Old 04-18-2014, 03:11 PM   #1
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
FA20 Engine Oiling, Bearings, and Starvation
So as we embark on our racing program for the FRS/BRZ we knew oiling would become a major issue when running high RPM and high load cornering (Think 1.7+ G sustained). Much of what we've see on this engine compared to the EJ is very positive. Better head drainage, nice deep sump, and a 12mm pump gear.
With high oil temps on track people have already recorded oil pressure drop approaching the OEM redline. Clearly when boosting the first step is to run forged internals.
The powerband of this engine falls hard so we needed to pickup our powerband so big valve headwork was performed. Pulls like a freight train to 9k rpm now!!!!
Having faced serious cooling issues last year, it was straight to the racing parts I use on my STi and a serious radiator was fitted.
Now onto the issues but keep in mind we are running up to 9k RPM and running 325 Pirelli non DOT racing slicks with high downforce. We pretty much instantly oil starved the bearings under race conditions on a track known for tearing up motors due to long high G turns.
Look at the FA20 crank mains and the rod journals and you should spot something unique where I oil starved the rod bearing. The third main from right to left has a larger oil port. Why? Because it has to feed two rod journals where all others only feed one rod journal. What happens to oil pressure when you increase the oil port size? What happens to your oil volume requirements when you need to feed two journals with one main? Guess which one failed?
Now that's not to dissimilar to the EJ motors with how the mains feed the rod journals but the major differences are that on the EJ two oil ports in the block feed the mains where on the FA, one port feeds all the mains. On the EJ the oiling ports for the mains are opposed (two on each side) and on the FA you can see all oiling ports to the mains are inline. Now you would think on the FA, this is better and more direct as the EJ has to travel through the block farther even though it splits it's oiling.
Overall I think the FA has some major advantages but I think maybe we see on major difference which may lead to more pressure issues at the crank. On the EJ motors the oil pressure first feeds your crank and rods and then travels to the heads but on the FA the heads are feed simultaneously with the crank and rods. I'm not sure if Subaru needed more oil feed to the heads for the newer cam setup or they just wanted more direct flow to each.
My bearing failure is not black and white unfortunately. We know it's oil starvation but I was also running a ton more RPM than I was last year. We need to retest and note the pressures we are seeing and at what rpm they fall while on the dyno. This should show the merits of the oem pump which is 12mm. This will determine if we go with a 2 stage scavenge dry sump or if we need to go to a 3 stage pressure. In the racing environment g forces and aerated oil add to the demands a street car may never face.
Let me remind you 325 racing slicks and over 1000 lbs of downforce.
Many of you will never face this problem but should you choose to go with headwork you may have an issue purely based on RPM. Also note I was class limited to 390 whp so I wasn't running any crazy amount of power.
I figured I would share some of the issues we are facing with this engine and hopefully we'll come up with a solution or the other companies will. So far from what I'm seeing the pan designs out there aren't going to help as they are not concentrating the oil around the pickup, they are simply widening the oil pan which I think will only make it worse on track cars.
Thanks,
Phil Grabow
Element Tuning is offline   Reply With Quote
The Following 61 Users Say Thank You to Element Tuning For This Useful Post:
2013GTRNate (02-23-2016), @Art_Mighty (10-19-2014), AndyBRZ (10-19-2018), arghx7 (04-18-2014), Astroboy (08-30-2015), ATL BRZ (04-27-2014), BatStig (04-18-2014), Black Tire (06-05-2014), Bonburner (03-18-2015), Boofneenee (04-18-2014), Boris_Petrov (03-18-2019), Bristecom (05-05-2014), Calum (04-18-2014), charged86 (07-07-2014), CircuitJerk (04-19-2014), civicdrivr (08-21-2014), Creole (06-05-2014), DAEMANO (06-21-2015), Dezoris (07-26-2014), Dimman (04-18-2014), disgruntld (08-25-2014), diss7 (04-21-2014), flippy (08-21-2014), Floggin Tires (04-18-2014), GhostOp86 (06-29-2015), gonzo (08-21-2014), GT86_PRAGUE (12-18-2014), illmatic (04-18-2014), industrial (04-18-2014), jbailey8748 (06-10-2015), JMon85 (06-12-2018), JP (04-20-2014), KoreanJesus (12-14-2018), Kris86 (07-19-2016), litemup (08-20-2014), Lonewolf (04-18-2014), Mikem53 (06-05-2014), mwjcyber (07-29-2014), new2subaru (12-27-2015), Ornelas66 (04-05-2015), P@ul (12-18-2014), Panda Mao (04-18-2014), Proof (04-18-2014), Rayme (04-29-2014), romin (10-19-2014), Shagaliscious (04-18-2014), SirBrass (04-26-2014), snuff58 (06-28-2020), SportInjected (04-18-2014), Sportsguy83 (04-19-2014), Superhatch (09-28-2014), Surok (03-22-2018), ThatAsianBradah (02-09-2018), Tristor (10-15-2018), Turdinator (04-19-2014), Tye300 (06-05-2014), whataboutbob (09-10-2014), WolfsFang (04-18-2014), xkalelx (09-05-2016), yo joshman (07-20-2015), zkv476 (10-28-2014)
Old 04-18-2014, 03:48 PM   #2
arghx7
Drives: car
I haven't looked deeply into this, but would oil pan baffling be an option?
