#4397 | |
Drives: 2013 SWP BRZ
I'd suggest Moto's kit too. All plug and play. I may end up buying the one fitting needed for my kit to plug it into the stock line but right now i've had no issues so I can't complain. For the price of the Prime Motoring one you can't go wrong. |
| The Following User Says Thank You to xxscaxx For This Useful Post: | Dustin (04-19-2014) |
#4398 |
Someone should try this and see if it clears the OEM hood and if it adds power:
http://ft86speedfactory.com/crawford...lock-1558.html
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#4399 | |
I already said something to crawford about making some for us, they were apparently going to get in contact with someone for the measurements of hood clearance on the SC and see if they could make something. May have a little more room with the smaller pulley but those are definitely too big to run with our SC. I was hoping for something like 3mm or smaller, if only for heat purposes. |
#4400 | ||
Grip>Slip
#4401 |
Drives: 86
#4402 |
| The Following 3 Users Say Thank You to xxscaxx For This Useful Post: |
#4403 |
Drives: 4 wheels
What tower bar fit with innovative supercharger? I know the cusco fit, but I am wondering what else.
Pekingduck's Build thread http://www.ft86club.com/forums/showthread.php?t=5717
#4404 |
#4405 |
Grip>Slip
#4406 | |
![]() I tried to order black but they were going anodize an already machined unit and I would lose all the shiny machined edges. Apparently this is a prototype. You need the 25mm spacers. |
| The Following User Says Thank You to Assunta For This Useful Post: | xjohnx (04-22-2014) |
#4407 | |
Grip>Slip
#4408 |
No that wasn't me actually lol. I can't recall who it was but they drilled and mounted the coolant reservoir to the tie bar in the back. I'm thinking about using some SS flat stock and just moving the coolant bottle back towards the firewall.
They have the non-ic setup on that speedhunter car too. The ground control setup works but remember thats using the camber plates up front, PLUS that spacer. I bought a GT Spec strut bar thinking it would fit since its cusco style, but it doesn't. I'm debating on getting a new bar or maybe getting spacers made or something to make this one fit. Not sure yet. |
#4409 |
Drives: 86
Has anyone received Bill's ( @DeliciousTuning ), 8.54 tune yet? I realize he's been busy and moved locations, but it's been close to 3 weeks now. My car gets a lot of garage time, because I'm just not 100% confident in the 8.51 tune.
#4410 |
I put in a request for it but knew prior that the flexfuel map was a little behind the standard pump gas maps in regards to release time. Haven't heard anything though. I know @Ryan86 has it, but not sure if anyone else does.
8.52 seems great to me, surprised you weren't at least updated to that revision. |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
