#57 |
- Ron Fish / mrfish
- AVO turbo kit, 8 PSI actuator, 3 bar MAP - 91 Octane - 9 PSI (tapers to 7) - Stock fuel, stock clutch, stock everything else - I superimposed some generic stock hp/trq lines on the chart for reference
| The Following 2 Users Say Thank You to mrfish For This Useful Post: | CxG (08-05-2015), Sportsguy83 (05-06-2014) |
#58 |
Drives: 2014 FRS
Automatic transmission
- Force Inducted Kit: AVO 6psi spring - Fuel Type: 93 - Max Boost: 10.5 - Other Mods: exhaust, MBC - Tuner: Moto-East (Moto-mike) - Thread: http://www.ft86club.com/forums/showthread.php?t=66723
| The Following User Says Thank You to onzippy For This Useful Post: | swift996 (05-29-2014) |
#59 |
Life to short to be slow!
Drives: Toyota GT86
Kombatlion
Fiebruz Motorsport Turbo kit 91oct + Methanol 12.96psi 3" Fiebruz Overpipe, Front pipe, ultimate racing exhaust, snow meth kit, tuned by Fiebruz Motorsports 358whp With Meth 280whp 91oct Sent from my SAMSUNG-SM-G900A using Tapatalk
| The Following 3 Users Say Thank You to kombatlion For This Useful Post: |
#60 |
Drives: '13 BRZ
[ame="http://youtu.be/B1Z0-EJvivw"]http://youtu.be/B1Z0-EJvivw[/ame]
Gtx3076r Ultimate racing 3 inch full exhaust Built short block 93 octane Dw265 lph Tuner : sam, 1000 dunes dubai
400+whp
| The Following User Says Thank You to slowmo For This Useful Post: | aagun (04-26-2015) |
#61 |
Drives: 2022 BRZ Limited
-glamcem
-Kraftwerks Supercharger (C30-94 )-Tuned by Moto-East - @moto-mike -92 octane (Chevron) -Standard size pulley- 9.5 psi (read from Ecu) -Perrin 2.5" OP, Invidia 2.5" Catless FP, Tsudo 2.5" Catback -4th gear pulls, 72F degree ambient temps
| The Following 2 Users Say Thank You to glamcem For This Useful Post: | kombatlion (05-30-2014), swift996 (05-29-2014) |
#62 |
Drives: 4-Runner Sport - 13' BRZ SportTech
- Alex / Protpibe
- AVO Turbo Kit - 94 Octane - 10 PSI - Delicious Tune, 3" Perrin Catback, AVO 2.5" Overpipe, Perrin Cold Air Put down just under 270 at the wheels today @ 10psi on 94 octane
Top Tier Imports - Check out my build journal HERE
#63 |
Vortech super charger kit 2.87 pulley
E85 tune ecutek by @Hal@Dynosty P&L Header with cat. custom overpipe Invidia Front pipe with no cat Invidia Q300 catback Perrin crank pulley Dynojet 375whp and 264 wtrq sae correction 1.02 Dyno Dynamics 340 whp sae correction im not sure http://www.ft86club.com/forums/showthread.php?t=52811 version 2.0 coming soon.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
#64 |
Drives: 13 Subaru BRZ
Hi everyone, long time listener, first time caller.
Matt/Ybotspawn - Innovate Stage 2 CARB - 93 Pump Gas - Stock pully 7~psi - Installed by Ptuning
| The Following User Says Thank You to ybotspawn For This Useful Post: | ecko04 (06-12-2014) |
#65 | |
Drives: 2013 raven black fr-s
#66 | |
ok~
#67 |
Drives: 2013 Black FR-S
Kevin S. - sw20kosh
- Ptuning GT3076R kit - 91 oct (green) and 91+torco (red) - 8 and 11 psi - Ptuning 3" exhaust, JDL Header - 4th gear pulls, ~75 degree ambient temps
#68 | |
Drives: 2013 AT Firestorm FRS
#69 |
Drives: Asphalt FRS
Here is another one.
MAPerformance turbo kit with a GTX3076R FIC 770 injectors DW65 fuel pump Prime flex fuel kit Full 3" turbo back exhaust Green line is stock Red line is 11psi 91 Oct Blue line is 17psi E85
| The Following User Says Thank You to MAPerformance For This Useful Post: | charged86 (08-27-2014) |
#70 |
Here's a better shot of mine:
![]() In my own inexperience, I guess I let off the throttle early (7200). I'm going to put it on the dyno again and run it to redline
| Dyno numbers list from Evasive Motorsports Meet/Dyno | Fish | Southern California | 29 | 02-24-2013 04:16 AM |
| Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 08:00 PM |
| Bolt-ons dyno comparisons thread? | seven | Engine, Exhaust, Transmission | 6 | 11-25-2012 11:28 PM |
| Base line dyno figure (dynapak Hub dyno) | gtauto | AUSTRALIA | 16 | 10-08-2012 09:06 AM |
