Old 04-30-2014, 03:09 AM   #1
BC-Boy
BC-Boy's Avatar
Drives: 2013 Brz sport-tech
Cricket Killer, Injector lube ?
Didnt know what to put this under but i found that this was more mechanically related than lube related.
I use nothing but 94 oct 0 ethanol fuel and do get light crickets pretty much all the time, but now im starting to hear a light ticking noise when going tru the underground parking at my place, so being ocd i checked exhaust leaks etc.. only to link this noise to the injection cycle.
My question is , its a question to know you all's opinion but i will be doing it anyways regardless to opposition i would just like to know if anyone has had luck with this yet.
2STROKE OIL . yes 2 stroke oil in your new cars gas tank, has anyone done this yet ? (in their 86) in the equipment we run either powerpacks or even down to our work trucks we have allways put some 2 stroke oil in the diesel fuel to lube the injection system, all the big lifted trucks driving around here blowing back smoke prettymuch all run 2 stroke oil in their fuel, alot of the VW TDI guys swear by it.
Downside, ive allways owned a sled and allways a 2 stoke (mainly rotax ski doos) and can confirm that 2 stroke oils have a very large difference brand to brand in terms of deposits in the pipes and on the piston, any generic cheap oil is gonna stink and cause black deposit in pipes and pistons BUT fully synthetic ester based oils seem to keep things like brand new yet they drip out the pipes meaning they do not completely burn. My favorite brand is IPONE strawberry scent . amazing oil you could run lean and overheat like mad this oil and the Motul Snow are the best ive run, alot of the other oils seemed to either stink or foul plugs when it warmed up outside and started running richer having jetted for the cold.
That being said i will be trying a 2 stroke oil for this problematic mechanical injection system, and it will be a ashless 100% synthetic , prob the IPONE strawberry scent :P Mix prob 20-25ml to 50L(1-200-250) pump gas. Ill update this as soon as a go tru the tank of gas and confirm the results , but pls share if you or someone you know has had good or bad experience using this method of lubrication or any other method for that matter, hearing this chirping is something that only brings to mind a metal on metal wear scenario in my mind and i can see it being bad in the long run, sure hi pressure direct injection circuits allways make noise but to make more noise than the valve train ?? my ecoboost truck was DI and was very silent for that matter so are alot of other DI vehicles.... im not bringing this car to the dealer i know ive allready screwed my warranty so i want alternatives to prolong life of this beast
BC-Boy is offline   Reply With Quote
The Following User Says Thank You to BC-Boy For This Useful Post:
Nu_era (05-02-2014)
Old 04-30-2014, 04:41 AM   #2
Raven604
I have also run nothing but 94 chevron gas from coquitlam but don't have crickets. It's probably a manufacturing process error somewhere along the line that causes it. But I have no idea if 2 stroke oil / gas is a good idea.
Sent from my SGH-I337M using Tapatalk
Raven604 is offline   Reply With Quote
Old 04-30-2014, 07:12 AM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
"cricket killer"
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
SirBrass (04-30-2014), sklimo (04-30-2014)
Old 04-30-2014, 07:15 AM   #4
DriftHappens
Drives: '14 FRS White
I know 2 stroke is wonderful in a rotary...let's see what happens here.
I can definitely recommend idemitsu...in a rotary...Burns well.
DriftHappens is offline   Reply With Quote
The Following User Says Thank You to DriftHappens For This Useful Post:
ML (04-30-2014)
Old 04-30-2014, 10:14 AM   #5
Pish
#teamswagoi
Pish's Avatar
Drives: 2014 Raven FR-S Monogram
"cricket killer"
Exactly what I was thinking !
Hope it works out for you man !
