Old 12-17-2012, 04:18 AM   #57
sw20kosh
Drives: 2013 Black FR-S
HP is calculated from Torque and rpm.
An engine that has a high hp number will have a high redline. Why? Because torque generated at high RPM = high HP # relative to torque #.
An engine that has a high torque number relative to HP will have a low redline (like 4,000-5,000).
Study a few dyno graphs that have both torque and HP on them.
Simply saying "I want torque" means nothing. You have to specify where you want it.
On a car that revs to 7500 rpm you will generally always have a higher HP # unless you are choking the engine in the upper rpm range. Look at the s2000's engine. It has low torque, but this torque is carried out all the way to redline. This creates a huge HP number of 240HP. F1 cars rev at least twice as high and generate even more HP compared to their torque.
If what you desire is more torque in the lower rpm range, then a positive displacement supercharger is your best bet. If sized properly you wont be suffocating the engine or generating too much heat in the upper rpm range and you will have lots of torque down low.
Old 12-20-2012, 03:34 PM   #58
3MI Racing
Pro Subie Engine Nerd
3MI Racing's Avatar
Drives: empty spot for an FR-S/BRZ
Originally Posted by carbonBLUE View Post
so.... at 12.5:1 compression you would need to run 9.9, so pretty much twice the psi to make the same power BUT heres the other factor, when you lower compression you INCREASE the amount of volume you can compress in the cylinder, = more air = more fuel can be used = more power
Your math is a decent guesstimate for how it will preform, without going into effect that the lower compression ratio has on quench, volumetric efficiency, tumble and flame propagation. Even more important on the GDI, your dish in the piston plays a LARGE effect on the spray (and thus vaporization of fuel) from the DI which cools your pre-ignition in-cylinder temps.
Also, more air and more fuel (at the added few CC's) doesn't not mean more power. There is a lot more to an engine than that when you are talking volume changes that are this small. With the added volume, that can also mean more residual gas too, so you how have a lower % of your volume being fresh air and fuel.
With that being said, you also said that you would have lower temps with a lower compression ratio. With all things being equal, I would agree. However, as stated, not all things are equal. You may have a nice 'chunk' of your now being hot exhaust (residual gas).
...just telling the rest of the story
3MI Racing is offline   Reply With Quote
Old 12-20-2012, 04:03 PM   #59
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Good points
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 01-12-2013, 09:25 AM   #60
hooman
hooman's Avatar
Drives: GTS86
It's really a problem only in summer heat
hooman is offline   Reply With Quote
Old 03-12-2013, 08:06 AM   #61
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Could anyone recall maximum psi proven which could be run without detonation on 93 \ stock motor \ upgraded fuel injectors&pump ?
What's the record by now?
@Visconti , John, what's your experience?
MSTiFK8R is offline   Reply With Quote
The Following User Says Thank You to MSTiFK8R For This Useful Post:
congiiee (04-06-2014)
Old 04-06-2014, 09:47 AM   #62
congiiee
Drives: WRB Subaru BRZ
Anyone know what the max psi is on stock block? No E85
congiiee is offline   Reply With Quote
Old 04-06-2014, 09:53 AM   #63
ZionsWrath
Thanks
ZionsWrath's Avatar
Necro master
Old 04-06-2014, 09:59 AM   #64
MAPerformance
Drives: Asphalt FRS
Too many variables really, but I am running 11-12 on 93 with mine. The car seemed to like this the best with my small turbo. 15 an up, we did see two counts of knock. One below 4500rpm, and one about 6k. So we turned it back down. However, there is a member on here running 20psi on pump safely according to his tuner.
MAPerformance is offline   Reply With Quote
Old 04-06-2014, 10:48 AM   #65
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
I am running ~22psi on stock internals on 93 octane, and there is still headroom there before it was showing knock. Been running it like this for a couple months now. Before that I was running 17psi.
FWIW, I am running straight 93. Not the "This gas may contain up to 10% ethanol" crap. How much of a difference that makes -
Now, I don't know how long it would hold up in a track setting. This is why I am building the motor though - I will probably stay about the same power (maybe a bit more), just with a bigger margin for error and better durability. I have plans for getting into going to the track by fall or maybe next spring at the latest.
To be honest, my biggest concern is cooling.. the engine seems to be doing fine (for the street) at these power levels. But again, 15 seconds of running thru the gears at 22psi and I am doing like 150mph, and thru the twisty back roads it doesn't see full boost for long at all so can't exactly say what it will do in a track environment where it is at the limits for a long period of time which creates a lot of heat.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
The Following 2 Users Say Thank You to woode For This Useful Post:
congiiee (04-06-2014), onzippy (04-06-2014)
Old 04-06-2014, 08:57 PM   #66
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
www.xcceleration.com/cr-boost%20101.htm
http://www.enginelogics.com/read-a-t...ompressor-map/
Old 04-06-2014, 10:14 PM   #67
onzippy
Drives: 2014 FRS
Your numbers make me feel so much better about running 8psi on mine.
Do you have any ecutek logs from round the town stops or dyno power runs to share? Id like to compare with what I see in mine. Thanks.
onzippy is offline   Reply With Quote
Old 04-06-2014, 10:28 PM   #68
congiiee
That is insane. You have any videos? Dyno sheets?
Old 04-06-2014, 10:36 PM   #69
onzippy
Drives: 2014 FRS
http://www.ft86club.com/forums/showt...ght=woode+dyno
He also has a dyno sheet if you look for it. I want tuning logs..
The Following User Says Thank You to onzippy For This Useful Post:
Old 05-21-2014, 03:01 PM   #70
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Originally Posted by DrifterX View Post
Basically, Boost + Compression = Effective compression ratio.
So 10/14.7 = .68 *2 = 1.36 + 10.5 = 11.86. Which means you can actually boost more.
The relationship between boost and CR is multiplied, not added.
In your example, the calculation would be 1.68 X 10.5 = 17.64!
1 bar boost (approx. 14.7 psi) doubles effective CR. Obviously, if you double the density of the intake charge, you will double the effective CR.
"Effective Compression = ((Boost PSI / 14.7) + 1) * Current Static Compression Ratio"
Here is a simple calculator for determining effective CR:
http://www.gtsparkplugs.com/Effectiv...ssionCalc.html
billwot is offline   Reply With Quote
Using Subarus other turbo Boxers as an idea, how much HP could a turbo BRZ/FR-S have? HitTheGas BRZ First-Gen (2012+) — General Topics 12 02-21-2012 01:24 PM
Turbo FR-S Mino Engine, Exhaust, Transmission 24 12-16-2011 08:42 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
turbo yes BMWDAD BRZ First-Gen (2012+) — General Topics 79 12-06-2011 12:58 AM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 06:20 PM
