Old 05-01-2014, 10:38 AM   #4467
xxscaxx
Drives: 2013 SWP BRZ
Originally Posted by Ryan86 View Post
I've done 400km on my OEM file with 80mm pulley with no CEL. So I can verify car is happy and Toyota are happy. TICK
I decided to change to 75mm pulley to verify if a slight more boost would trigger a CEL, drove 80km no CEL. TICK
Decided to load the one tune from Bill I've had on my car the longest for 75mm pulley than did not have any problems. 5.81.
As I load the file Ecutek indicates a DCT at the end of completion PU001, I started the car and drove for 100m CEL came on PO016.
Drove back home loaded stock file back in and drove 60km no CEL.
Something is going wrong either tune or SW related.
Has Bill been in contact?
xxscaxx is offline   Reply With Quote
Old 05-01-2014, 10:40 AM   #4468
xxscaxx
Just wanted to let everyone know something quick. I've been searching for a strut bar solution for us seeing as we are pretty limited.
I contacted @mav1178 who had the STi strut bar to see if he could give me measurements so I could check and see if the strut bar would fit over our charger. He found someone online that had the bar already installed on our kit.
Just glad there is another option out there for us. I know FRS owners probably won't want this but at least it fits so i figured i'd share.
Full post:
http://www.ft86club.com/forums/showt...28#post1708328
Old 05-01-2014, 10:51 AM   #4469
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
I've mailed Bill daily on the progress of elimination which he's been in contact. I've also mailed Ecutek to have both tuner and SW look into this. Ecutek have responded, busy looking into it.
I have a suspicion it's got to do with international ECU, we on a different file to you in the US which may be causing conflict with the ECU using your US file. My OEM is as G file and you are C file.
Let's see what the response is.
I've had 2 guys PM me also with PO016, whom are also out of the US. Did not say who there tuner was.
Ryan86 is offline   Reply With Quote
Old 05-01-2014, 10:54 AM   #4470
Ryan86
Road Warrior
Ryan86's Avatar
I contacted @mav1178 who had the STi strut bar to see if he could give me measurements so I could check and see if the strut bar would fit over our charger. He took it one step further and found someone local with the innovate kit and had them test fit it.
Full post:
Megan strut brace fits perfect and is cheap too under $100
Damn I like the red connectors for the intake, where from?
Old 05-01-2014, 11:16 AM   #4471
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
Possible causes
- Faulty spark plug 2
- Clogged or faulty fuel injector 2
- Faulty ignition coil 2
- Fuel injector 2 harness is open or shorted
- Fuel injector 2 circuit poor electrical connection
- Ignition coil 2 harness is open or shorted
- Ignition coil 2 circuit poor electrical connection
- Insufficient cylinder 2 compression
- Incorrect fuel pressure
- Intake air leak
What does this mean?
Read more: http://engine-codes.com/p0302_toyota.html#ixzz30TDPETU2
Could it be because the water pump for the intercooler is powered from the number 2 injector plug??
Sent from Samsung Galaxy Note 3
Area86 is offline   Reply With Quote
Old 05-01-2014, 11:24 AM   #4472
Ryan86
Road Warrior
Ryan86's Avatar
I questioned while installing the purpose to link into the injector harness, thought it would be dangerous to have a electrical source off the injector plug.
Have not heard of any problems though.
Old 05-01-2014, 11:54 AM   #4473
Kodename47
Kodename47's Avatar
Drives: UK GT86
Ryan, is there any reason you're not running a G series ROM? Or did I read that wrong?
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-01-2014, 12:00 PM   #4474
Ryan86
Road Warrior
Ryan86's Avatar
You reading it right.
Bill only supplies a C rom,
Old 05-01-2014, 12:49 PM   #4475
xxscaxx
I knew of that one, but it is a copy of the Cusco and I don't like the way that one is designed and looks hehe.
The only ones I know of are the STi, and the megan/cusco/whiteline (I believe whiteline). Maybe i'm missing one. But those are all the same style which i'm not particularly fond of.
Old 05-01-2014, 12:59 PM   #4476
xjohnx
Grip>Slip
xjohnx's Avatar
Ground Control fits too, with spacers.
Chad86 (01-11-2015)
Old 05-01-2014, 01:28 PM   #4477
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Has there been any updates for the 210+ kit?
I've been holding out and spending money on other parts while waiting. :P
Old 05-01-2014, 01:30 PM   #4478
xwd
Nothing but crickets (no pun intended).
The Following 2 Users Say Thank You to xwd For This Useful Post:
SirBrass (05-01-2014), tahdizzle (05-01-2014)
Old 05-01-2014, 02:29 PM   #4479
xxscaxx
I didn't include this one because the only way you can run that bar is if you buy the ground control camber plates. This bar will not fit on its own. I even reached out to GC about making the spacers larger and if they off a normal mounting solution and they don't.
The Following User Says Thank You to xxscaxx For This Useful Post:
Chad86 (01-11-2015)
Old 05-01-2014, 02:55 PM   #4480
swift996
swift996's Avatar
FWIW the cusco bar clears fine too
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
