs
Also got new air box to replace the one mechanics cracked. Accepts drop in kn filter with ease. Old box was a struggle.
fredfromnh is offline   Reply With Quote
Old 05-19-2014, 06:13 PM   #646
Michael Blue
Drives: 1998 Audi A4 Quattro Sport 30v
Originally Posted by twag4 View Post
Most of the time, longer intake runners (however they are employed either different manifold or spacers) will add to top end....
My understanding was different.
Looking at ITB kits (individual throttle body) through the years, it seemed the short-stacked intake trumpets were for high-rpm power, while the longer trumpets were for low/mid-range torque.
(Pic of ITBs without filter assembly)
Michael Blue is offline   Reply With Quote
Old 05-19-2014, 08:35 PM   #647
twag4
Drives: frs
If I recall, my original statement was in regard to carbureted v8 engines back in the good old days. I claim no knowledge or experience with itb. I have employed many a long runner Holley street dominator and strip dominator high rise intakes, and I promise you they reduced bottom end and increased top end.
twag4 is offline   Reply With Quote
Old 05-20-2014, 12:07 AM   #648
Boxer486
Drives: small
That's likely due to a weird synergy the carburetors in question had with your particular intake manifold like dual plenums which do weird things to airflow based on what you stack on top. It's just due to weird antiquated designs that have strange airflow characteristics. Shorter is better for top end power and longer for low to mid torque all things being equal. When you start mixing different types and sizes of carbs with various jets with various spacers and various IMs all bets are off till you get on a dyno or have an understanding of how the airflow will acquit itself from experience.
Boxer486 is offline   Reply With Quote
The Following User Says Thank You to Boxer486 For This Useful Post:
Michael Blue (05-28-2014)
Old 05-20-2014, 12:24 AM   #649
akyp
Drives: 2012 86
Originally Posted by JL78 View Post
no clearance issue with TRD tower bar.
Hi, did you remove the sound tube? Been considering this mod for a long time, but seems either the sound tube or the TRD strut bar has to go.
akyp is offline   Reply With Quote
Old 05-27-2014, 06:39 PM   #650
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Remember those Spoon venturi gaskets made for Hondas in the 90s? ...I think/wonder if they really worked...maybe Crawford should've experimented with them and maybe included it in their Billet Power Block designs.
fooddude is offline   Reply With Quote
Old 05-27-2014, 06:41 PM   #651
fooddude
The Following User Says Thank You to fooddude For This Useful Post:
Superhatch (06-09-2014)
Old 05-27-2014, 06:46 PM   #652
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by MrAmalto View Post
I don't know if someone already posted it since this thread is already pretty long, but MotoIQ did a pretty interesting article about the Crawford Billet Power Block
http://www.motoiq.com/MagazineArticl...d-Spacers.aspx
Already posted, it was tested on my car:
http://www.ft86club.com/forums/showp...&postcount=324
-alex
MrAmalto (05-30-2014)
Old 06-06-2014, 09:41 AM   #653
fredfromnh
Have blocks installed but need to load correct flash. Right now low rpm response is less snappy than stge 1 oft stock. On dirt track bikes we would lengthen intake tract to soften throttle response. It's called transitory horsepower. I hope right tune does the trick.
Old 06-09-2014, 05:56 AM   #654
jng
jng's Avatar
Drives: Toyota 86
Any idea what modifications are required to make the BPBs fit RHD vehicles?
jng is offline   Reply With Quote
Old 06-09-2014, 08:11 AM   #655
Clot
Fitted them to my RHD a couple of weeks ago. It's fiddly if you're doing it alone, but no mods required. Read the install threads and watch the Youtube video for some tips.
Clot is offline   Reply With Quote
The Following User Says Thank You to Clot For This Useful Post:
jng (06-09-2014)
Old 06-09-2014, 09:59 AM   #656
jng
jng's Avatar
Drives: Toyota 86
Thanks Clot. I had heard otherwise from some of my local 86 group, for RHD cars.
Old 06-09-2014, 10:38 AM   #657
jng
jng's Avatar
Drives: Toyota 86
One more question, anyone have the BPBs installed with Cusco tower strut (w/ MCB) and Cusco engine braces? Checking if any fitment issues. Thanks.
Old 06-09-2014, 02:33 PM   #658
DAN_BRZ
DAN_BRZ's Avatar
Drives: 2013 WRB BRZ Sport Tech
i have the cusco front bar with brace, no issues.
DAN_BRZ is offline   Reply With Quote
The Following User Says Thank You to DAN_BRZ For This Useful Post:
jng (06-10-2014)
billet, crawford, magic blocks
Crawford Performance Turbo BRZ! Balance Meets Power - Ignition Episode 71 ZetaVI BRZ Photos, Videos, Wallpapers, Gallery Forum 22 04-01-2014 06:19 PM
short blocks? 350matt Engine, Exhaust, Transmission 4 11-04-2013 09:37 PM
Billet Oil Catch Can #BC-175 by Billet Custom Tim_Asphalt_FRS Engine, Exhaust, Transmission 48 10-27-2013 03:29 PM
***Blitz Advance Power Air Cleaner and SUS Power Core Intakes*** FT-86 SpeedFactory Engine, Exhaust, Transmission 1 10-07-2013 10:40 PM
