Old 04-14-2014, 06:55 PM   #71
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Originally Posted by 1Cor10:23 View Post
The old crappy ones (12-13)
You had me all excited for changing the boot screen 😭
Old 04-14-2014, 07:00 PM   #72
samisons
Drives: 2013 Raven Fr-s, 2013 Versa Sedan
you get cock Blocked if You stand next to the Car with your date and a Car Person sees you .
samisons is offline   Reply With Quote
Old 04-14-2014, 07:01 PM   #73
westendRIOT
Drives:
Originally Posted by Mikem53 View Post
- Turn on the car. The car must be FULLY warmed up. You must do the entire sequence within 30 seconds of starting the car.
- Pull the e-brake 3 times. Hold/lock the e-brake on the 3rd pull.
- Press the brake pedal 3 times. Hold it down the third time.
- Pull the hand brake 3 more times. Hold/lock the hand brake on the 3rd pull
- Press the brake pedal 2 more times.
- On the last press of the brake pedal, two yellow lights should have come on.
Best used ONLY for track use!
Why must the car be fully warmed up?
westendRIOT is offline   Reply With Quote
Old 04-14-2014, 07:12 PM   #74
retrosmiths
Drives: Scion FR-S Whiteout
Because.
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 04-14-2014, 07:34 PM   #75
Ponwh
Drives: 4 wheels
It doesnt have to be.
Ponwh is offline   Reply With Quote
Old 04-14-2014, 07:53 PM   #76
stugray
Drives: 2013 GBS BRZ Limited
It DOES have to be warmed up (fully is how much?).
It is part of the conditions to be met for the car to enter diagnostic mode (what you are in if you successfully execute the 'pedal dance').
Why? Who knows. Maybe it was to minimize the chance that someone stumbles across it messing with their car in the driveway?
Old 04-14-2014, 09:27 PM   #77
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
I believe some Scions will apply to this.
At least the ones with door handle lock unlock sensors.
On Limited BRZ's
Factory settings:
When you touch the inside of the handle to unlock the door,
it unlocks the drivers side only. If you want both driver and passenger
side to unlock with a single touch of the handle, do as follows.
Open The driver door,
Leave the car off,
On the key fob Hold down both Panic and Lock buttons for ~5secs.
When you let off you should hear a beep.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Old 04-14-2014, 09:46 PM   #78
Tromatic
It didn't work for me when cold. How warm is warm? Dunno.
Old 04-14-2014, 10:44 PM   #79
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Operating temp
Old 04-14-2014, 11:24 PM   #80
twag4
Drives: frs
- You can also set the gear indicator (Google it!), but it's not "real-time" that it needs a couple seconds to register.
The gear indicator displays the gear number selected when the clutch pedal is released. It is real time if you aren't on the clutch pedal.
twag4 is offline   Reply With Quote
Old 04-15-2014, 12:48 AM   #81
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
Great thread. I really didn't know some of this stuff. Thanks. Now I know what gear I'm in just by looking at the tach.
Here is a small thing. The glow in the dark trunk release inside the truck (just in case you forgot you put someone back there, or it closed on you while you were in there) has a way to be attached so it isn't dangling. Make sure that you flip it so you can see the writing on it, and then snap it into place.
DrDuquette is offline   Reply With Quote
Old 04-15-2014, 09:07 AM   #82
Chattanooga FR-S
Chattanooga FR-S's Avatar
Drives: Monogram Firestorm
On Limited BRZ's
Factory settings:
Leave the car off,
I just checked and this worked on my Monogram. Thanks!
Chattanooga FR-S is offline   Reply With Quote
Old 04-15-2014, 11:21 AM   #83
userjack6880
userjack6880's Avatar
Drives: Raven FR-S MT
The FR-S comes with bandaids. You can patch yourself up when you cut yourself on the piece of plastic right next to the oil filter... trying to take out the oil filter. Or putting it back on.
2013 Scion FR-S - Build Thread
2015 Ford Mustang GT
1978 Triumph Spitfire 1500
userjack6880 is offline   Reply With Quote
Old 04-15-2014, 12:43 PM   #84
JR007
JR007's Avatar
Drives: Ultramarine FR-S
helpful info...thx.
JR007 is offline   Reply With Quote
scion brz hidden features
Ideas for a hidden magnetic phone-mount. MmmDieselFumes Cosmetic Modification (Interior/Exterior/Lighting) 40 05-09-2016 01:14 PM
Bespoke A/V Hidden Option UbSaMrC Electronics | Audio | NAV | Infotainment 58 12-13-2015 11:14 PM
FS: Custom Stainless Lightweight Hidden Hitch that_guy Canada Classifieds 3 06-11-2014 07:13 PM
Hidden Rusting issue FRSHunter Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 04-07-2014 05:02 PM
DIY: access hidden menus on BRZ head unit robot DIY (Do-It-Yourself) Guides 0 10-22-2013 11:59 PM
