Old 04-09-2014, 08:22 PM   #603
JS + BRZ
Drives: 2010 MS3
Hope this is the right section to post this..
Any suggestion from you experts to improve my driving at the track?
This was my first time out at the track with the new wheels and tires. I felt like whenever I pushed the car a little too much, it was about to "snap". I should push more and counter that "snap" to go faster, correct?
Thank you guys!
[ame="https://www.youtube.com/watch?v=n9ry-PV6V28"]04/05/2014 Chuckwalla Valley Raceway _ 2nd Session - YouTube[/ame]
Old 04-09-2014, 08:36 PM   #604
CSG Mike
CSG Mike's Avatar
^ Use more of the track. You leave a lot of room when you miss the apex by 5+ feet, and don't use the full track out on every turn.
Old 04-09-2014, 08:43 PM   #605
JS + BRZ
Drives: 2010 MS3
Made perfect sense.
Thank you!
Old 04-09-2014, 09:48 PM   #606
araines2010
Drives: 86 GTS
Hi,
Any one with experience of mid corner issues with oem tyres on 17x8 rims? i.e. tyres rolling off the rim etc.
araines2010 is offline   Reply With Quote
Old 04-09-2014, 10:14 PM   #607
Pat
Pat's Avatar
Drives: 2023 BRZ
Why are open ended lug nuts better than closed?
Old 04-09-2014, 10:17 PM   #608
CSG Mike
CSG Mike's Avatar
Originally Posted by araines2010 View Post
Hi,
Nope
Old 04-09-2014, 10:18 PM   #609
CSG Mike
CSG Mike's Avatar
They're not "better", but they're more flexible in allowing for varying spacers with extended studs.
They do let water in between threads, but they also allow for release sprays to get in as well.
Old 04-09-2014, 11:46 PM   #610
u/Josh
Drives: GBS Limited 6MT
I did a track day this past weekend and I noticed that on a particular corner almost every lap the car would flash one of the dash lights. I don't think it was one of the two traction/stability lights (although it could have been the slip light), and I didn't feel the car intervening at all. This doesn't seem like the issue that is fixed with the pedal dance because as I said, a light flashes rather quickly, it doesn't stay solid. Anyone else experience this?
I was running with all aids off (three second press, not pedal dance).
u/Josh is offline   Reply With Quote
Old 04-10-2014, 01:51 AM   #611
kavanagh
Fat on Corn Syrup
Was great seeing you out there Josh!
Which corner was it? I got it in turn 11(?) last 180 before the pit exit and start/finish.
Old 04-10-2014, 03:06 AM   #612
CSG Mike
CSG Mike's Avatar
That's the electronic diff kicking in. Do the pedal dance. Otherwise the bacon may narwhal at noon.
Old 04-10-2014, 03:31 AM   #613
araines2010
Drives: 86 GTS
Lol cheers
Old 04-10-2014, 02:07 PM   #614
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Ice mode is engageed when you go from gas to MASHING the brake pedal VERY quickly.
I've never engaged it under normal driving, even when I'm doing for hot/record laps. I can force it to happen, but I also need to go DEEP into ABS engagement to do so.
Correct, everything is disabled except the ABS.
Thanks for the explanation of the root cause.
But.... what Is Ice-Mode, and what does it do exactly??
I keep reading/hearing about it ..but idk what it even does, or what happens when it activates, lol.
fooddude is offline   Reply With Quote
Old 04-10-2014, 04:00 PM   #615
CSG Mike
CSG Mike's Avatar
The car basically reduces braking force to something like 30%, to prevent skidding on ice. It boils down to you won't slow down like you normally will.
Old 04-10-2014, 05:42 PM   #616
fooddude
Woah...sounds very dangerous indeed.
Starting to hate these electronic aids the more and more I read about them, lol.
Hopefully someday soon, someone will make a device or tune that will completely and permanently disable all aids, tc, vsc, ice mode, etc...leaving you with a fully analog rwd drivetrain (sans abs).
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
