View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 05-09-2014, 05:02 PM   #4047
PollosHermanos
PollosHermanos's Avatar
Drives: 2014 SWP BRZ Limited 6SP
I'm tempting fate here but I'm at 4500 miles and no crickets except for ONCE after I filled up at a station I'd only been to once. And even then I only heard them once when I was in the garage at work.
I'm guessing they will be back eventually but for now I'm going to enjoy the sound of silence.
1990 Laser RS - Lights go up, lights go down ||1992 MX-6 Coupe - Hah ... no || 2001 Integra GSR - Almost rice. Risotto || 2003 IS300 - A nice car but no fun. || 2011 Stage I GTI - Lots of fun. Would buy another
2014 BRZ - That BRZ. So hot right now.
PollosHermanos is offline   Reply With Quote
Old 05-09-2014, 07:57 PM   #4048
Zero90
Zero90's Avatar
Drives: "14 BRZ Limited - SWP
Got my pump changed this morning. Waiting it out to see if they return, probablt will, haha.
Zero90 is offline   Reply With Quote
Old 05-13-2014, 04:05 AM   #4049
Autocon
Autocon's Avatar
Drives: 2014 Whiteout FRS
Crickets started happening in my FRS this weekend, just shy of 5k miles. I am super sad as it makes my nice car sound like a piece of shit when not moving.
Autocon is offline   Reply With Quote
Old 05-13-2014, 08:27 AM   #4050
vgi
Drives: frs
Subu/toyo just needs to add and sound of rain/water running down, birds sinning, wind in the leaves, etc and advertise it as a car for mental disorders.
vgi is offline   Reply With Quote
Old 05-13-2014, 09:51 AM   #4051
Bluetib
Subaru product specialist
Bluetib's Avatar
Drives: BRZ Sportech
Fixed with the new version
Bluetib is offline   Reply With Quote
Old 05-13-2014, 10:00 AM   #4052
SGT_slap_a_hoe
Mine is still occurring after pump replacement, any tips on how to make it stop? Or tone it down?
SGT_slap_a_hoe is offline   Reply With Quote
Old 05-13-2014, 10:08 AM   #4053
HunterGreene
Hail Magnet
HunterGreene's Avatar
Just wait....
It has priests in it?
The Following 2 Users Say Thank You to HunterGreene For This Useful Post:
mwjcyber (05-18-2014), Vis101 (05-13-2014)
Old 05-13-2014, 03:07 PM   #4054
twag4
Drives: frs
I'm adding 2oz of Lucas semi synthetic low ash 2-cycle oil to every tank full of gas, and it solves the problem. I got a gallon jug at o'relly auto parts for $24. 128oz in a gallon means 64 fill ups. About 300 miles on the average tank of gas for me means that one gallon jug will cover 19,200 miles of cricket free driving. It sounded quiet nearly instantly after adding it the first time. I don't mind $24 for cricket free 19,200 mi of driving.
twag4 is offline   Reply With Quote
Old 05-13-2014, 03:19 PM   #4055
Vis101
Vis101's Avatar
Drives: 2013 Limited BRZ
@twag4, what made you choose to add that oil and how do you add it?
Sent from my HTCONE using Tapatalk
Vis101 is offline   Reply With Quote
Old 05-13-2014, 03:57 PM   #4056
HunterGreene
Hail Magnet
There's a post much earlier in this thread (forgive me for not going to dig it out) that says a capful (which works out to approximately a 1:1000 mix) of ash-free two-cycle oil is all you need. I would suggest scaling back and seeing what the minimum you can get away with is.
Old 05-13-2014, 05:33 PM   #4057
twag4
Drives: frs
2 oz is less than 500:1. It's fine. I've been using it for a long time in a catted motorcycle engine at around 500:1 with no ill effects. The usage I described on an 11 gallon fill up translates to a 704:1 ratio. No worries for me. Plus, high flow cats will definitely not be affected by this ratio. If my stock cat(s) fail, this is the route I'd go anyway. Replace with high flow. I finally decided to try it. I'm on my 4th tank using the 2-cycle oil, and the car seems to be running better than ever.
The Following User Says Thank You to twag4 For This Useful Post:
HunterGreene (05-13-2014)
Old 05-13-2014, 05:44 PM   #4058
twag4
Drives: frs
I've used it for many years in lawn equipment and two-stroke motocross bikes. I had part of a jug lying around, and tried it. It eliminated the chirps by the time I got to the next red light a block away. I got a two oz mixing syringe at wal mart. It was located in the automotive department with the gas cans. The oz measurements aren't in black, they are moulded into the plastic syringe. I fill it at the house, plug the little clear hose that comes with it, then off to fill up the tank. The hose with the syringe is stored inside attached to the plunger when you buy it. I leave the hose on, and plug it with a small rubber stopper. Plus, the oil is low ash. The old containers specified tcw3 or whatever. Now it simply says low ash on the bottle. I also like Lucas products.
Old 05-13-2014, 06:16 PM   #4059
hattrickey
Drives: Scion FR-S
Are there any negative effects to doing this at every full up?
hattrickey is offline   Reply With Quote
Old 05-13-2014, 06:38 PM   #4060
twag4
Drives: frs
I can't imagine what they might be. It is such a small amount that I can't imagine it clogging the cats or leaning out the mixture. I can't smell it in the exhaust.
hattrickey (05-13-2014)
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 10:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 02:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 11:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 04:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 01:00 PM
