#967 |
Drives: Yes
Great job and thank you for posting your vid and recap!
I'm running the Yokos as well (though 225/45), but I've struggled to get a solid, clean run on them at each event. They're at least equal to the Z2, but I feel like they are not quite as forgiving. That said, they FEEL like the best street tire I've tried, but I just can't tell if they're actually faster than the Z2 (I have not driven on Rivals). On the Yokos, I've spun and coned more times in my first five events this year than I did all of last year. Also, the highest temperature we've seen for any of our events has been 55 degrees with most being 40-45, so a warmer day should help? I have to wait for the DC Pro and NY/NJ Tour to see where I'm at compared to the hotshoes. Any suggestions for decent lug nuts? I'm putting my ARP wheel studs on next week and will probably need another spare set of lug nuts. |
#968 | |
DBC Racing
but i personally couldn't give you a definite answer since i have not driven in conditions such as that http://www.arkdesign-us.com/wheel.htm we use these lug nuts.
#194 SM
#969 |
I had someone come over to my car at a National event a few years ago and ask me not once but at least three times if I had adjusted my waste gate on my Genesis Coupe even though it had the factory paint mark perfectly intact. Not only that but he was also going around to other competitors with the same vehicle and trying to rally the troops so to speak. One of those people happened to be my friend and come over and inform me about it. Not sure why people like that think asking a second or third time is going to change the answer but it certainly was annoying. Not too long later they come over to ask me if they can drive my car because their car was having problems. So either that person decided they needed to know if my car was setup better and lied about the mechanical or they really did have problems in which case they shouldn't have asked me if I was cheating over and over again as they probably would have gotten to drive my car. Magically though they got the issue resolved within a minute or two after me saying no to the co-drive and still got his run in. Fortunately, I had the opportunity to compete against that same person in RTR in the same type of car since then and handily beat him...ironically he didn't come over to go through my car with a fine tooth comb though haha.
On a side note, I have used a few different brands of aluminum lug nuts and my favorite thus far are Buddy Club. Last edited by TRev; 04-10-2014 at 05:39 PM. |
#970 |
DBC Racing
![]() we are ready for this weekend's protest LOL
#194 SM
#971 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
Yes! Ready for the idiocy
Take many pictures of your "OS Giken" differential tear down and rebuild
#972 |
Drives: BMW 135i, soon to BRZ
#973 | |
Drives: Subaru
2 socket wrenches on a nut. If 18mm/19mm wrench on the nut is set to tighten, what should the smaller 9mm adjustment nut wrench be set on (loosen/tighten)? |
#974 |
Drives: Ultramarine
Guys I need some help with my setup, I installed koni's and crash bolts about a month ago, I'm running stock rims with rs3 tires. In the event a month ago I loved my setup, car turned and rotated on command. I ran my tire pressure around 30-32 psi. I installed the Strano sway bar this past week, stock end links. First run out I had front koni's 1 turn from soft rear full stiff. Tires all at 31. Push push push. Changed front to full soft, push push push. Then with the recommendation of our local pax winner. Turned rear pressure up and front down, by the end of the day I had the fronts at 28 and rear at 42. Tires are 225 45. It wasn't pushing too bad on my final run, but I may have just been giving it up early. Any advice would be greatly appreciated. Last event I finished 9th this one 32nd.
#975 | |
Lost in Kansas
Drives: 2013 Scion FRS (Raven)
#976 |
Drives: 13 SWP BRZ
New tires for the weekend. 245/40/17 ZII,
![]() No weight on the tire in this picture. |
#977 | |
The Stig's German cousin
1. Unless you're the Stig, your performance will vary from weekend to weekend based on how well you "get" the course, surface and weather conditions, Venus/Jupiter alignment, etc. 2. I feel you've gone the wrong way on pressures. What you're doing is an old FWD trick to get a car to rotate by inflating the rears so much they start losing grip (one that I, as a former FWD owner, never personally believed in, but I digress). Here's a good primer on tire pressures: http://farnorthracing.com/autocross_secrets12.html If I was at 32psi in the front and dealing with push, I'd increase pressure in the front, not decrease it. That's just me, and I'm atypical from most in that I tend to prefer rather high pressures, but dealing with a lack of grip in the front by taking grip away from the rear is rarely the right answer. Given that we have a 55/45 F/R weight distro, 42psi in the rear is going to turn the tire into a torus and reduce grip. |
#978 |
That doesn't look excessively bulged out. Do 245s really work better on the 7" rim than 225s? Andy Hollis did a ton of testing that suggested this wouldn't work, but this was with 15" diameter wheels and higher aspect ratios than we use.
#979 |
Overthinking it
Drives: BRZ in CS
I'm running 33f / 32r on stock shocks, crash bolts and rivals. That's where I'd start with a new tire setup on this car.
#980 | |
Drives: Ultramarine
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 05:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 12:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 08:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 01:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 10:03 AM |
