| Software Tuning Discuss all software tuning topics. |
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
AFR in Closed Loop
Has anyone messed with the afr's in closed loop to increase MPG? I was reading on the mr2 forums that on closed loop they were running e85 as lean as 17 afr (on a wideband set for pump gas) to try to get some of the mpg back they lost. I don't know and think that i should run 93 pump that lean because egt would be high but i think we could run it leaner the 14.7 standard afr in closed loop fueling? Anyone try? I bet we could get close to 40 mpg?
| The Following User Says Thank You to Toyota John For This Useful Post: | gonzo (04-04-2014) |
#2 |
Drives: UK GT86
I don't think you can set the CL fueling tables to leaner than 14.7. The only way to do it would be to offset the O2 sensor scaling.
.: Stealth 86 :.
#3 |
Drives: car
For what it's worth, I did it a long time ago on a 2005 Legacy GT with an older version of Cobb Accesstuner. There were some tables labeled as closed loop target AFR on that version (this was before Bill from RomRaider joined Cobb and redid a bunch of stuff). I leaned it out enough to help gas mileage but not enough to cause misfire. I just dug up an old screenshot of a log I made.
| The Following User Says Thank You to arghx7 For This Useful Post: | Sportsguy83 (04-07-2014) |
#4 |
Drives: frs
#5 |
Calle Atun
I talked to my turner friend and he said the only way he got it to work was to turn off O2 feed back. But this wasn't on an frs. I think he said it was on an older sti. The mr2 guys that were doing it didn't have the ability to change closed loop fueling but they could turn it off and run from just the fuel table. I would like to try and see if I can change closed loop and have it make a change.
#6 | |
Drives: UK GT86
.: Stealth 86 :.
#7 |
Calle Atun
I tried to change the closed loop fueling table and nothing happened. AFR stayed at 14.7. I guess that table does nothing? The main fueling table can not be changed to anything higher then 14.7 ether. Only lower numbers are accepted.
#8 | |
Drives: UK GT86
.: Stealth 86 :.
#9 |
Drives: 85 corolla gts
You would have to completely disable the factory closed loop system to do this. It is doable, I have not done any long term testing so I can not give a good answer on reliability.
#10 |
Drives: 2JZ FRS
man thats low mpg. my average on 93 pump is 30.5. average on e78-85 is 24. i reset it once a week and calculate when i fill up so i know the gauge is somewhat accurate. my driving is about 50/50 highway/city.
#11 | |
Drives: 2013 Asphalt FR-S
you can do this using the coolant temp based target offset tables. I forget the names right now. As others have said the closed loop target afr is not what the name would indicate and you cannot set a value leaner than 14.7 without error. I saw some strange fuel trim stack-up when i messed with it and have not bothered to try again.
~Namaste~ |
#12 |
Calle Atun
The more I learn about this car the less i seem to understand.
| The Following User Says Thank You to Toyota John For This Useful Post: | Wayno (12-14-2015) |
#13 |
Drives: UK GT86
Thread revival. Thought that this is the best place for this. Having some wierd closed loop fueling issues that I've finally decided to tackle, seems like the ECU targets around 13.8 for a while before reverting to the CL fuel table target, which I have set mostly to 14.7. You can see in the graph below that the AFR tracks pretty well, but it always goes to 13.8 when changing to Fuel System Status 2.
Blue is Commanded AFR / Yellow is AFR ![]() This chart the load and RPM are not changing much, in fact the earlier part of the chart is at lower RPM and loads so should be hitting 14.7. I have tried changing the minimum open loop enrichment value and the closed loop targets are never that rich. Map is A02G I'm no running a rear O2 sensor, I wonder if that makes a difference? Ideas?
.: Stealth 86 :.
Abbey Motorsport/K47 Tuned Sprintex 210 Supercharger Kodename 47 DJ: Soundcloud / Instagram / Facebook Last edited by Kodename47; 12-14-2015 at 05:28 AM. |
#14 | |
Drives: 2014 86 GTS
Certain, my closed loop fuelling is not targetting lower than 14.7 and temp comps are all set to 0 |
| BRZedit Fuel Trims, Closed to Open loop transiton | mad_sb | Engine, Exhaust, Transmission | 32 | 08-06-2015 04:14 AM |
| Closed Project Kick Revo Lug Nuts (closed) ARP Extended Lugs | Sportsguy83 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 02-25-2014 11:46 AM |
| Screencast: closed loop boost control with RaceRom | jamesm | Software Tuning | 2 | 02-10-2014 03:23 PM |
| Screencast: experimenting with full-time closed loop fueling | jamesm | Software Tuning | 2 | 12-27-2013 11:19 AM |
| i've been out of the loop! | VenomRush | Off-Topic Lounge [WARNING: NO POLITICS] | 0 | 02-16-2013 12:25 AM |
