Old 04-09-2014, 09:00 PM   #1
ddeflyer
Experiences with aftermarket tow hooks
Hi, I've been tracking my BRZ a few times at HPDE events. Every time I put the stock tow hook on the car, sometimes front, sometimes back. I am worried though that I only have one end covered in case I taste the kitty litter. So I'm wondering, what tow hooks or straps do people use? I want to make sure that whatever I get is honestly strong enough to tow the car with (I've read people guessing that some aftermarket tow hooks aren't strong enough to be functional). I'm not sure that looks matter too much so long as it is good and visible to the tow truck driver on a hot course (doesn't take that long to put in and take off) though I wouldn't mind not having to deal with them every time.
From what I have found, my options are:
1. Get some more OEM hooks and rattle can then red
2. Tow straps that I hide with the plastic covers when not at the track
3. RaceEng ones
4. Cusco ones
5. Godspeed ones
6. ? Something else ?
Anyway, I'd appreciate people sharing their wisdom on this topic, like so many things it is quite confusing. Also, cost isn't the biggest thing (I'm putting plenty of money into this sport already) though I certainly don't mind saving a few dollars.
Thanks
ddeflyer is offline   Reply With Quote
Old 04-09-2014, 09:06 PM   #2
CSG David
CSG David's Avatar
Thought about making a nice one...if there is interest...it can happen...
The Following User Says Thank You to CSG David For This Useful Post:
enjoi23 (06-14-2015)
Old 04-10-2014, 01:16 AM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I have the @Raceseng Tug View mounts, simply because I wanted the ability to have tow with a GoPro mount.
The shaft also allows the Universal Plate Mount to be used on the car, so I can swap easily on the front end between my license plate mount, and the tow mount to/from the track.
Same setup on rear, this way I have both ends covered.
Tug View review: http://www.ft86club.com/forums/showthread.php?t=53205
UPM review: http://www.ft86club.com/forums/showthread.php?t=53203
-alex
Old 04-10-2014, 12:45 PM   #4
Thongpocket
Master Troll
Thongpocket's Avatar
Drives: 2013 BRZ Limited
I have the Cusco tow hooks and they are QUITE substatial. I think they would get the job done no matter what.
Thongpocket is offline   Reply With Quote
Old 04-13-2014, 03:37 PM   #5
ddeflyer
-alex
Thank you for your response. Those Raceseng setups look pretty nice. Is the license plate holder hard to get on and off? I have the grimmspeed one on my car now and it is a PITA to take on and off (have to remove the plate and then unbolt the center shaft to get it off).
Additionally, is the color of the Raceseng tow hooks as fluorescent as the pictures show? The candy color of the photos on their page makes me fearful that they are as much bling as function.
Old 04-13-2014, 03:41 PM   #6
ddeflyer
Nothing wrong with more variety of parts. That said though I am pretty sure I will have bought all of what I need before any plausible turn around time for a new product, so I would be unlikely to buy
Old 04-13-2014, 03:47 PM   #7
ddeflyer
Thank you, that is very useful information for if I go with them. One question though, I see that raceseng makes a point that their tow hooks click into a 90 degree position. Does the cusco one have anything like that (either through friction or a setup like the raceseng one)? I'd like to avoid marring my bumper if I could (though I don't even know if that is an actual issue).
Old 04-13-2014, 03:56 PM   #8
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Anybody know how well the car's anchor points hold up to being towed uphill onto a roll back tow truck? I've had cars where the tow hook pulls right out of the OEM anchor point, and the car has to be pushed by hand onto the tow truck bed.
dradernh is offline   Reply With Quote
Old 04-13-2014, 08:34 PM   #9
CSG David
CSG David's Avatar
You need to secure those cars better than just pulling on the OEM anchor. All four wheels or at least all four corners need to be secured to the trailer bed properly.
Old 04-13-2014, 09:15 PM   #10
akuhei
akuhei's Avatar
Drives: Raven M/T FR-S
I think they were asking if the OEM tow anchor was strong enough to handle having the car pulled up onto the trailer bed. Cant really tie the wheels down, or even the corners, while the car is on the ground.
Akuhei's Blog
"Inconceivable"
akuhei is offline   Reply With Quote
Old 04-13-2014, 11:10 PM   #11
CSG David
CSG David's Avatar
The fastener section is strong enough for that. If the material for the tow hook sucks, then the tow hook will fail.
akuhei (04-14-2014)
Old 04-13-2014, 11:29 PM   #12
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Those Godspeed hooks were $50-60 MSRP wen I checked months ago. Now they are $80... sheesh. supply and demand I guess.
Old 04-13-2014, 11:32 PM   #13
dradernh
Correct.
The tow hooks have always been fine; the cars...well, not always. I like it when the lead tow guy says "*@_&(!^ - that happens with every one of these cars!"; meanwhile, the session is blown, you're that guy, and we're about to start eating into the next session.
The Following User Says Thank You to dradernh For This Useful Post:
akuhei (04-14-2014)
Old 04-14-2014, 12:55 AM   #14
mav1178
mav1178's Avatar
Once you set up the base shaft's "anchor" point (where the outside piece threads to), to swap between the Tug View & the UPM takes me about 60 seconds.
As for the color, it's prettier when new. Once you've used it for a while, it is less pretty. But the red tow hook ring looks darker in person.
The above pictures in my review threads were all taken with an external flash, so the colors are saturated and overexposed.
-alex
ddeflyer (04-15-2014)
tow hooks ? for what-- rikdrt1 Scion FR-S / Toyota 86 GT86 General Forum 54 03-18-2015 07:06 PM
2 tow hooks please DrDuquette Want-To-Buy Requests 1 08-16-2013 08:46 AM
Tow hooks Chen Northwest 25 01-05-2013 09:40 PM
Tow hooks Minovsky Cosmetic Modification (Interior/Exterior/Lighting) 12 11-11-2012 06:22 PM
Front tow hooks for BRZ gmookher BRZ First-Gen (2012+) — General Topics 0 10-29-2012 06:26 PM
