Old 04-25-2014, 05:43 PM   #4439
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Originally Posted by xxscaxx View Post
Was hoping it would just be an ECU flash...but keep us posted. Best of luck Ryan.
How many miles on the car?
I'm on 40000km
Had the Sc on for 14000km
Ryan86 is offline   Reply With Quote
Old 04-25-2014, 07:09 PM   #4440
stockysnail
Just the tip
stockysnail's Avatar
Originally Posted by scionsalesjay View Post
I am experiencing a chirping on my 2013 MT6 FR-S. I was wondering if anyone had experienced similar problems.
I have a the intercooled CARB legal kit with a Stage 2 tune from Delicious.
Recently I started hearing a loud chirping when cold starting, when on throttle above 2k rpm and after a downshift while decelerating.
I have already changed out my tensioner pulley to try to resolve the problem, but it started chirping again the next day.
Any ideas? Has anyone experienced this?
I hear a slight chirp as well which is a different chirp than the fuel injectors. I'm thinking it's coming from the intercooler's water pump.
The Following User Says Thank You to stockysnail For This Useful Post:
scionsalesjay (04-26-2014)
Old 04-25-2014, 09:51 PM   #4441
xxscaxx
Drives: 2013 SWP BRZ
If it's the water pump it means you have air in the system and it needs to be bled.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
Old 04-26-2014, 07:46 PM   #4442
scionsalesjay
scionsalesjay's Avatar
Drives: 13' MT FR-S Innovate Stage 2
It is coming from the area around the tensioner pulley.
Thank You guys for the responses.
View my FR-S Build
Innovate Supercharger w/ Intercooler
My members journal: http://www.ft86club.com/forums/showthread.php?t=58728
Subscribe to TuneCast: https://www.youtube.com/watch?v=1vUWK0GqB_Q
scionsalesjay is offline   Reply With Quote
Old 04-26-2014, 07:49 PM   #4443
scionsalesjay
chirp? Can you get a video?
Chirp reminds me of the HPFP cricket noise lol.
You check the oil level in the supercharger?
I will try to get video. My phone just crashed so I lost the video I was going to upload. Does sound like a louder version of the HPFP crickets, but it only happens when at or above 1800 rpm and during cold start occasionally.
View my FR-S Build
Old 04-27-2014, 02:07 AM   #4444
Ryan86
Road Warrior
Ryan86's Avatar
I get the same on start up then goes as the cold start kicks off. Emptied the SC oil and refilled, still there so not the oil.
It's Not the tensioner,
It's not the belt
I'll keep looking and I'll find you Mr Cricket...
Old 04-27-2014, 05:00 AM   #4445
sw20kosh
Drives: 2013 Black FR-S
It's not the belt
It's probably the tensioner pulley. Not the one supplied by the kit but the one you move in order to slip the belt on. I think supercharger systems place too much of a burden on that stock tensioner. That's why people are having chirps even after replacing the pulley supplied by the kit...
My 2 cents
The Following User Says Thank You to sw20kosh For This Useful Post:
scionsalesjay (04-27-2014)
Old 04-27-2014, 03:07 PM   #4446
scionsalesjay
My 2 cents
I noticed MOTOIQ did some changes during installation for fitment. Maybe I will look into that. It started doing it again the day I replaced the tensioner pulley. I am looking into the idler pulley next. Does anyone sell an aftermarket idler pulley if I find out that is what is chirping?
View my FR-S Build
Old 04-27-2014, 03:10 PM   #4447
scionsalesjay
My 2 cents
DO you have crickets while driving?
View my FR-S Build
Old 04-27-2014, 07:35 PM   #4448
Calum
That Guy
Drives: 2013 asphalt FRS MT
Do you own a mechanics stethoscope or even a long screw driver? You can press one end of the screwdriver to a stationary part near each pulley and the other end to your ear to locate which pulley is making the noise.
Sent from my XT1032 using Tapatalk
The Following User Says Thank You to Calum For This Useful Post:
scionsalesjay (04-28-2014)
Old 04-27-2014, 10:35 PM   #4449
xxscaxx
It's not the belt
I have this issue too. Take off the belt, and turn the alternator pulley by hand. Thats where my noise is coming from.
Old 04-28-2014, 04:44 PM   #4450
scionsalesjay
Oh I wouldn't have thought about the alternator pulley but one thing I did notice is when I have the defroster fan on, the squeaking gets crazy. Maybe that might be a sign. Thank you!
View my FR-S Build
The Following User Says Thank You to scionsalesjay For This Useful Post:
xxscaxx (04-29-2014)
Old 04-29-2014, 05:32 AM   #4451
Ryan86
Road Warrior
Ryan86's Avatar
so before sending car into the dealer I ran multiple tests on various tunes from 8.5 up to 8.54, all giving me cel PO016 & C1201.
Ive had to load stock map and bring the SC down to lowest boost possible to run the car on the stock map.
80mm and normal belt.
started up no crickets, which leads me to think the Blue gates could be causing the problem as it is slightly smaller and places alot more tension on the tensioner pulley.
the strange thing is i have run the car for 100km with the stock map, no CEL have come on, which is concerning me.
Car is in at the dealership, hoping nothing serious
The Following User Says Thank You to Ryan86 For This Useful Post:
Lawnik (04-29-2014)
Old 04-29-2014, 11:29 AM   #4452
Ethan
Drives: Subaru BRZ
Mis-fire
I got a CEL yesterday for misfiring or bad coil pack. I am the second person I know of that has had this problem. Does anyone know if it is a tune problem, a problem with the part itself, or something to do with the SC?
Ethan is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
