Old 05-07-2014, 09:02 AM   #1
Lebby83
Drives: 2019 BRZ, 2016 Touareg
Is this normal - Hot air blowing in through vents?
Not sure if this is normal or not for our cars. When I have the AC/Heat off completely there is a lot of hot air flowing out of the vents, mainly when in motion of course. I have never noticed this on any of my previous and current cars, but this is my first Subaru so I am not sure if this is common.
Any input??
Thanks!
Rob
2019 BRZ Limited Sport
2016 VW Touareg TDI
Lebby83 is offline   Reply With Quote
Old 05-07-2014, 09:14 AM   #2
Pistol
Drives: 86
unfortunately yes
Pistol is offline   Reply With Quote
Old 05-07-2014, 09:25 AM   #3
Lebby83
Awesome. Guess I have to get used to closing the vents while the windows are down and at the track.
Thanks pistol
Rob
2016 VW Touareg TDI
Old 05-07-2014, 09:29 AM   #4
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
I have noticed this in all of my cars, but only when the heater was the last thing that was on. If you put on the AC and then turn off HVAC, it doesn't leak heat.
Prog is offline   Reply With Quote
Old 05-07-2014, 09:37 AM   #5
Lebby83
It has been doing it after the AC has been running. I've only ran the system with the AC on.
Rob
2016 VW Touareg TDI
Old 05-07-2014, 10:23 AM   #6
codesplice
Elite Recognized Geek
codesplice's Avatar
Drives: 2014 DGM BRZ Limited
If you hit the Recirc button before you turn off the AC that should stop the airflow
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+
codesplice is offline   Reply With Quote
Old 05-07-2014, 11:02 AM   #7
00NissanNinja
The Thread Lurker
00NissanNinja's Avatar
Drives: '14 BRZ, '17 GTI, MT09
+1 for turning on the recirc. All cars do this to varying levels, since they always let some amount of outside air into the car for ventilation purposes. Turning recirc on mostly stops outside air from coming through the HVAC system. It's maybe more noticeable in the BRZ due to the design of the cowl and the how close packed the car is.
00NissanNinja is offline   Reply With Quote
Old 05-07-2014, 11:02 AM   #8
BrrrRrrZ
Drives: 2014 BRZ 6MT
I've read this a couple times now. Being from PA we have very similar weather so I'm surprised it'd be so different...
If you turn the dial to "low" and keep it to the first few fan clicks I find its nice, especially on the highway.
I have a sport tech (dual zone) so I'm not sure if maybe there is a difference?
BrrrRrrZ is offline   Reply With Quote
Old 05-07-2014, 11:13 AM   #9
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
yup. just hit the recirc and no mo hot air.
Old 05-07-2014, 12:38 PM   #10
Lebby83
Thanks guys! Will give it a shot.
Rob
2016 VW Touareg TDI
Old 05-07-2014, 12:39 PM   #11
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Yes, recirc button willl close the vent allowing outside air to go in.
Old 05-07-2014, 02:38 PM   #12
qqzj
Drives: MDX, Camry
It is a design flaw on Subaru's part. You can do this. If you feel hot air blowing into cabin, turn on the AC, set temp to 62, then turn off AC. the air will blow cold from now on.
Basically if you want warm air, the car should open a channel for the air to enter heat core and then enter cabin. If you turn AC system off, the car should shut down that channel. Obviously, Subaru engineers forget to do this. So when you turn off AC, they still let that channel to heat core open. This will only happen when you turn on AC but set it to a warm temp in the morning. Then when you drive it during afternoon w/o AC on.
Any input??
Thanks!
qqzj is offline   Reply With Quote
Old 05-07-2014, 03:02 PM   #13
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Still doesn't help in my case. This is my first subie where this has been an issue.
When it was much cooler, no problem. I normally wanted some warmer air anyway even if I wasn't running the heat. Now, though, it gets annoying. Usually I have to run the temp up to just about where ambient is (set HVAC to auto, and roll the temp up till the fans drop to a low fan speed) and hit the A/C and recirc. If I have the windows down, I hit recirc and turn a/c off and drop the temps down. Still end up with way warmer air than what is coming in through the windows.
I think it's b/c our engine bay runs hotter than normal anyway, so wherever the cabin air is being pumped in from fresh (or even near the firewall), is where it gets heated up more than normal.
I bet if one is able to ventilate a good bit of the normal bay heat, the issue will decrease.
^GT5 Replay Photo Mode^
Old 05-07-2014, 03:04 PM   #14
tahdizzle
So elite I'm 1338
If only the fender vents were functional from the factory.....
Want to trade my BRZ fender vents for you FRS fender vents, or buy FRS vents outright ill roller Exterior Parts (Aero, Lighting, Etc.) 6 09-22-2013 10:49 PM
How cold is your a/c blowing? jermyzy Issues | Warranty | Recalls / TSB 68 08-18-2013 03:29 PM
WTB BRZ galaxy blue fender vents or trade w my FRS UM blue side vents BlueLeader Exterior Parts (Aero, Lighting, Etc.) 0 03-18-2013 02:55 PM
Did the issue with the air vents blowing hot ever get resolved? fiveoneoh Scion FR-S / Toyota 86 GT86 General Forum 25 09-05-2012 01:21 AM
A/C Compressor blowing hot? Is this normal? SocalBurt Engine, Exhaust, Transmission 3 08-22-2012 07:10 AM