Old 04-18-2014, 04:20 PM   #3
chiefshayan
chiefshayan's Avatar
Drives: 2013 AT Firestorm FRS
Is this the car that caught on fire? What was the reason?
chiefshayan is offline   Reply With Quote
Old 04-18-2014, 04:27 PM   #4
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Sucks to see this.
Good to know you are working it out.
Thanks for sharing your development.
Will be watching.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Old 04-18-2014, 05:06 PM   #5
Element Tuning
Yes it would definitely help as there is none currently around the pickup.
Old 04-18-2014, 05:10 PM   #6
Element Tuning
Yes she has risen from the ashes
We haven't pulled it down yet but it was a chain reaction fire, oil, plastic, fuel lines burst. I can tell you the rods let go but that's about it.
The Following 2 Users Say Thank You to Element Tuning For This Useful Post:
Boris_Petrov (08-23-2019), chiefshayan (04-18-2014)
Old 04-18-2014, 05:10 PM   #7
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
I love your car so much for the simple fact you dident do a engine swap like everyone else.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
The Following 9 Users Say Thank You to WolfsFang For This Useful Post:
blackfireball5 (06-03-2014), Boris_Petrov (08-23-2019), cdrazic93 (06-03-2014), codesplice (04-18-2014), DAEMANO (06-21-2015), Element Tuning (04-18-2014), GT86_PRAGUE (12-18-2014), Rampage (07-07-2014), SirBrass (04-26-2014)
Old 04-18-2014, 05:14 PM   #8
chiefshayan
Awesome! Can't wait to see what new data/projects you bring to our platform. Glad your back!
Edit: Would it possible to post a picture of how the engine currently sits?
Old 04-18-2014, 05:24 PM   #9
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
good info guys. i was running njmp last Sunday swinging around this large light bulb shapped turn in 4th gear wondering if my heads are draining oil back good lol
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 04-18-2014, 05:25 PM   #10
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
More info on that roll bar setup please?
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 04-18-2014, 06:58 PM   #11
Tainen
Drives: First SWP BRZ-L
How have you gotten around the electric power steering overheating after 1.5+g loads?
Also I'd LOVE more information on the rebuild after the fire!!! Extremely interested in your decisions you've made (been following your subie builds for a loooong time), as they've influenced my buying and setup decisions before.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
Old 04-18-2014, 08:23 PM   #12
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
Thanks for sharing! Glad to see you guys aren't giving up.
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 04-18-2014, 08:56 PM   #13
Element Tuning
Thanks. The current engine is the one with the spun bearing, forged internals, and the head work. The plan was to race it in a 7.5 power/weight ratio class until we decided to drop coin on a beefed up driveline.
We have more pics over on Facebook and some on our "track build thread."
The Following User Says Thank You to Element Tuning For This Useful Post:
Old 04-18-2014, 08:58 PM   #14
Element Tuning
Oh that turn is an engine killer! The oem setup is overall very good but it's no match for a professional race setup with wide slicks and downforce.
FA20 Engine component photos Crawford FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 89 02-22-2016 03:31 AM
FA20 Engine component photos Crawford Engine, Exhaust, Transmission 46 01-26-2015 06:19 AM
Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. FRSport.com Engine, Exhaust, Bolt-Ons 0 01-10-2014 01:33 PM
FA20 Le Mans Race Engine SilverSkyline210 Engine, Exhaust, Transmission 11 11-18-2013 12:24 AM
