Old 05-02-2014, 02:08 PM   #141
Scottemad123
Drives: 2014 SWP BRZ Limited
Curious to see it and how it feels in person!
Scottemad123 is offline   Reply With Quote
Old 05-04-2014, 09:49 PM   #142
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
All set for install tomorrow! An extra special thanks to @Extreme86 for lending his garage, tools, and hands for tomorrow's work!
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 05-06-2014, 01:00 AM   #143
Turkish
Serial Cone Killer
Turkish's Avatar
Bilstein B8 w/ RCE Tarmac springs install: The Good, The Bad, and The Ugly
So today I, with the invaluable help from @Extreme86, installed my new suspension. As of right now (2-3 hours since car was dropped from jack stands), I have dropped 0.4" in the front and 0.6" in the rear and the car seems to be even more on rails with the stock rubber, the Primacy HP tires really don't seem as bad as they were with the stock suspension.
The good is the suspension is now installed and the car is stiffer without being too harsh. This actually feels a lot closer to what I anticipated the car feeling like before I had test driven it at the dealer.
The bad, due to user error with the torque wrench I sheered two studs off the front left strut. This resulted in an unplanned trip to Lowe's where a M8x30 bolt and lock washer were purchased to replace the studs. They actually seem to be stronger than the studs. FYI, you are supposed to torque the nuts on the studs to 17 ft-lbs and I accidentally torqued to 18 and it sheered off two studs..
Finally the ugly, a "2 hour" install which I expected to take 6 hours ended up taking 9 hours (with a dinner break included).
Verdict: I would do this again in a heartbeat. I need to get an alignment done to ensure toe is within spec, but even before that I am super impressed with the effect on handling. With stock rubber and full nannies, the vsc is engaging far less than it did before.
... his name is...
C'THULHU
Old 05-06-2014, 08:28 PM   #144
Si_Chris
Drives: 2016 ISM BRZ Limited, 2000 Civic SI
Originally Posted by Turkish View Post
Are your front springs upside down? Typically the progressive rate coils should be at the top no?
Si_Chris is offline   Reply With Quote
Old 05-06-2014, 08:52 PM   #145
Turkish
Serial Cone Killer
Turkish's Avatar
Fronts have the progressive coils on the bottom and the rears have them on the top. Odd yes, but it works I guess. I'll double check when I get home, I guess it would fit with how the install for the fronts went if they're upside down.
... his name is...
C'THULHU
Old 05-06-2014, 10:27 PM   #146
Turkish
Serial Cone Killer
Turkish's Avatar
I followed the guide by @DarrenDriven http://www.ft86club.com/forums/showt...t=10842&page=7 and that has the springs with the progressive coils on the bottom in front.
... his name is...
C'THULHU
Old 05-08-2014, 03:50 PM   #147
Turkish
Serial Cone Killer
Turkish's Avatar
Looks like I won't really be needing rear camber adjustment just yet, this is on the upper limit of the negative camber I was looking for. (-1.5 to -2.0)
... his name is...
C'THULHU
Old 05-09-2014, 01:07 PM   #148
FrSnake
Resident Noob
FrSnake's Avatar
Drives: Satin White BRZ Limited
Looks great! WRB will forever haunt my dreams for not waiting for one to come in.. But hey SWP is pretty awesome too. But i was curious to know where you got your replica oem diffuser. I can't justify the price of the actual oem one..
USAF2013 SWP BRZ Limited- CAI, Borla Cat-Back Exhaust
“Speed has never killed anyone, suddenly becoming stationary… That’s what gets you.” -Jeremy Clarkson
FrSnake is offline   Reply With Quote
Old 05-09-2014, 03:23 PM   #149
Turkish
Serial Cone Killer
Turkish's Avatar
I believe @MysteryMachine was the one who originally purchased it, and then it passed hands a couple times here in Austin before I painted it and installed it on mine. I scraped the crap out of it last evening pulling out of an awkward driveway downtown, the joys of a lowered suspension!
... his name is...
C'THULHU
Old 05-09-2014, 03:28 PM   #150
Scottemad123
Still awaiting pictures showing the drop from the outside! I need to know if it is *too low for me
Old 05-09-2014, 03:28 PM   #151
Turkish
Serial Cone Killer
Turkish's Avatar
I drove Lime Creek Rd (A very fun, albeit short twisty road here in Austin) today, and the new suspension was AWESOME! The car is very planted to the ground in the sharp turns by the lake. As I had mentioned in the "What did you do with your BRZ today" thread, it felt like the first time you had sex with your new girlfriend. I am currently using OE wheels and tires (yes, the Primacy HP ones everyone hates) and the car had a TON more grip in the corners. I am still peeling out even when driving like Miss Daisy, that hasn't changed. It is amazing what a couple degrees of rear camber can do for you.
... his name is...
C'THULHU
Old 05-09-2014, 03:29 PM   #152
Turkish
Serial Cone Killer
Turkish's Avatar
I'll go take some cell phone pics next time I am out (which should be not too long from now).
... his name is...
C'THULHU
Old 05-09-2014, 04:25 PM   #153
MysteryMachine
MysteryMachine's Avatar
Drives: 2014 SWP BRZ, 2002 Bugeye OBS
Actually it was Trevor's, he offered it to me since I had given him my e-brake boot when I swapped it to leather, but the diffuser didn't fit the look I wanted for my car so Trevor gave it to the next person that wanted it and was part of the group in Austin. You were the lucky next person
MysteryMachine is offline   Reply With Quote
Old 05-10-2014, 01:29 AM   #154
Turkish
Serial Cone Killer
Turkish's Avatar
@Scottemad123 I apologize, as soon as I saw the perfect spot to take pictures the sky opened up with rain, I will attempt tomorrow to get some good pictures with my cell phone.
... his name is...
C'THULHU
Call me OLD!!?? DrDuquette Off-Topic Lounge [WARNING: NO POLITICS] 49 07-23-2012 01:45 AM
GOT THE CALL!!!! Plxdjake89 Scion FR-S / Toyota 86 GT86 General Forum 13 07-20-2012 05:54 PM
I got the call..... 2pt5RS Southeast 23 07-09-2012 08:41 PM
What Will You Call Your 86? phm14 Scion FR-S / Toyota 86 GT86 General Forum 52 06-23-2012 09:36 PM