Pish is offline   Reply With Quote
Old 04-30-2014, 03:20 PM   #6
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Ive been using nothing but Costco's 91... occasional crickets if I have a low tank of gas. Once I fill up, they go away
N1rve
Old 04-30-2014, 06:46 PM   #7
schmearcampain
Drives: 2014 Argento FRS 6MT
Quite a few people are using 2-stroke oil to quiet their engines
http://www.ft86club.com/forums/showthread.php?t=21980 (among other threads)
I've started using it as well. Ashless (TC-W3) is supposedly better since it's meant to leave no residue. People have had success at ratios as low as 1:1000 (50ml per tank), others are sticking with a 1 oz/5 gal ratio (approx 1:600). I'm still on my first tank at 1:750 (~70 ml/50L) and it's working well. The engine is much quieter overall and crickets show up much less frequently and are quieter when they do.
schmearcampain is offline   Reply With Quote
Old 04-30-2014, 07:02 PM   #8
ramiram1984
Drives: 2016 STi DGM
let's wait to see long term effects...
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 04-30-2014, 08:38 PM   #9
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Stick these by your hpfp. I promise it'll kill those crickets dead.
http://www.webstaurantstore.com/jt-e.../605JT844.html
^GT5 Replay Photo Mode^
Old 05-02-2014, 04:10 AM   #10
BC-Boy
BC-Boy's Avatar
aha ok im not putting 2 stroke oil in , i was actually a bit steep into a case of beer when i wrote that it really sounded like a good idea , i dont have loud crickets but they do come and go. i have however solved a problem that has been lurking around me ever since i got the car, that is CHEVRON 94. i will make a seperate thread , but all i have to say is that when its a good batch it does tune like a 94 BUT there seem to be more bad batchs than good, i now run vpower 91 and seriously didnt have to detune all that much , just slightly pull back on ignition and afr is great. i will be running OCTANANIUM from VP fuels its coming in tomorrow, then im going to dyno next week after my oil cooler install, my 91tune vs my 94tune that i allready had (with the VP additive) and a new tune to take full potential of the VP additive which is supposed to yeild 96oct and it does have lubrification properties that are good for injectors and such.if this doesent quiet down the injectors i bought some redline fuel additive, its does feel slick, so im sure it will help ill only add a bit,quite the cocktail. this should be interesting.
Old 05-02-2014, 08:36 AM   #11
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
I've used 1-2oz of Lucas smokeless low ash 2 stroke oil in a full tank of gas many times before and it completely silences the crickets for the duration of that tank. Do a search and you'll find many others here use it with the same results and no ill effects. Just keep the concentration really low and you'll be fine.
Old 05-02-2014, 09:21 AM   #12
stugray
Drives: 2013 GBS BRZ Limited
I was thinking keep a bearded dragon under the hood.
The Following User Says Thank You to stugray For This Useful Post:
SirBrass (05-02-2014)
Old 05-02-2014, 12:50 PM   #13
BC-Boy
BC-Boy's Avatar
[QUOTE=stugray;1711158]I was thinking keep a bearded dragon under the hood.
putting a animal i would go no lower than a honey badger
Old 05-02-2014, 12:55 PM   #14
BC-Boy
BC-Boy's Avatar
im going to wait and see how the VP additive works, if as advertised it does lubricate and clean injectors, if it doesnt work i have redline fuel additive, which is supposed to lubricate the upper cyl and clean / lubricate injectors, i will only go small doses, if still doesnt work im putting some ashless 2 stroke at a very very thin ratio no knowing how it will affect the VP stuff as well, the switch from chevron to shell might help as well.
chirping, noise
Plano Tx - Quaker Steak & Lube Meet 20firestorm13 Southwest 1 06-03-2013 04:55 PM
So my girlfriend took the car to Jiffy Lube... Mandy Other Vehicles & General Automotive Discussions 24 04-08-2013 02:35 PM
How shall I lube? jimmillion Off-Topic Lounge [WARNING: NO POLITICS] 5 11-17-2012 01:13 AM
Anyone change transmission lube yet? BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 08-21-2012 05:47 AM
the BMW killer! RRnold Off-Topic Lounge [WARNING: NO POLITICS] 10 08-28-2010 01:48 AM
