#15 | |
Drives: FR-S MT & FJ Cruiser
Some will fall in love with life and drink it from a fountain That is pouring like an avalanche comin' down the mountain |
#16 |
Drives: UK GT86
Surprised no one has mentioned tire pressures, would be my first check. Especially if temperatures have changed since you got the car.
.: Stealth 86 :.
#17 |
Wind is devilish with this car. Passing semi's on the interstate when you hit the blast from the front of their vehicle my car moves to the left every time. I vote wind
#18 |
Lug nuts all tight?
#19 |
Drives: Skoda Yeti DSG diesel 4x4
I had this a few times with less than 1000km on the clock but not since. The only conclusion I can make is it was the tyres and now they've bedded in?
#20 | |
Drives: Supercharged Golf Cart
Maybe it's the panels underneath the car?
#21 |
Drives: 2013 BRZ DMG manual Limited
Wind! Happens when I am driving on the H-3 here in Hawaii.
#22 |
#23 |
Drives: Scion FR-S, 1999 Lincoln Navigator
I had this same issue basically exactly what you were talking about. I went to get new tires and I ended up getting the continental DSW tires thinking that it would fix the problem and it didnt. So basically after they were inspecting my rims and discovered that the lower ball joint was really loose so I took it to my dealer and they said it was covered under warranty and I only have 15,000 miles on my fr-s. I would get alot of vibration and wobble and it was especially scary on the highway but basically the lower ball joint is responsible for keeping the whole wheel on the car and if that breaks then bye bye tires and hello accident. I would have them check you lower ball joints to see if there is any play. You probably hit a pothole and it made it loose. Tires do play a huge role in helping the overall drive of your car because I mostly do highway driving as well. It basically looked like I was drunk driving hahaha. Hope this helps brah
#24 |
Drives: Subaru BRZ Limited
I've definitely been freaked out by the amount this car jostles around when it's windy or passing semi's (especially when you get crosswinds when on a multilane freeway). It's even worse when you have a softer compound winter tire, and the steering response gets lazy. That combo can lead to a white knuckle drive.
#25 | |
Drives: 2014 Scion FRS
There has been a few other people here say as well that they found their lower balljoint loose, all on new cars. For sure worth looking into. |
#26 | |
Drives: '13 Firestorm FRS
Or is that you are going straight, and the car seems to follow the road and shift around? If it's the first one, I'd say broken ball joint. But unless you hit anything you shouldn't have any problems with your ball joint |
| Found Loose wire...?? IDK what it is | rikdrt1 | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 06-10-2020 01:42 PM |
| Red stitching is coming loose. | Chip | Issues | Warranty | Recalls / TSB | 7 | 11-01-2012 11:02 AM |
| Fuel Lid Tight or Loose? | JiB | Issues | Warranty | Recalls / TSB | 18 | 09-20-2012 01:50 PM |
| Loose Floor Mats | mact | Issues | Warranty | Recalls / TSB | 0 | 09-15-2012 12:53 AM |
| The ride of the falling leaves | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 10-20-2011 07:45 PM |
