Old 04-28-2014, 11:53 PM   #1723
steve99
Drives: FT86
Originally Posted by 1Cor10:23 View Post
Could I get some thoughts on my data log? Greatly appreciate any and all comments
Stage 2 UEL on 94 Octane.
log is here http://datazap.me/u/1cor1023/140428-...0&data=1-11-12
AFR shows rich on WOT, you can see +LTFT (~3.9) at high revs on 2nd and 3rd gear pulls. Another concerning point is the KC going on all over the place causing the IAM to drop to .88 after first 2nd gear pull and then .88 later on in log.
Anything I should be concerned about?
Would appreciate your thoughts if you have a moment @shiv@vishnu
Cheers.
Yeah it looks pretty good
If you want to stop IAM drop see first post in thread below, you carn't use the ROM's as they are G series but same principles apply, basicly just pull a bit of timing in problem 2000-3500 area
http://www.ft86club.com/forums/showthread.php?t=61820
If you want to get your AFR closer to target then you will need to scale MAF and get your ltft closer to 1 or 2% throughout rev range , its not rearly going to make that much difference but just makes the tune more consistent day to day. If your ltft was 7 or something then its rearly worth doing.
The +3.9% fuel trim at wot will make you richer than target.
Shiv target's around 11.8 for safety and your not rearly far off.
Old 04-29-2014, 05:10 AM   #1724
steve99
Drives: FT86
Originally Posted by Grip Ronin View Post
well its 7-4% in CL and -3.91 in mode 2 injection till about 3500-5k then drops too.78 and a/f is faily close. i have rescaled the maf in the higher range not the CL. getting the high pressure pump warranty a few months ago wouldnt throw off injector scaling would it??
Probably worth doing the CL maf scaling if your running up to 7% LTFT trim. And check for leaks in exhaust before O2 sensors, you did use new gaskets when you installed headers ?
Old 04-29-2014, 06:26 AM   #1725
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
@steve99 thanks for your insight. Do you think running rich is a symptom of not having a modified snorkel like the one Shiv uses on his test cars?
1Cor10:23 is offline   Reply With Quote
Old 04-29-2014, 06:57 AM   #1726
steve99
Drives: FT86
Don't think it will be snorkel , more likely combination of fuel formulation and maybe bit of error in MAF scaling.
Fuels with 10% ethanol tend to run leaner than fuels with no ethanol content ect, also can be effected by other additives in fuel, don't you guys have some weird additives due sub zero climate ??
not sure if shiv tunes on E10 fuels or not.
Don't worry too much unless your really picky, running a bit rich is safer than running lean also generally less knock prone.
Old 04-29-2014, 07:00 AM   #1727
1Cor10:23
1Cor10:23's Avatar
@steve99 Yup, most of our stuff is e10 but would have expected shiv's California juice to be the same. Perhaps it is some additives.
Old 04-29-2014, 07:06 AM   #1728
steve99
Drives: FT86
Yeah your running about 11.4 AFR at +3.9% LTFT so if that went back to 0% that would put your AFR at 11.8 which is what shiv said he targets at WOT.
Old 04-29-2014, 10:40 PM   #1729
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
i did not. but i checked for leaks after the first install and was checked again maybe a month or two ago.. its weird that it would pull fuel even tho its so far lean from the commanded a/f
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 04-29-2014, 11:57 PM   #1730
steve99
Drives: FT86
I'll put a $1 on new gaskets sorting it out. rearly weird stuff happens if you have leaks near O2 sensor, do all 3
Old 04-30-2014, 09:41 AM   #1731
Grip Ronin
The Mechanic
Grip Ronin's Avatar
ill give them another check and report back.
IG-Joey_Soul
Old 04-30-2014, 12:50 PM   #1732
gabeg86
gabeg86's Avatar
Drives: 2013 Raven FR-S
just got my OFT a couple days ago, flashed yesterday morning, and datalogged last night. run is 3rd gear WOT. Seems to be running pretty rich.. doesn't seem to be very ideal.. any thoughts and/or comments would be greatly appreciated! Thanks! Mods are evo3 catback and f20club intake
http://www.datazap.me/u/gabeg86/orig...0&data=1-2-6-8
edit: is it also strange that my throttle position is never at 100% when WOT?
Perrin (LWCP) - Blox (shift knob) - HID Powerhouse (LED's and HID's) - Eibach (sportlines) - Muteki (lugs) - SPL (LCA's) - Rays Engineering (57dr's) - Dunlop Direzza ZII (tires) - Greddy (Evo3) - Full Race (turbo kit) - Ecutek (tuned)
gabeg86 is offline   Reply With Quote
Old 04-30-2014, 01:30 PM   #1733
ML
ML's Avatar
Drives: 13 White MT FR-S
That all looks normal and safe for this tune.
Old 04-30-2014, 01:37 PM   #1734
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Throttle taper off to 90% by redline is normal. Your logs do show it running a bit rich due to the FA20club intake. I recommend just driving around for another day or two and wait for the LTFT to settle. You may not have giving it much learning time. It may move a bit more negative and adjust AFR accordingly. The other option is to adjust your MAF scale table to compensate for the FA20club intake.
Cheers
Shiv
Shiv@Openflash is offline   Reply With Quote
Old 04-30-2014, 02:58 PM   #1735
gabeg86
gabeg86's Avatar
Cheers
Shiv
Awesome thanks guys! I'll probably rescale my MAF if it doesn't adjust much in the coming days. I appreciate the input fellas @shiv@vishnu @ML
Sent from my HTC One using Tapatalk
Old 04-30-2014, 08:13 PM   #1736
uncivilised
Drives: 86 GT
whats the target afr for e85 that i should be aiming for?
it seems that some days its around 11.8-12 WOT, then once i saw it go from 12.5 to 12.7 then go down to 11.8-12 WOT
using stock airbox and filter, 4-1 EL catless headers and matching overpipe. stock exhaust from overpipe back
would a gasket leak after the o2 sensors cause it as i think there is a leak, i dont think its leaking before the sensors as i replaced the header to cylinder head gaskets with grimmspeed multi layer metal ones.
edit found a log that shows this
http://www.datazap.me/u/uncivilised/...zoom=2852-2958
uncivilised is offline   Reply With Quote
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
