Old 04-28-2014, 11:57 AM   #295
Tromatic
Originally Posted by regal View Post
The problem with this on is you would have to drive x number of miles with an aggressive vvt tune, pull the cams and mic them. Nobodies going to do that. I can say going from A00C to B01C calibration eliminated the noise under load at 5k rpm. I was convinced the noise was just a resonance but the drastic difference in factory tunes has changed my mind.
How do you change cals? I missed that one! ETA: Assuming a new ECU.
Old 04-28-2014, 04:51 PM   #296
steve99
Drives: FT86
OFT does not allow you to change rom type or upgrade a stock calibration, for that you need to go to dealer or use tactrix/ecuflash
Old 04-28-2014, 05:27 PM   #297
wparsons
wparsons's Avatar
Kinda true... the OTS maps are built off the newest ROM, but tweaked to work like it's stock. So I'm running a 700c ROM (OLD!), but it's based off the A01C ROM (unless it was updated again to a newer one).
flickr
Old 04-28-2014, 06:31 PM   #298
steve99
Drives: FT86
True, but the oft will return you to your original rom cal if you unmarry. and you carnt jump to the new b01c series rom either.
The 700c to a01c was just a couple of parameter changes the b01c is complete structure change for some reason.
Old 04-28-2014, 06:58 PM   #299
wparsons
wparsons's Avatar
Very true, forgot to mention about unmarrying it.
flickr
Old 05-16-2014, 01:53 PM   #300
ML
ML's Avatar
Drives: 13 White MT FR-S
bump
Old 05-16-2014, 08:56 PM   #301
Dezoris
Dezoris's Avatar
Still have to get to the dyno to look at comparisons.
Old 05-16-2014, 08:57 PM   #302
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
I have the OFH, OFT stage 2 with the q300 which is a very quiet exhaust system. I hardly ever hear it.. go stage 2 if you hate the sound
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 05-17-2014, 03:01 PM   #303
regal
Drives: Scion FR-S/Toyota Yaris
I used Tatrix, ECUFLASH, and TD-D's rom&dev posts. I held my breath thru the flash but it went well and going from the original calib to the 2014 is like night and day. I almost feel comfortable reving this engine now, they (OEM's) had to have done some behind the scenes improvements.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 05-17-2014, 03:17 PM   #304
Tromatic
I'll need ECUFlash and the Open Port, correct? Can you provide a link to the ROM's?
Old 05-17-2014, 03:19 PM   #305
steve99
Drives: FT86
I added ROMs (well B01C and A01G) at end of the Tactrix info post
http://www.ft86club.com/forums/showthread.php?t=62332
Old 05-17-2014, 03:20 PM   #306
steve99
Drives: FT86
by the way the "official" version of ECUFLASH is out on the tactrix web site I have updated Tactrix info post above
Old 05-17-2014, 03:30 PM   #307
regal
yea you have to install the official ecuflash first , update your openport stuff, then install the beta over top. All in all it took me about 6 hrs to figure it out, less time than I have spent haggling with the dealer.
Th VVT noise is gone, but understand I went from the very first 2012 calib which we all know was junk.
Mods:
Old 05-17-2014, 03:50 PM   #308
Tromatic
Sanity check, then. If I use the ECUFlash to flash the latest B01C ROM, I can still use the OFT as well, correct? I'd zero the OFT and read the B01C from the car. IIRC, though, the ECUFlash will do just about any ROM, and is NOT idiot (moslty) proof.
Am I close?
Variable Valve "Butterfly" Exhaust dlux Southern California 19 02-22-2016 06:21 PM
First tank OFT E85 tuning. Noise? Tromatic Software Tuning 2 02-20-2014 05:43 PM
Exhaust Cut Off Valve beagoodruslan Engine, Exhaust, Transmission 2 01-01-2014 01:47 AM
Exhaust Noise that goes away after warmed up FastLane1000 Engine, Exhaust, Transmission 10 08-15-2013 10:06 PM
Knock/valve slap/crick noise under accel yomny Issues | Warranty | Recalls / TSB 47 01-07-2013 08:53 PM
