Old 05-05-2014, 03:08 PM   #211
Xerious
Speed Chaser Thrill Seekr
Xerious's Avatar
Drives: 2014 Asphalt Monogram FR-S 6MT
Originally Posted by xxBrun0xx View Post
For anyone who is thinking about letting someone else do the install, don't bother. This is incredibly simple, with really only 2 parts to install. Impressions after a few days: best $150 you can spend on this car, period.
no lift required? Did you have to remove the drive shaft or exhaust
Sent from my SAMSUNG-SM-N900A using Tapatalk
Performance: Jackson Racing SC & Oil Cooler, 18x9.5 Gram Lights 57Xtreme Wheels, 255/35 Yokohoma Tires, Rays Volk Racing Black 17hex 12x1.25 lugs, KW V3 C/O, Stance Control Arms
Exterior: LED DRL MOD Kit, Tom's Tail-lights, 5%/40% tint
My Build
Xerious is offline   Reply With Quote
Old 05-05-2014, 03:11 PM   #212
OrbitalEllipses
Drives: Attitude
You 'drop' the driveshaft at the carrier and let it rest on top the exhaust, which you do not need to remove.
Old 05-05-2014, 03:15 PM   #213
Xerious
Xerious's Avatar
Thanks. No issues with tranny fluid leaking?
My Build
Old 05-05-2014, 03:16 PM   #214
OrbitalEllipses
Drives: Attitude
No, you're not removing the driveshaft. Even if you do, I've *heard* that only a small little bit comes out of the tail section - though that rear seal CAN be damaged so be careful. Either way there's no reason to remove the driveshaft entirely with this mod.
Old 05-05-2014, 03:25 PM   #215
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I've *witnessed* a hell of a lot more than a "small little bit" come out of the tail section when installing a clutch. I would drain it or buy the Subaru plug the next time. With that being said, you don't need to pull it to do the shifter it sounds like.
Old 05-05-2014, 03:31 PM   #216
Xerious
Xerious's Avatar
Thanks! Anyone willing to write up a DIY?
My Build
Old 05-05-2014, 03:31 PM   #217
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Like the induvidual that Haz degree said, you drop the shaft down, don't disconnect it and no fluid comes out.
I installed mine, no lift.
Old 05-05-2014, 03:47 PM   #218
OrbitalEllipses
Drives: Attitude
Be more careful next time.
Check the Kartboy DIY...it's informative and the kit you bought comes with instructions that are readily adaptable to the Kartboy DIY. There's almost nothing to this install compared to replacing the lever on an actual shifter kit.
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
Sportsguy83 (05-05-2014), Xerious (05-05-2014)
Old 05-05-2014, 05:08 PM   #219
Sprchrgd
Drives: Whiteout frs
I did my install without a lift, just using two factory jacks most cars come with. The only problem one may face when doing the install is that without the recommended 8" and 3" extenders, those bolts for the rear bracket will be difficult to reach...
Sprchrgd is offline   Reply With Quote
Old 05-05-2014, 05:51 PM   #220
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
I used my uncle's lift to do the install. I'd be happy to do a video walkthrough, but it's so easy to install, nobody is going to need this. Seriously, this is on par with an oil change or rotating your tires.
xxBrun0xx is offline   Reply With Quote
Old 05-05-2014, 06:00 PM   #221
fguadamuz
Drives: 2013 BRZ Silver M/T
That would be great. I know the instructions that came with the Trd shifter are the best I have ever seen including color pictures but I prefer video instructions.
Mtec did a video for their springs and I will be using that as a guide next week.
fguadamuz is offline   Reply With Quote
Old 05-07-2014, 02:42 AM   #222
stockysnail
Just the tip
stockysnail's Avatar
I installed the quick shifter tonight. A WORD OF WARNING! If anyone has an aluminum drive shaft this will not work with it! The drive shaft has a slightly larger diameter and will rub the shifter linkage. I found out the hard way, fortunately I didn't break anything when I tried to drive off.
Aside from that the shifter is incredibly short. This is in my top 5 mods to my car I think, and I've done maybe 40 mods so far. Selling my aluminum drive shaft now since it's not compatible for $425 for anyone willing to pick it up from me. Not willing to ship.
Install was super easy (not counting the drive shaft issue). I already have the Perrin rear shift bushing so I skipped that part. Since I didn't do that part I didn't need to undo anything with the drive shaft or any other parts. Just unpin the shifter, remove the boot, install new boot, install the extender thing, put pin back in, put boot over new goodies. Would have been a 30min job (15mins jacking up the jack and getting ready), if it weren't for my aluminum drive shaft. Took 2 hours instead.
The Following User Says Thank You to stockysnail For This Useful Post:
vgi (05-08-2014)
Old 05-07-2014, 02:55 AM   #223
Xerious
Xerious's Avatar
Wow you'd sacrifice the aluminum drive shaft for the short shifter? I wonder if the carbon fiber drive shafts would work. It looks like they might have a slightly smaller diameter but am not sure.
Which brand aluminum driveshaft did you go with?
My Build
Old 05-07-2014, 03:04 AM   #224
stockysnail
Just the tip
I have the Axle Exchange aluminum drive shaft. It's a great shaft and I really liked it. I would not hesitate to recommend it for those without the quick shifter. If the carbon fiber one is the same or smaller than stock then yes it would work. I'm not willing to spend that much on a drive shaft since it has very minimal gains for the amount of $ spent.
SirBrass (05-07-2014)
TRD Quickshifter lovebeingbleu98 Brakes, Suspension, Chassis 3 02-13-2014 01:14 AM
Amazing Wax geb2391 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 04-12-2013 05:42 PM
The most amazing thing I've done with my BRZ so far azngolfur BRZ Photos, Videos, Wallpapers, Gallery Forum 8 01-09-2013 09:23 PM
Concept-Three-LED's DRL's are AMAZING! soros151 Cosmetic Modification (Interior/Exterior/Lighting) 4 11-09-2012 02:42 AM
