Old 06-05-2013, 06:52 PM   #85
DJCarbine
Thupercharged
DJCarbine's Avatar
Originally Posted by Dezoris View Post
Waiting for Perrin to get back to me on this but been having this odd issue with power cut after a 1st gear to second gear shift. Per this log.
After careful second gear shift, foot back on throttle then sudden power cut, for a millisecond, power comes back but weaker then knock at the higher end per log.
I have the same issue randomly as well. During a shift while in boost, the timing gets pulled and I notice a split second decrease in power along with an exhaust note change that sounds like really retarded ignition (only lasts less than half a second), I always thought it was just the normal transition from boost to vacuum to instant boost again, I figured it was just tip-in spark retard to prevent detonation.... maybe one of the tuners can chime in
If I shift and feather the throttle to roll into boost more smoothly, the ignition retard does not happen.
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 06-05-2013, 11:15 PM   #86
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
I've had this same issue on my completely stock engine with just a drop in filter. I don't think it's a vortech or tune issue. I hadn't seen any mention of someone else experiencing it until now.
I will say it became more pronounced for me when I put an exhaust on the car. But I have since removed it and the issue has lessened.
When I shift gears foot on the gas again I get a slight hesitation (you could hear the exhaust not change when I hate the exhaust installed) then all is well.
NotSoJDM is offline   Reply With Quote
Old 06-06-2013, 12:45 AM   #87
Dezoris
Dezoris's Avatar
Well I am glad to know its not just my car but it happens to me a lot and the fact I got it on a log and also a knock correction after makes me uncomfortable.
I heard back from Chris at Perrin saying they cannot correct it in a tune.
The guy I used for dyno work said it may be built into the throttle mapping to protect against drive train shock.
But I would prefer an answer obviously, of why it can't be fixed and the real reason for it.
Old 06-07-2013, 01:14 AM   #88
Dezoris
Dezoris's Avatar
How much knock correction is normal in your logs. Do you guys see it often randomly and what RPMs?
Old 06-07-2013, 07:33 AM   #89
Foobar
SLO NO MO
Foobar's Avatar
Which column on the ECUTek log shows that? I saw two columns relating to knock and it looks like they were all zeroed out in my last log. I have to make a new log this weekend so I'll check again.
Sent from my Nexus 4 using Tapatalk 2
Old 06-07-2013, 11:39 AM   #90
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
In a perfect world and a perfectly happy motor, both the Knock Correction and Knock Learn Value would be 0 at all times. The more random the knock is the more likely it is phantom knock and not real knock. My Knock Learn Value is almost always zero, and I normally only get some Knock Correction at throttle tip in. The thing you really have to worry about is if you have a negative Knock Learn Value and are seeing constant Knock Correction with full throttle and under boost. That means the ECU is consistently seeing knock in that area and is trying to do the best it can to correct it. The Knock Learn Value is more like a long term knock correction where the ECU says I have seen knock here before so I will pull timing even if I don't see knock where the Knock Correction is I see knock right now I am going to pull timing.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
Cal3000 (05-08-2014), Foobar (06-07-2013)
Old 06-07-2013, 06:43 PM   #91
Dezoris
Dezoris's Avatar
Thanks for that info. I am going through logs trying to establish what the "normal" conditions are for the operation. Everyone I talk to with the Vortech kit all say just go out and beat on it. I am not that type of person until I know where everything is at and where it should be and why.
Old 06-09-2013, 02:19 PM   #92
ft86me
ft86me's Avatar
Drives: 2013 FRS
does anyone have solutions to safely make more hp on 91 with the vortech? smaller pulley?
did find an e85 flex fuel place by my house so maybe i'll go that route, but if i run out of gas and that place isn't near by. trouble haha.
would like to get close to 300 as much as possible.
ft86me is offline   Reply With Quote
Old 04-11-2014, 04:06 AM   #93
zenny
Drives: brz 2013
can someone link me to the how to for swapping the pulley out on this so i can put my new one on or instruct me on how to do it ive been searching
zenny is offline   Reply With Quote
Old 05-07-2014, 12:44 PM   #94
diirk
diirk's Avatar
Drives: 4Runner
Add me to the list of Vortech owners. Here's my build thread. http://www.ft86club.com/forums/showthread.php?t=20326
2013 SWP BRZ Premium
Pinnacle Tint
ISC Coil-Overs
StopTech Brake Pads
Rota Titans 17x9 +42
Ventus V12 245/40-17
TopSpeed Cat-back Exhaust
Vortech Complete System
OEM Mud Flaps
Bluebatmobile Reverse Light Overlay
Spyder 2 Tail lights
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Old 05-09-2014, 04:28 PM   #95
reyruiz191
reyruiz191's Avatar
Drives: 2013 FRS Vortech Supercharged
Pinnacle Tint
ISC Coil-Overs
StopTech Brake Pads
OEM Mud Flaps
Updated
If anyone wants to update their info or get added let me know.
reyruiz191 is offline   Reply With Quote
Old 05-09-2014, 04:51 PM   #96
jamesm
This is not correct. If knock correction learn value is zero, you likely have big problems . The parameter you're thinking of is 'ignition correction - fine' which is the value being applied from fine learning. Knock correction learn value is the currently applied advance value.
Old 05-10-2014, 12:26 AM   #97
King Tut
NASA SpecE30 Racer
King Tut's Avatar
My experience was from Visconti and FA20Club tunes, and I don't remember ever seeing a positive value for Knock Correction Learn Value. I was referencing seeing negative values for that which would mean the advance value is negative and it is pulling timing from seeing prior knock. I don't know what the advance tables looked like in my tunes though.
Old 05-10-2014, 01:21 AM   #98
jamesm
Basically KCLV is (IAM * <current advance value from the table>) - (corrections + compensations). So if you were seeing 0 constantly that would indicate either zero values in the advance map, a zero AM, or significant and constant correction. The corrections can push the value negative even after it's bottomed out the advance map. No bueno.
STX Rules and Setup Questions Scooby South Tracking / Autocross / HPDE / Drifting 3914 07-18-2023 05:16 AM
Questions and Discussion on Vortech Supercharging Systems Brian@Vortech Forced Induction 1462 01-27-2017 03:05 PM
Vortech Offical Owner Thread cjsporl1996 Forced Induction 2 03-27-2014 01:50 AM
Who to tune Vortech setup? pheoxs Forced Induction 18 02-20-2014 03:58 AM
Sprintex or Vortech, which setup has more potential? Turbowned Forced Induction 328 09-14-2013 12:09 PM
