Old 05-01-2014, 08:06 PM   #183
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
I did. And there is crazy, stupid amounts of play while in gear that definitely wasn't there stock. I've had $1000 beaters with 200k miles and way less shifter play than that. Stock was much better, imo
I'll take a video and post it up in a few. Maybe I did something wrong? Something definitely doesn't feel right
Sent from my XT1053 using Tapatalk
xxBrun0xx is offline   Reply With Quote
Old 05-01-2014, 08:55 PM   #184
xxBrun0xx
xxBrun0xx's Avatar
This should show how much slop my shifter had with the quickshift installed. Did I do something wrong? Don't have any other shift related mods at all.
[ame]http://youtu.be/8445SoYm3T8[/ame]
The Following User Says Thank You to xxBrun0xx For This Useful Post:
Mooseknuckle44 (06-06-2014)
Old 05-01-2014, 09:32 PM   #185
Xerious
Speed Chaser Thrill Seekr
Xerious's Avatar
Drives: 2014 Asphalt Monogram FR-S 6MT
Video doesn't work it says it's private
Sent from my SAMSUNG-SM-N900A using Tapatalk
Performance: Jackson Racing SC & Oil Cooler, 18x9.5 Gram Lights 57Xtreme Wheels, 255/35 Yokohoma Tires, Rays Volk Racing Black 17hex 12x1.25 lugs, KW V3 C/O, Stance Control Arms
Exterior: LED DRL MOD Kit, Tom's Tail-lights, 5%/40% tint
My Build
Xerious is offline   Reply With Quote
The Following User Says Thank You to Xerious For This Useful Post:
nosi9frs (05-01-2014)
Old 05-01-2014, 10:11 PM   #186
xxBrun0xx
xxBrun0xx's Avatar
This should work. Think the link is the same, but I'll repost it anyways. [ame]http://youtu.be/8445SoYm3T8[/ame]
Old 05-01-2014, 11:23 PM   #187
Kwaziekeller
Kwaziekeller's Avatar
Drives: '13 Argento MT FR-S
I got mine in today, it took me about 35-40mins to install and I'm very impressed. I was doubting the effectiveness of the part but went ahead and ordered it based on reviews and overall cost. The throws are short enough that when I tested shifting before taking my car off of the jackstands, I thought it was binding and not going into gear but it was.. Still retains factory feel as well (I'm still using my Perrin rear shifter bushing). Best short throw I've ever used (compared to Mopar Short Throw Shifter with Booger shift linkage bushings on my old SRT4, and a TWM shifter in a Civic Si).
Kwaziekeller is offline   Reply With Quote
Old 05-02-2014, 12:39 AM   #188
ft86me
ft86me's Avatar
Drives: 2013 FRS
anyone else provide input in regards to the play that @xxBrun0xx is talking about. mine is coming tomorrow and wondering if i should send it back before wasting my time on install
ft86me is offline   Reply With Quote
Old 05-02-2014, 03:41 AM   #189
Sprchrgd
Drives: Whiteout frs
I had mine installed for a few days now and there is no play like that described and depicted in the video above. also, my knob position at neutral has changed after the installation and it is placed a little bit towards the right. I am loving the shifter so far.
Another thing to note, i am no expert so i tried to follow closely the instruction the shifter came with and applied loctite on every bolt that was part of the shifter kit...
Sprchrgd is offline   Reply With Quote
The Following 3 Users Say Thank You to Sprchrgd For This Useful Post:
axelo (08-23-2015), ft86me (05-02-2014), Xerious (05-02-2014)
Old 05-02-2014, 03:43 AM   #190
Xerious
Xerious's Avatar
Yah that's pretty bad. Did you install it yourself? I'm now hesitant to install this on my car if it had that much play.
My Build
Old 05-02-2014, 05:40 AM   #191
OrbitalEllipses
Drives: Attitude
That's definitely not normal. You sure you installed everything correctly?
Old 05-02-2014, 06:42 AM   #192
xxBrun0xx
xxBrun0xx's Avatar
I did install everything myself, and also followed the directions to a T. Did have an extra washer at the end, though. Anybody have any idea what might be causing all that play in the shifter? Just trying to think what it could be. I'll get it back on the lift and recheck everything later today, but I'm not really sure what I should be looking for besides retorquing bolts. Could the little adapter that lowers where the shifter connects be loose or would it be the rear shifter busing I should be looking at?
Edit: I'll try replacing the rear shift busing first, since its easier, see if that fixes it, then try replacing the adapter to see if that fixes it. I'll let you guys know when I figure it out so that anyone else with the same issue can fix it as well! Wonder if some of the kartboy users complaining of play have the same root cause as I do? Guess we'll find out!
Old 05-02-2014, 11:07 AM   #193
xxBrun0xx
xxBrun0xx's Avatar
Solved! The bolt that goes into the adapter piece was loose. Tightened it up and there's almost no slop now! Also, doesn't seem to rattle, but I just took it out for a few minutes. Much much better!
The Following 9 Users Say Thank You to xxBrun0xx For This Useful Post:
chanomatik (05-02-2014), ericmpena (05-02-2014), ft86me (05-02-2014), Jmonty (05-31-2014), Kimsey47 (07-30-2014), Mooseknuckle44 (06-06-2014), unsurety (05-02-2014), wu_dot_com (05-02-2014), Xerious (05-02-2014)
Old 05-02-2014, 11:24 AM   #194
sato
sato's Avatar
Drives: Dodge Patitas
Makes me want to purchase the car, without even having the car. Jeje
Sent from my C6906 using Tapatalk
sato is offline   Reply With Quote
Old 05-02-2014, 12:10 PM   #195
nosi9frs
nosi9frs's Avatar
Drives: Raven FR-S
Can you post the same video with the fix??
nosi9frs is offline   Reply With Quote
Old 05-02-2014, 12:42 PM   #196
xxBrun0xx
xxBrun0xx's Avatar
Yes sir!
[ame]http://youtu.be/2JIPNaEXxfA[/ame]
The Following 6 Users Say Thank You to xxBrun0xx For This Useful Post:
chanomatik (05-02-2014), ericmpena (05-02-2014), nosi9frs (05-02-2014), SPCorBUST (05-23-2015), stockysnail (05-03-2014), Xerious (05-02-2014)
TRD Quickshifter lovebeingbleu98 Brakes, Suspension, Chassis 3 02-13-2014 01:14 AM
Amazing Wax geb2391 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 04-12-2013 05:42 PM
The most amazing thing I've done with my BRZ so far azngolfur BRZ Photos, Videos, Wallpapers, Gallery Forum 8 01-09-2013 09:23 PM
Concept-Three-LED's DRL's are AMAZING! soros151 Cosmetic Modification (Interior/Exterior/Lighting) 4 11-09-2012 02:42 AM
