View Poll Results: Grip style
Palm grip 38 55.88%
Pistol grip 20 29.41%
I drive an automatic. heh. 10 14.71%
Voters: 68. You may not vote on this poll
Old 04-26-2014, 08:44 PM   #1
aristo
aristo's Avatar
Drives: BRZ SWP 14
How do you hold your shift knob?
New to manual trans. Some people are telling me that a strong open palm grip is the only way to go? Would like some input from people who have been driving manual for longer
Currently doing the 'pistol grip/side arm' style because it feels more comfortable and natural to me but maybe I can still change habit
Some shift knobs seem to even be designed purposely for side arm shifting like the raceseng Ashiko
aristo is offline   Reply With Quote
Old 04-26-2014, 08:47 PM   #2
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
When shifting down, I hold it like a pistol, but when shifting quickly up into third or 5th, I put my hand/palm right "behind" the middle of the knob and throw it up.
husker741 is offline   Reply With Quote
Old 04-26-2014, 08:49 PM   #3
KelvinBRZ
GBS Mafia Member
KelvinBRZ's Avatar
Drives: with Snow mode on
I usually have my palm on it, mostly use my palm to shift up or down. Different strokes for different folks!
Yes I drive an automatic.
GBS Mafia
KelvinBRZ is offline   Reply With Quote
Old 04-26-2014, 09:02 PM   #4
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
^what this guy said.
In reality, my grip for each gear is different. Depends on what gear I'm in and which gear I plan on going into next.
unsurety is offline   Reply With Quote
The Following 2 Users Say Thank You to unsurety For This Useful Post:
Churnobyl (04-28-2014), SeanBlader (04-29-2014)
Old 04-26-2014, 09:10 PM   #5
dbrandt01
Drives: none
I use just like finger tips to pull it down to 2nd, 4th, 6th or downshifting.
Palm for going up to 3rd and 5th
dbrandt01 is offline   Reply With Quote
The Following 2 Users Say Thank You to dbrandt01 For This Useful Post:
gramicci101 (04-26-2014), xoxomichaela (04-29-2014)
Old 04-26-2014, 09:16 PM   #6
extrashaky
Drives: 2014 BRZ Limited
Don't over think it. All that really matters is that you have enough grip on it to keep it from slipping through your fingers but not such a kung-fu grip that you're white knuckling it. The car doesn't have to be gently caressed, nor does it need to be slammed into gear. Beyond that, how you apply the proper amount of pressure to get it into the next gate is up to you.
And if you ever start shifting in some particularly stylish way that you think "looks cool," you're not. I saw a video a while back where some kid was throwing his elbow out to the side and slamming the shifter into the gates, like he was all gangsta an' shit. On the contrary, he was just a moron. Ultimately, shifting is one of those things that should just happen without you or anybody else really noticing.
Old 04-26-2014, 09:24 PM   #7
aristo
aristo's Avatar
Drives: BRZ SWP 14
Thanks for all the input! much appreciated
A follow up question: Are heavier shift knobs actually noticeable when installed vs stock? Or is it mostly a placebo thing?
Has anyone ever installed a heavier shift knob and regretted it or reverted back to stock?
Old 04-26-2014, 09:31 PM   #8
BRZBlack
BRZBlack's Avatar
Drives: 2013 Subaru BRZ
A 2 finger grip is what I use to shift into 2nd, 4th and 6th. Just enough pressure to get it in there. Palm for neutral to 1st 3rd and 5th. When I first got the car (this is my first MT), I found myself "Death Gripping" the shifter all the time. You don't need a lot of force to make it happen. This came after I got more comfortable and "relaxed" behind the wheel though. In spirited driving, I use 3 fingers (imagine twisting off a cap on a bottle of coke) to grip the top of the knob.
BRZBlack is offline   Reply With Quote
Old 04-26-2014, 09:31 PM   #9
kberkel
kberkel's Avatar
I palm it, lightly.
I never "hold" it when I'm not shifting. That always felt awkward to me.
kberkel is offline   Reply With Quote
Old 04-26-2014, 09:40 PM   #10
gramicci101
Off Topic
I use fingertips for everything, even 2-3 and 4-5. It's quicker to move just my hand and fingers than it is my entire arm, and it doesn't take that much pressure to shift.
Old 04-26-2014, 09:57 PM   #11
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
+1
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
The Following User Says Thank You to FLYFISHR For This Useful Post:
dbrandt01 (04-26-2014)
Old 04-26-2014, 10:03 PM   #12
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
I found the stock shift knob too rattle-prone for my liking (I later screwed it on a lot tighter than it had come from the factory, and this seemed to fix the issue a bit).
I replaced it with a 495g WC Lathewerks ball, and I have to say it felt much better - more solid, smooth, and the shift knob is now much lower than the stock knob.
I think it is a tangible difference - however, make sure your shift knob really IS heavier (the stock piece is supposedly 198g, which is about the same as most of the custom shift knobs out there).
Only downsides: you will need gloves for winter driving (the material gets very cold), and likely you will want to cover it whenever you park for the summer (haven't experienced this yet)
Also, depending on the material, the new shift knob might not be as "grippy" as the stock unit, which may be an issue under spirited driving.
daiheadjai is offline   Reply With Quote
Old 04-26-2014, 10:04 PM   #13
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
I use my feet
Old 04-26-2014, 10:28 PM   #14
dbrandt01
Drives: none
I use an Anarchy Motive shift knob at 671 grams to answer your newest question. The only difference I can tell besides it being cold during winter, or what little winter Alabama has and the heat. It gets hot and cold. Although, the main difference it doesn't feel as notchy, but I wouldn't say it shifts any easier like some people claim.
WTB TRD shift knob Vlady Interior Parts (Incl. Lighting) 0 04-17-2014 01:28 AM
FS Raceseng 86 AT Shift Knob and Cusco Red SPin Turn Knob Unidentified Interior Parts (Incl. Lighting) 2 01-06-2014 10:55 PM
Shift knob help z3ro Cosmetic Modification (Interior/Exterior/Lighting) 3 10-13-2013 01:05 AM
TRD MT Shift Knob NG86 Australia Classifieds 2 01-21-2013 07:40 PM
any other shift knob? oso_25 Cosmetic Modification (Interior/Exterior/Lighting) 2 07-31-2012 02:38 AM
