Old 05-12-2014, 01:20 PM   #43
mikko86
Drives: Scion
mikko86 is offline   Reply With Quote
Old 05-12-2014, 01:32 PM   #44
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
WOW! Did somebody really just compare the FRS to the LFA or am I high on crystal meth?
MokSpeed is offline   Reply With Quote
The Following User Says Thank You to MokSpeed For This Useful Post:
Zaku (05-12-2014)
Old 05-12-2014, 01:34 PM   #45
suaveflooder
suaveflooder is offline   Reply With Quote
Old 05-12-2014, 01:34 PM   #46
maxeveland
maxeveland's Avatar
Drives: n/a
Anyone know if the "black seats" are like the alcantara ones? I have seen only 1 picture which only shows the sides of the seats and it does look like some kind of suede material.
maxeveland is offline   Reply With Quote
Old 05-12-2014, 01:50 PM   #47
Chaetagnath
Drives: Whiteout FRS
Probably both.
Chaetagnath is offline   Reply With Quote
The Following User Says Thank You to Chaetagnath For This Useful Post:
suaveflooder (05-12-2014)
Old 05-12-2014, 01:57 PM   #48
suaveflooder
Originally Posted by Chaetagnath View Post
Probably both.
I'm gonna vote crystal meth
Old 05-12-2014, 02:16 PM   #49
NemesisPrime909
NemesisPrime909's Avatar
Drives: 91 Toyota Supra 16 Nissan Versa
from what i've seen, the seats are fabric with the toyota "t" pattern instead of the red inserts.
The FRS/BRZ was not meant to be a world beating car, it was not meant to be an extremely fast car, nor a powerful car, but a well balanced fun car.
NemesisPrime909 is offline   Reply With Quote
Old 05-12-2014, 02:57 PM   #50
Dezoris
Dezoris's Avatar
I don't think a lot of people understand what "special editions" and all that BS is.
It's a way to clear out inventory on parts manufacturers are losing money on from over ordering from suppliers.
They then market it as "special or limited" mark it up and people go nuts for it.
I get that some of it is a bargain, but there is nothing special about it.
The Following User Says Thank You to Dezoris For This Useful Post:
Old 05-12-2014, 03:07 PM   #51
NemesisPrime909
Originally Posted by suaveflooder View Post
I guess the best way of answering your question is explaining what I've learned working on my cobra setting it up for tracking. Sorry about the pics, they are a picture of a picture, but I used what I could
Think of aero in terms of low pressure and high pressure on the car. Here is what I think is a TRD body kit. I marked the pressure with red being the high pressure and green being low pressure.
Here's why the griffon works
The canards create the downforce for the front and the wing sits right in the high pressure area coming off the roof. You now have a low pressure spot UNDER the car, pushing the car down (good thing).
I WANT THAT HOOD as it is a true heat extractor hood and creates a low presseure area behind the radiator, literally sucking the hot air from the engine and pulling air from the radiator (which faces slightly upward) They used aero to their advantage to cool the car.
If you think about the car in terms of low pressure and high pressure areas, you can answer your own question on whether or not the 1.0 series is fuctional. Of course any aero is going to do something, but in the 1.0 series and the TRD kit, not much.
All the stuff coming out of these cars DID have a racing start, but MOST of the front lips people are putting on these cars aren't functional. They look cool, but they aren't doing what they are supposed to. IMHO function over form. I'll take something that ACTUALLY WORKS over something that looks cool.
It's the reason why I went with a wing that was taped on….so I could bolt on a fuctional wing in the future and pull the stillen wing off. I also plan on putting on a fuctional lip, which looks like it's about to come out by one of our forum venders. Stoked!
I hope all that makes sense.
I does make sense. However looking at your diagrams both the TRD kit and the Griffon improve air flow, just the griffon does it better.
Infact, let's compare some more.
Here's the JDM TRD kit.
And here's the USDM TRD kit.
now, looking at the two. You're right about them being more or less the same. However, I think it could be argued that the USDM kit may be just a bit better based on a few factors.
1. No front license plate holder to block and/or disrupt airflow
2. A broader wing at the back that conforms to the natural shape of the rear.
It's no doubt that the Griffon is the better car. But as we know the areo on that car is,
1. Still in development.
2. Going to be balls to the wall expensive when and if it is released to the public.
3. It's also a widebody kit. And I can't think of any car that was sold in the us with a widebody kit from the factory.
So it would make sense for TRD to release a slightly improved version of the JDM kit rather than sky-jacking the price of the car by adding the Griffon's super-functional aero.
