#4257 | |
WUB WUB
Drives: 2013 Firestorm
#4258 | |
Drives: 2013 SWP BRZ
@wrxgoose - Have you reached out to Innovate at all? I think i've asked this or suggested it...could all be resolved i'm sure by sending it out to innovate and under warranty. |
#4259 |
WUB WUB
yeah, i'm going to be reaching out to them, see what they say. and see what they can do.
#4260 |
Drives: 2005 kia spectra 5, 2004ford tauras
On wrxgooses car the whole blower seems to sit nose high, which is making the pulley lean back a few degrees more than all the other pulley. This is letting the belt walk to the back of the pulley when the tensioned loosens upon hard engine decel. Say the wheels are spinning and you let off the gas and the tensioned shutters the belt will jump back on rib. We had the pulley runout checked and its perfect. I'm looking into having a pulley made with a lip to retain the belt. I don't know when sprintex made a lip less pulley to begin with. I'm also in contact with innovate/sprint ex to see in this will be warrenty.
#4261 |
I also checked the mating surfaces between the blower and the engine to see is I screwed up during the install but everything is good.
#4262 |
Drives: 2013 Black FR-S
There is an area that needed to be filed down before placing the blower manifold onto the engine. I think it is near the alternator. Maybe that is a possibility or maybe some other casting tolerance issue is not letting the blower sit true?
#4263 |
I noticed another bolt seared off...any tricks on removing? (the top broke off)
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#4264 |
WUB WUB
we did file the alternator, and there's no contact. thought of that too, but no joy.
#4265 | |
Drives: 86
I originally bought a screw extractor set, but quickly realized it wasn't needed. |
#4266 |
That Guy
Drives: 2013 asphalt FRS MT
It sounds like a mating surface was machined incorrectly. I don't see Innovate covering previous belts, but they hopefully will correct the issue. I'd be surprised if they didn't want investigage the cause as well.
#4267 |
Drives: 85 corolla gts
Good luck if you have to deal with sprintex, I have seen them not stand behind this product once already.
#4268 |
Drives: Raven FR-S
Has anyone got the 8.54 tune revision from @DeliciousTuning?
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
#4269 | |
Drives: 2020 DGM BRZ Limited
Sent from my Nexus 5 using Tapatalk |
#4270 | |
Grip>Slip
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
