Old 04-23-2014, 11:26 PM   #71
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
@SP86
Here is some more pics, had a little less meat on the wheels when these pics were taken. Getting some new tires in the rear (245/45 RE-11 rear and have 225/45 A048 front) will post how it looks when ever my tax return decides to come in.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 05-07-2014, 12:11 PM   #72
GuerillaRacing
GuerillaRacing's Avatar
Drives: Scion FR-S
NEW UPDATE!
New wheels - Enkei Compe in 16x8" +25 (Matte Gunmetal)
GuerillaRacing is offline   Reply With Quote
Old 05-09-2014, 08:29 PM   #73
Trettiosjuan
Drives: GT86
About 6kg lighter a corner than the stock rim and tyres (18,3-18,7kg). Feels good.
Trettiosjuan is offline   Reply With Quote
Old 05-09-2014, 11:06 PM   #74
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
Originally Posted by Walla Walla View Post
still don't know if i like that bigger sidewall, last year i was on 18 inch wheels... i really preffer the 16' look, but, can't say if it will give a better handling or not...
haha, me too.
Anyway, here's my current setup. Didn't plan on it, but the price of the wheel/tire combo was supa cheap, so I went for it. I like the way it handles too.
xxr something something, 16x8 +20 225/50/16
car sits a little higher today, since it got an alignment
dori. is offline   Reply With Quote
Old 05-10-2014, 12:01 AM   #75
stockysnail
Just the tip
stockysnail's Avatar
Originally Posted by GuerillaRacing View Post
NEW UPDATE!
What sized tires did you put on them? Which suspension and camber are you running?
Old 05-10-2014, 03:22 AM   #76
stockysnail
Just the tip
Originally Posted by CSG David View Post
With the Innovate kit, you will benefit with a 225 tire on a bigger track and 245 tire on a smaller track. For competitive autocross, I'm sure you'll attempt to fit some massive 275s on a 7" width tire or something just to get every ounce of grip possible. The issue is making sure you can get sufficient heat in the tire for your intended application. Even with boost, the 245 tire may not get sufficient heat for optimal grip. In this case, I would generally recommend a 245/40/17 tire, however, based on your setup, I see that a 225 is an okay tire to run. Running less, however, you're just limiting your grip potential. For best acceleration, Mickey Thompsons on 16s would be great right?
If you can, run a 17x8 +42 TWS T66-F with a 225/45/17 or a 17x9 +35 Wedsport TC105N with 245/40/17 tires. Both setups are fine and fairly dependent on application and desires. Tire selection on 17s is much greater. Everybody has preference, but I recommend RE11A for DD cars and RS3s for track setup. NT01, RC1, or RA1 are great tires if you like running with R-comps. With a grippier tire, you don't need to run as wide of a tire, however, having a fat sidewall also means slightly less response.
What about 245/45R16 on 16x8 et25 20lbs Enkei Compe wheel wrapped in Bridgestone RE-11. It would poke just a teenie bit.
OR
245/40R17 on 17x8 et35 Kosei K4R 15.8lbs wheel wrapped in Bridgestone RE-11a?
Neither seem like they would rub stock suspension lowered .8" with -1.1 camber. since the offset is further from the car. I run on small tracks and autox and daily drive so according to what you mentioned earlier wider would be better in that case.
Old 05-12-2014, 02:16 PM   #77
GuerillaRacing
Drives: Scion FR-S
I am on 225/50/16 Bridgestone Potenza RE760 tires with Megan Racing Track Series coilovers with around 2 degrees of camber all around.
Old 05-12-2014, 03:57 PM   #78
stockysnail
Just the tip
What differences in cornering and ride are you noticing with that tire size compared to others you driven (please provide those other sizes if you have examples). Thanks for answering my questions.
Old 05-12-2014, 04:03 PM   #79
GuerillaRacing
Drives: Scion FR-S
We were on 235/40/18 before and it is noticeably more comfortable to drive on this setup. Also, I can sort of feel the wider footprint since these wheels have a lower offset and stick out further than the 18" I had before. I mostly went with the 16" setup not only because I love the way it looks, but also because this is a daily driven car on terrible roads in Denver, CO, so the taller sidewall makes it a bit more bearable on the track suspension (more cushion for the pushin!)
Old 05-12-2014, 05:05 PM   #80
stockysnail
Just the tip
I was thinking of doing 245/45/16 on those wheels. Should fit even on stock suspension since the offset is 25. There's really only one non-track tire that is made in that size however and that's the Bridgestone RE-11 which was what I'm going to buy anyway as that's what I'm currently running already (in 225/40R18). I also guess 245s would fit on the 8" wide wheel.
Old 05-19-2014, 12:19 AM   #81
FRSdrive
FRSdrive's Avatar
Drives: 2013 FRS, 1985 Corolla GTS (AE86)
16x9.5 +0 / 16x8.5 +0
FRSdrive is offline   Reply With Quote
Old 05-19-2014, 10:35 AM   #82
pmanliu
Drives: Lexus IS
The FT86 looks awesome with meaty tires...
pmanliu is offline   Reply With Quote
Old 05-19-2014, 02:45 PM   #83
Trettiosjuan
Drives: GT86
If those are meaty, anybody appreciate these?
Old 05-19-2014, 08:11 PM   #84
AllStar0419
AllStar0419's Avatar
Drives: 2013 FR-S Asphalt
My winter setup: 16" Enkei EDR9. Not a great pic but the only one I have. Currently running stocks plasti dipped bronze.
Sent from my SCH-I545 using Tapatalk
AllStar0419 is offline   Reply With Quote
Wheel Directory: Styluz S006 18x7.5 +40 Pavel Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 01-22-2014 04:16 PM
FS [SYD] 16 inch GT wheels and tires! luv85 Australia Classifieds 3 11-04-2012 06:15 AM
Help! Two 10 inch vs One 10 (or 12) inch cyntage Electronics | Audio | NAV | Infotainment 7 09-27-2012 11:20 PM
I need 19 inch wheels today! benqld7 AUSTRALIA 16 08-07-2012 08:33 AM
16 inch wheels for the base model!!! Blokatos Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-07-2011 11:17 AM
