Old 04-13-2014, 08:32 AM   #1653
shif7i7down
Erected Member
Drives: frs
@solidONE keep at it mate, we need more people like you who is willing to do some R&D.
Report back with your findings bro, I'm interested.
shif7i7down is offline   Reply With Quote
Old 04-13-2014, 12:58 PM   #1654
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Latest Datalog of Stage 2 EL Header Custom 3 with FA20club CAI.
http://datazap.me/u/tonystewart/apri...3?log=0&data=1
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 04-13-2014, 01:30 PM   #1655
Cross
It's the Mad Cow
Cross's Avatar
As has been pointed out MBT is going to be a major concern as an example before I started tuning my Vette a tuner just put it to 32 degrees and left it. Thankfully one of the better tuners took the time to pass on some information about MBT and share some common facts on that platform. Going to 26 and working my way up I found 28 to be the best. I did my testing at the track using trap speeds but the process proved what I had been told.
E85 NA is really hard to mess up, FI not so much.
However now with years of testing I found that 12.2 - 12.6 to be the best range. 12.3 - 12.4 have always felt the best and now that you can log AFR via wideband you can really dial it in. However with my testing on the FRS being cut short in favor of a turbo setup I didn't get to test my tune at the track or on the dyno with the AFR changes to prove the same being true of this car.
Sent from Spaceball 1
Old 04-13-2014, 01:57 PM   #1656
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
E% variability doesn't really have much to do with my last post. You can tune well beyond MBT (in NA application) with far less than e85. I suspect e40 would give enough octane to allow you to run a too aggressive (power robbing) tune without even knowing it from logged knock retard. This is why dyno tuning is key for custom e85 tuning for more power.
Shiv@Openflash is offline   Reply With Quote
Old 04-13-2014, 04:44 PM   #1657
gonzo
Drives: frs
does this mean we could run your e85 tune down to e40? I know you've said its safe down to e60.
would mixing 91 into the e85 tank bring my fuel trims into negative and help my mpg without affecting power?
gonzo is offline   Reply With Quote
Old 04-13-2014, 06:50 PM   #1658
SilverFoxBRZ
BRZ Jockey
Drives: 2013 BRZ LTD 6MT Sterling Silver
XDF File for TunerPro
When/why did this stop being included with the OTS maps? I had to go back to the download of the 1.42 maps to find it. Good thing I'm smarter than I look.
SilverFoxBRZ is offline   Reply With Quote
Old 04-13-2014, 07:05 PM   #1659
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by Kodename47 View Post
0.8 lambda is 11.76:1 AFR on gasoline so based on that it looks like you want targets of around 11.7-12. I have absolutely no idea of what is ideal though and as Shiv has said, you can hit MBT with Ethanol so without real testing it's not ideal.
General consensus is that if you start advancing timing and the power gain is minimal without knock, you're around MBT and it's best to back off the timing to the last known with the biggest gain. This is done for reliability rather than searching for that last few bhp. As Shiv has done his testing, I wouldn't go too mental.
It's also going to be difficult to do any form of MAF scaling/calibration if the E% content is varying.
Can you post your sources? Everything I've read suggests that ideal AFR for E85 to be around 12.5:1 if not leaner for maximum power (also same goes for na gasoline tunes). Under low load cruising conditions anything from 15:1 to 16:1 can be run safely on E85, I've also read. This is also ideal for the pocketbook, since leaner usually means less fuel consumption. And it's good for the environment and stuff.
Old 04-13-2014, 07:53 PM   #1660
steve99
Drives: FT86
Exactly what I am finding, their is so much information out there , often contradictory that its hard to work out whats right and wrong. I try to dig up info from persons who actually have tuning experience on the fa20 but they are few and far between and even fewer will actually release anything useful as its their income stream and that's fair enough.
Old 04-13-2014, 11:14 PM   #1661
solidONE
solidONE's Avatar
Yeah. To be fair, every engine is different, there is a chance that this FA20 likes to be run richer than the typical engine. Only one way to find out for sure, right?
Old 04-14-2014, 12:41 AM   #1662
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Anyone want to let me know how these look?
First log after flashing
http://datazap.me/u/andrew025/oft-ot...4?log=0&data=1
12 days later
http://datazap.me/u/andrew025/4-12-2...8?log=0&data=1
Old 04-14-2014, 02:30 AM   #1663
steve99
Drives: FT86
yep your right, I suppose I am the cautios type, who looks to the pioneering type to head off into the unknowthey do seem to like running rich though i leaned off my gass tune a few % and it knocked like crazy was 11.8 did not like 12.5 not on our fuel anyway
Old 04-14-2014, 04:03 AM   #1664
solidONE
solidONE's Avatar
I advanced the timing about a degree at the higher load and RPM areas to the OTS E85 rom and went and took some logs again. Also fueled up right before like the other times. This is what I got compared to the best pull I did on the OTS map and a bit more learning.
As you can see, there appears to be a bit of increase in power at the 5800-7100rpm range. Pretty cool stuff. I will need to dial in the maf scale more at the low voltage range, it looks like. I will try to log some more pulls tomorrow to confirm results.
Old 04-14-2014, 06:44 AM   #1665
s2d4
s2d4's Avatar
Is virtual dyno a substitute for a real one?
Sent from my Galaxy Nexus using Tapatalk
Old 04-14-2014, 10:37 AM   #1666
Kodename47
Kodename47's Avatar
Drives: UK GT86
If used correctly, as above, then you can get good comparisons. As for actual figures etc, no.
.: Stealth 86 :.
Kodename 47 DJ:
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