I mean this isn't new for TRD
Remember the hardcore MR2 and Supra?
I'm sure the 86 will be no different.
So to reiterate, the aero looks to be slightly more functional than the JDM kit. so i wouldn't write it off completely just yet. It still has to be tested.
I mean would you rather have the Nur kit instead?
it was tested, and it was used in the development of the standard car. so we know it works (even though that wing is still uglier than sin).
The Following User Says Thank You to NemesisPrime909 For This Useful Post:
Zaku (05-12-2014)
Old 05-12-2014, 03:10 PM   #52
Wilsonk227
Wilsonk227's Avatar
Drives: Super Vehicular Terrain Vehicle
Originally Posted by NemesisPrime909 View Post
I'm no troll
-I saw that you were writing the 1.0 off because of it's bodykit.
-I told you it's fine that you don't like it, just don't piss on other people who like it.
-You continued on, saying that the "useless bodykit" adds weight
-I told you that a lot of things add weight, and getting all bent out of shape just because less than 100lbs (arguably less than 50lbs) was added is basically pointless
-You then go on to complain about Toyota's support for the FR-S/86. You say it has been a joke, and they ultimately failed. You praised the aftermarket for stepping up.
-I point out that TRD support for the FR-S/86 has been great, citing the Griffon car as evidence of their developments.
-You call me a troll, and say the Griffon apparently doesn't count because it's has a gutted interior and functional aerodynamics.
We were(are?) debating. I came into thins knowing I would never convince you to like it. I was merely discussing the topic. I never once insulted you. I merely disagreed.
If you would like to continue I'll point this out.
True the Griffon has Aero, and a gutted interior, but it's still a TRD vehicle. And I think it's credible evidence that TRD supports and is developing for the FR-S/86, therefore negating your claim that TRD is a "Joke."
Just because the RS 1.0 isn't a factory-built track monster doesn't mean it's pointless. I pointed it out earlier that some people don't go to track days, or care about going faster. Some just like cruising.
also it occurred to me,
How do we know the aero isn't functional? I can't find any records of a wind tunnel test.
so in reality, that claim is unproven until some tests can be done.
I think that other guy just needs to remove his bumpers and passenger seats to save more weight. Cus you know, racecar
ig: @MrWiils0n
Wilsonk227 is offline   Reply With Quote
The Following 2 Users Say Thank You to Wilsonk227 For This Useful Post:
Quentin (05-12-2014), Zaku (05-12-2014)
Old 05-12-2014, 03:17 PM   #53
NemesisPrime909
Toyota sould've sent a small number of these to the states or at least let them be custom orders.
for those people who want to shed all weight
Old 05-12-2014, 03:48 PM   #54
Wilsonk227
Wilsonk227's Avatar
lol im sure those would sell pretty well too! i mean there's no "pretty parts" on it
ig: @MrWiils0n
Old 05-12-2014, 04:03 PM   #55
NemesisPrime909
I genuinely think it was a missed opportunity on their part.
but then again Japan keeping the good stuff for themselves isn't anything new.
The Following 2 Users Say Thank You to NemesisPrime909 For This Useful Post:
Wilsonk227 (05-12-2014), Zaku (05-12-2014)
Old 05-12-2014, 04:07 PM   #56
Wilsonk227
Wilsonk227's Avatar
i agree, a lot more people who want the car for tracking and etc can get it for WAY cheaper. Would've been a nice edition to have. Just as nice as the RS 1.0. I think the people who are bashing on the RS 1.0 is forgetting a couple of things. Business and more choices for consumers. I love the fact that if I wanted an FRS or BRZ, i could easily choose from 4 different kinds. Regular FRS, Monogram FRS, RS 1.0 or a limited BRZ. How great is that ?
ig: @MrWiils0n
Fly Guy (05-13-2014), Zaku (05-12-2014)
Press Release: NEW FDA9 Series Shark Fin Antenna for Subaru BRZ and Scion FR-S Beat-Sonic Announcements, Contests, Giveaways 20 06-26-2014 04:37 AM
Pictures of Scion FR-S Release Series 1.0 from Toyota Grand Prix of Long Beach mav1178 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 19 04-20-2014 01:03 AM
Scion FR-S Release Series 1.0 CSOCSO Scion FR-S / Toyota 86 GT86 General Forum 26 04-16-2014 08:16 PM
Release Series rL-gT Scion FR-S / Toyota 86 GT86 General Forum 55 01-18-2012 03:02 PM
