Old 03-23-2014, 01:48 PM   #29
stueck9356
Drives: 2015 VW GTI SE
I am debating on doing this, where I want the clutch to engage is right where the helper spring goes from 'rotating up' to 'rotating down' so at the top of the clutch pedal it has almost no pressure, and sometimes gets stuck about an inch low until the spring 'pops' the other way and applies upward force on the pedal. The engagement point is PERFECT at that spot, but the spring ruins it for me.
How much of a % stiffer would you say it is? 25%?
stueck9356 is offline   Reply With Quote
Old 03-23-2014, 02:13 PM   #30
wheelhaus
wheelhaus's Avatar
Does the spring delete help the clutch pedal throw to feel more linear (i.e. you feel the clutch diaphragm spring more), or stiffer for the entire travel, or just stiffer in one area of travel?
I've been driving Subarus for nearly a decade so I'm kind of used to them, but have always felt like the clutch feels a bit vague. I'm the adaptive type, I try learn how a mechanism feels and then persist with it to find how to utilize it most effectively. Even still I sometimes wished the clutch had a more linear feel where the clutch's diaphragm spring felt more palpable in the stroke...
Old 03-23-2014, 04:52 PM   #31
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
FWIW, I ended up reinstalling my helper spring. I feel that it provides a more precise feel, even if the pedal action could be firmer.
enjoyminutemaid is offline   Reply With Quote
The Following 4 Users Say Thank You to enjoyminutemaid For This Useful Post:
fatherfork (03-23-2014), gonzo (08-21-2014), Hyper4mance2k (03-14-2015), zdr93523 (05-21-2014)
Old 03-24-2014, 10:43 AM   #32
FR-Slide
Drives: 13 Whiteout 6MT
Hmm, this is good to know.
I've been looking into this, as I just adjusted my clutch and installed a clutch stop this weekend. I really love the shorter throw, but the numbness in the top half of the travel still really bugs me. I was thinking that removing the spring may make the pedal a bit stiffer at the top (like it is at the engagement point), but I didn't want to muck around and make it worse than it is.
It's honestly not BAD, I just wish it was a bit firmer at the top...
FR-Slide is offline   Reply With Quote
Old 03-24-2014, 01:36 PM   #33
stueck9356
No, I don't think its bad either. Could be a creative way to get a stiffer clutch without the stiff pedal, by providing a stronger spring.
I think the hatred of the clutch is because the helper spring doesn't align with the clutch engagement style, causing a pedal feel that doesn't match the movement of the clutch.
Old 04-29-2014, 02:47 PM   #34
customfab87
customfab87's Avatar
Drives: 2014 FR-S 6MT
Highly Recommended! I always wondered why the car felt like it was responding to very stiff diaphragm springs, yet the clutch return travel had no feel. I have owned about a dozen stickshift cars over the past 10 years, with stock to 6-pucks, and have never had a clutch be so soft, vague, and jerk the car so much. LOL. Although the pedal is a little stiff now, I can completely feel the action of the springs, which helps when you're feathering a non-responsive electronic throttle! No more stalling EVERY SINGLE DAY.
I found the easiest way to remove the C Clip is to take a small flat head, stick it into the middle of the "C", and push away from the rod. If you try to push on the ends of the "C", you'll just keep rotating the clip and get annoyed. Easiest way to remove the spring, as others have said, is to push the clutch in all the way to relieve compression on the spring, and then to push the spring away from you. It should pop right out.
I would compare the stiffness to an ACT HD Street clutch.
I may end up looking for a very weak helper spring (I've seen compression springs at Home Depot and Auto Parts Stores) if the stiffness gets annoying in LA traffic. I think the stiffness is something easy to get used to. Plus it prevents me from holding down the clutch and putting wear on the bearings!
customfab87 is offline   Reply With Quote
The Following User Says Thank You to customfab87 For This Useful Post:
Slysdexia (05-08-2014)
Old 04-29-2014, 11:32 PM   #35
Carban
Grease Monkey
Carban's Avatar
Drives: Whiteout FR-S
Just did this. took about 120 seconds. spring perch was very simple to pry off.
Clutch now feels.... like a CLUTCH no more handicap "new car" clutch feel.
R.I.P. '92 Honda Prelude you will be missed
Carban is offline   Reply With Quote
Old 04-29-2014, 11:56 PM   #36
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Bump for a mod that is completly worth it!
Old 05-01-2014, 04:12 PM   #37
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
Just did this as well and it is incredibly good. My only question: Has anyone else who has done this noticed that the first half an inch or so of travel has basically no resistance? Might this have anything to do with the petal height adjustment mod I did prior to doing this? Any way to fix this?
xxBrun0xx is offline   Reply With Quote
Old 05-01-2014, 04:21 PM   #38
Slysdexia
Slysdexia's Avatar
Drives: '14 Monogram 6MT FR-S - Hot Lava
Actually, you're just feeling the clutch. The helper spring is fighting you for the first inch before it switches to making it easier, so without it the pedal is very easy for the first little bit.
If you're talking about some other sensation, then try undoing the adjustment you performed previously.
Sent from my PO-T4T0 with Eyes.
Slysdexia is offline   Reply With Quote
The Following 2 Users Say Thank You to Slysdexia For This Useful Post:
gonzo (08-21-2014), xxBrun0xx (05-01-2014)
Old 05-01-2014, 04:21 PM   #39
enjoyminutemaid
That happened on mine too. I'm still not sure if it just felt that way because the rest of the travel was so much stiffer. When I reinstalled the clutch spring (recently uninstalled it again, lol), there seemed to be more play in the first half inch of travel than before I removed the spring the first time.
Old 05-01-2014, 04:32 PM   #40
xxBrun0xx
xxBrun0xx's Avatar
Thanks guys, did some more reading and I'm not really worried about it anymore The clutch feels amazing without that spring! Have never ever been able to drive the car as smooth as I can now!
The Following 2 Users Say Thank You to xxBrun0xx For This Useful Post:
504 (09-03-2014), jcw99 (08-02-2016)
Old 05-01-2014, 09:25 PM   #41
stueck9356
Just pulled mine. It is a lot stiffer than stock, but I think after a few hundred miles I'll be used to it.
There isn't more "feedback" from the clutch, however it is much more linear and that makes it easier to work with and turn into muscle memory.
Sent from my GS4
Old 05-02-2014, 03:44 PM   #42
Slysdexia
Slysdexia's Avatar
Originally Posted by stueck9356 View Post
It is a lot stiffer than stock...
...There isn't more "feedback" from the clutch.
You said it right there.
The stiffness you're feeling is the spring pressure of the clutch pressure plate as you're working through its travel. That's the feedback I'm talking about.
It's not like steering feedback. You're not usually going to get a literal response in the pedal from your actions unless your clutch is chattering or some odd stuff is going on.
clutch helper spring, helper spring removal
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 01:11 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 01:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 11:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 01:06 PM
