#869 |
Drives: '13 BRZ Ltd
The 5x100 bearings were known for being weak on the WRX, but they are a good 6-700 lbs heavier than the brz. IIRC that is one of the reasons the STI went from a 5x100 to a 5x114.3 for MY 2005. I had a bearing go in my 2006 WRX at around 50k miles but that was after a good 60-70 autocrosses as well.
There are a lot of BRZ being tracked/autox'd around here and I haven't yet heard of a wheel bearing going.. sounds like something peculiar to orthojoe and his friend. Axles on the other hand seem like they will definitely fail. |
#870 | |||
2013 Subaru BRZ
#871 |
Drives: Some rust bucket
Maybe your Whiteline camber bolts are slipping and causing toe to change as well. Changing camber will affect toe at the front. Not sure why the rear toe would change sine there's no stock rear camber adjustment.
#872 |
#873 | |
You wouldn't expect GMG to be knowledgeable about WRXs, would you? Or Plattforme AG? Or SP Engineering? |
#874 |
Drives: gt86...among others
Hi Mike,
Here at our home track we're being beaten decent drivers in S2K's. Since you drive one (and seem to know a few things about an FRS platform) could you outline some key areas where an S2K outperform's an FRS on track? Obviously weight and revs come to mind first. However, if you feel there are some particular areas where an S2K can be exploited, we'd love to know. GT-B (GT-B in Taiwan is a GT-3 car under 2.3L) S2K's are 5 sec faster then our 86auto. We gotta catch 'em! But where...and how? From a stir-crazy defeated racer; thank you for any help
racing gods live deep in corners
#875 | |
Get to Jaku's level of driving first, and then worry about the car. To put it in perspective, when he was in the states, Jaku ran a best of 2:00 at Buttonwillow 13CW. How many drivers on this board run that in a GT86? The S2000 has SIGNIFICANTLY more power at the speeds your tracks see, and uses more tire. The GT86's advantages only show at higher speeds (80+). |
#876 |
Oh yeah, we're also classed with Supercharged Lotus 3.5's for some reason. So if you have any dirt on them, that'd be great too.
They're 6sec faster then the 86. Just a bit quicker then the S2K's. Here's a video I found of the track record holder in both an S2K and an Elise. Start at 3min mark if you want. Thanks again for any advise you (or any other bored member) have. [ame="http://www.youtube.com/watch?v=a9JgQtTi05U"]2013 TSF R4 台灣大賽車 決賽 (夜賽) - YouTube[/ame]
#877 | |
fwiw, I totally understand everyone's skepticism.
2013 Subaru BRZ
#878 | |
#879 |
The shop I mentioned are all service shops
#880 |
#881 |
I understand/know that.
2013 Subaru BRZ
#882 | |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) General Topics | 20 | 01-10-2012 09:54 AM |
