Old 03-21-2012, 05:23 PM   #43
Lonewolf
Lonewolf's Avatar
Drives: Moped
Originally Posted by serialk11r View Post
Manual transmission has same ratios as the S15 Sylvia (6th gear is 0.767), auto has same ratios as IS250 or something (evenly spaced, starts at ~3.6-7 or something, 6th gear is 0.582, 4th is 1.000), both are 4.100 final drive in the US. Markets with the stripper model have a 3.727 open diff option. The 6th gear in the manual transmission revs 30% higher than the 6th gear in the auto, which a lot of people are kinda upset about.
It's been posted at least 20 times already...it came out with the BRZ specs/options brochure in December/January ish. You seem like you usually post good stuff, I was hoping you'd find it in a search.
I saw some numbers thrown around like that...but I didn't know if they had been confirmed for the US market and if the same numbers also applied to the FRS...
That is exactly the type of info that I was looking for...thank you :happy0180:
Old 03-21-2012, 05:39 PM   #44
dhpinoy
Undecided Color for FR-S
dhpinoy's Avatar
Drives: Jeep Liberty, Scion xA
Originally Posted by 7thgear View Post
for fucks sake, did you not bother to read the technical discussion posts right above you?
like i said, "dumb person". I barely understood (understand now, but I dont get the diagrams). I'm still goin to school
dhpinoy is offline   Reply With Quote
Old 03-21-2012, 05:47 PM   #45
serialk11r
Drives: '06 AM V8V Coupe
Okay, it's like this. An automatic transmission these days controls the engine and gearbox together, so the gearbox can shift up very early and operate the engine more efficiently in the EPA test, where a car is required to accelerate at a predetermined rate at any given time. The manual transmission however is to be kept in the same gear until some speed, which could be much less efficient. Thus an automatic wins out in the EPA test, while in the real world normal drivers can do just as well with a manual transmission typically speaking.
Basically what it comes down to is, a manual transmission's fuel economy depends more on the driver. The computer is not necessarily "better" at shifting the gears for you (aside from the fact that it shifts faster), since the way it's programmed is a compromise.
Old 03-21-2012, 06:14 PM   #46
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Auto and manual have the same final drive ratios (4.10:1).
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 03-26-2012, 10:32 PM   #47
Allch Chcar
Drives: N/A
Jeff
Negative. They have the same axle gears, 4.1. The Final drive is taller in the automatic. 3.14 for the manual vs 2.39 for the automatic. (Approximately based on the previously posted numbers, I don't have them memorized.)
I don't know about the typical driver but ecomodders and hypermilers tend to do better with the manual, despite the gearing disadvantage. For MPG, control is huge. Which is also why the autos get better scores on the EPA cycle.
Thanks for the writeup arghx7. It didn't interest me but hopefully that helped a couple of the guys understand it better.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 03-26-2012, 10:43 PM   #48
serialk11r
Um Allch Chcar, I thought final drive typically refers to axle ratio?
Old 03-26-2012, 10:54 PM   #49
dsgerbc
Drives: BRZ(sold), STI
He probably means "tranny ratio in 6th X rear diff ratio". I have heard people refer to that as "final drive ratio", although usually I'd associate it with rear diff ratio.
Old 03-26-2012, 11:27 PM   #50
Jeff Lange
Jeff Lange's Avatar
Common terminology refers to Final Drive Ratio as the Axle Ratio, it applies to all gears.
Effective 6th gear is what you are referring to, as that multiplies transmission/axle ratio.
Jeff
Old 03-27-2012, 05:44 PM   #51
Allch Chcar
Drives: N/A
Jeff
Yep, that's right.
I misspoke. Must have been an off day. <.> *derp*
-Allch Chcar
Old 05-07-2012, 05:59 PM   #52
serialk11r
Well well well, Pekingduck has finally got us some real numbers to play with!
He said he averaged 29.5mpg on a mostly highway at 85-90mph (holy shit) trip, and 39mpg on a mostly highway 70mpg trip. Put through the ecomodder calculator, these points basically match the 1NZ-FXE's equivalent load BSFC points, and considering that his car is brand new and will probably pick up a few percent higher efficiency as he drives it, I think this is reason to celebrate Going off the 1NZ, 65mph should give 42mpgish, but it could be even better than that :O
The real interesting thing will be to see how this engine behaves under very low load, but I feel like they're never going to release a BSFC map
I think a 6th gear right in between the manual and auto 6th gears would be worth trying, with 15% longer 6th gear and looking at the same range of points that apparently approximately match the 1NZ-FXE, we can expect the difference to close to within 7% at the engine, 6% minus AT parasitic load 46mpg 65mph cruise anyone?
Old 05-07-2012, 06:22 PM   #53
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
Very interesting indeed. Hopefully his numbers are typical, and the EPA estimates are very pessimistic [as I was hoping].
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 01-16-2021, 12:44 PM   #54
Nibby1
Drives: Scion FRS
Throttle accelerator modules
Anybody ever try or using an aftermarket throttle accelerator module?
Nibby1 is offline   Reply With Quote
Old 01-16-2021, 03:11 PM   #55
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Old 01-16-2021, 03:57 PM   #56
churchx
churchx's Avatar
Drives: 2014 GT86
You shouldn't. If you want more performance, see some ecu tuning solution (eg. OFT or Ecutek) (and throttle pedal mapping even stock is not too linear to open throttle much more in initial travel. Not sure it's worth to make it even less linear and further rob throttle fine control by those .. "modules").
auto, consumption, manual, mpg, transmition
FR-S to BRZ Ratio MannyO New England 11 03-08-2012 03:23 AM
Brz Production Numbers WRB Bandit BRZ First-Gen (2012+) — General Topics 29 03-07-2012 10:53 PM
Any Idea of U.S. Pre-Order Numbers? markemark24 Scion FR-S / Toyota 86 GT86 General Forum 1 02-21-2012 01:29 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 02:21 PM
86,BRZ MT gear ratio Yobiwan Engine, Exhaust, Transmission 1 01-26-2012 03:40 AM
