Old 05-09-2014, 06:06 PM   #211
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
Since day 1, it has been difficult to get into 2nd when cold, grinds 3rd slightly, and grinds 4th above 5-6K RPM every time, even when warm. This is not speed/power shifting, I don't do that, just during normal operation. So, Mark Miller Midtown is replacing the transmission for me. They're also putting Motul 300 in the tranny and diff while they're at it. I supplied the upgraded oil. Their service department has been absolutely outstanding. When I reported the transmission issue, they got me right in and the service manager went for a ride with me and confirmed the problem. Within 30 minutes, he had contacted SOA and had my transmission on order. Unfortunately, an exhaust bolt broke during the transmission replacement and had to be ordered. Otherwise I would've had the car back in 1 day.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
The Following User Says Thank You to zdr93523 For This Useful Post:
ichitaka05 (05-09-2014)
Old 05-09-2014, 06:42 PM   #212
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Hm... That's too bad. At least Mark Miller is taking care of you. I might have issue w 2nd gear... but it's not 100% sure. I'll drive it bit more & check it up w Mark Miller Southtowne
Old 05-09-2014, 06:48 PM   #213
zdr93523
zdr93523's Avatar
I really believe that the issues are caused by the GL-3 that Subaru uses. The other car manufacturers that use this Aisin tranny use GL-5 fluid and are not known to have issues. Makes you wonder.
www.makesmodels.com
www.camautomag.com
Old 05-09-2014, 06:54 PM   #214
ichitaka05
Site Moderator
ichitaka05's Avatar
Hm... Good info. Let me ask few expert on this issue & see that they say
Old 05-09-2014, 06:58 PM   #215
zdr93523
zdr93523's Avatar
Let me know what you find out. There are plenty of posts about the grinding but no good solutions so far. It shouldn't be a parts issue since the parts are common with other cars. The only difference that I could find is the fluid used.
www.makesmodels.com
www.camautomag.com
Old 05-09-2014, 07:01 PM   #216
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
Does the IS250 use the GL-5 tranny?
Fett4Real is offline   Reply With Quote
Old 05-09-2014, 07:03 PM   #217
zdr93523
zdr93523's Avatar
Yes, the IS350 uses GL-5, I'd assume the 250 does too.
www.makesmodels.com
www.camautomag.com
Old 05-09-2014, 07:03 PM   #218
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
LEXUS TSB CAUTION:
Using manual transmission gear oil other than API GL-5 may cause occurrence of gear noise
and damage to the transmission.
Old 05-09-2014, 07:05 PM   #219
zdr93523
zdr93523's Avatar
LEXUS TSB CAUTION:
And Subaru has a sign on the service counter that says, "All fluid is not created equal" and yet they refuse to fill with Subaru Extra-S (which is awesome GL-5 gear oil) from the factory, or stock it at the 99% of dealerships.
www.makesmodels.com
www.camautomag.com
Old 05-09-2014, 07:12 PM   #220
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Well its weird that toyota would put GL-3 in the 86 and say in a TSB for the same tranny GL-5 in a CAUTION...seems like a tech data violation to me
Old 05-09-2014, 07:28 PM   #221
zdr93523
zdr93523's Avatar
Sounds like it to me too. I could get into a rant about execs wanting to save the $80 per car on the fluid and being so short sighted to not see the $5000 tranny replacements as a result of the desire to make a quick buck... But I won't.
Sent from my LG-D800 using Tapatalk
www.makesmodels.com
www.camautomag.com
Old 05-10-2014, 10:55 AM   #222
ichitaka05
Site Moderator
ichitaka05's Avatar
Good info. Well, I better look into Subaru Extra S gear oil
Better be safe than sorry
Old 05-10-2014, 07:01 PM   #223
enivid
enivid's Avatar
Drives: WRB JR BRZED
You were right toby, they were over inflated by 10psi.
enivid is offline   Reply With Quote
Old 05-10-2014, 07:24 PM   #224
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Sat what? You know after driving on em they'll go up in pressure.
Sent from my SCH-I545 using Tapatalk
southwest, utah
Ecutek in Utah? Batman Southwest 1 03-26-2013 10:37 PM
Utah. Wolfe Southwest 4 02-22-2013 05:18 AM
Opticoat in So. Utah Drofnum Southwest 1 02-20-2013 01:53 AM
BRZ available in Utah next week! helloimgil BRZ First-Gen (2012+) — General Topics 0 06-09-2012 12:58 PM
Does anyone want my preorder? I have ETA (Utah) 12STI BRZ First-Gen (2012+) — General Topics 5 05-13-2012 12:51 PM
