Old 05-05-2014, 12:50 PM   #1751
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
This is because the factory wideband has not been rescaled for the e85. It reads stoich and converts. Read the AFR as gas numbers.
Luckrider is offline   Reply With Quote
Old 05-05-2014, 01:01 PM   #1752
TruRace
TruRace's Avatar
Drives: FRS-Raven-MT
The readings on that dyno are from a sniffer on the exhuast, not from the factory wideband.
TruRace is offline   Reply With Quote
Old 05-05-2014, 01:06 PM   #1753
Luckrider
Luckrider's Avatar
Do you have any logs. That just doesn't sound right at all. If that were the case, you would have about 50% less fuel in the combustion stroke than you need.
Old 05-05-2014, 01:08 PM   #1754
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
@TruRace do you have cats in your exhaust?
- AdrianG
AdrianG is offline   Reply With Quote
Old 05-05-2014, 01:10 PM   #1755
TruRace
TruRace's Avatar
Yeah that's why I am a little concerned. I checked the tune I was running and it is definitely the Stage 2 E85 EL tune. I don't have any logs right now I can take one after I get off work.
- AdrianG
Yes, both of them.
Old 05-05-2014, 01:13 PM   #1756
AdrianG
Then the sniffer can't really be trusted...
- AdrianG
Old 05-05-2014, 01:13 PM   #1757
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
O2 sensors read oxygen content, not AFR. They assume you are running gasoline which is why you see a gasoline appropriate AFR. In reality, your actual AFR is a lot lower since you are running E85. Nothing to worry about. Your dyno operator doesn't understand this
Cheers
Shiv
Shiv@Openflash is offline   Reply With Quote
Old 05-05-2014, 01:15 PM   #1758
stefmiesterb
stefmiesterb's Avatar
Drives: B8 A5
I noticed the power blocks from crawford for sale on the OFT site. What are the numbers for this product paired with the and open flash tune and OFH/UEL compared to without the blocks?
Is it just the 10whp in the specific RPM range as claimed on the site?
stefmiesterb is offline   Reply With Quote
Old 05-05-2014, 01:16 PM   #1759
TruRace
TruRace's Avatar
Originally Posted by shiv@vishnu View Post
O2 sensors read oxygen content, not AFR. They assume you are running gasoline which is why you see a gasoline appropriate AFR. In reality, your actual AFR is a lot lower since you are running E85. Nothing to worry about. Your dyno operator doesn't understand this.
So are you suggesting the sniffer that was used wasn't calibrated for e85?
Old 05-05-2014, 02:37 PM   #1760
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Calibrating it for E85 is not necessary - O2 sensors read in lamba, with the value 1 being stoich. Stoichometric AFR for gas is 14.7, for E85 it's 9.765.
So when the dyno tuner is tuning for an AFR of 14.7, he's tuning for lambda = 1 (in other words, a true 9.765 AFR for E85). It will not affect the process.
See here for interesting data on various fuel types:
http://ethanolpro.tripod.com/id213.html
Td-d is offline   Reply With Quote
Old 05-05-2014, 08:00 PM   #1761
steve99
Drives: FT86
Originally Posted by mightyt73 View Post
I am currently using the OFT ots stage 1 tune. Earlier this week my advanced multiplier dropped down to .8 and slowly made its way back up to 1. Is this normal for the off the shelf tunes?
What fuel are you using on 91 USA fuel this will be quite normal it will do that on stock tune as well. On 93 or better it should not happen.
Old 05-05-2014, 08:05 PM   #1762
Lytheum
Drives: 2013 BRZ Premium 6MT
Mine still drops on 93 from time to time.
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Old 05-05-2014, 08:11 PM   #1763
steve99
Drives: FT86
These cars really need good fuel at 12.5:1 compression ratio. Even different brands and formulations of fuel can make a difference. you could try different brands of fuel
The problem area is generally between 2000-3500 rpm when you get on the throttle in a high gear.
The stock tune is even worse in this area.
have a read here our 98 RON is supposed to be equal to your 93 but it not quite as good
http://www.ft86club.com/forums/showthread.php?t=61820
Old 05-05-2014, 10:12 PM   #1764
mightyt73
Drives: 2013 Subaru BRZ, 2007 V6 Mustang
I use 93 from Exxon. Maybe I will try a different station. I'm guessing as long as it doesn't happen a lot I will be fine?
mightyt73 is offline   Reply With Quote
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
