#29 | |
Fanboy
Drives: 2013 ultramarine frs
I'm done helping those who won't help themselves.
TL;DR: ![]() -Duke |
#30 |
Drives: GT86
Perrin intake pipe and cold intake kit with the BPB could have good results
#31 |
Supra Senior Member
Drives: AE86 & BRZ
Another off topic, but I called up Crawford Performance and spoke with "Kelson" for additional information. He said pretty all of the above. Furthermore, there is a group buy going for the first 80-100 people (if the tier gets there) 20% off. Needless to say, this review really influenced me to make the purchase. Thank you.
#32 |
That guy
Drives: Ultramarine mt FR-S
It could, but you will never know until the combination is installed, and tuned. We are hitting that stage of modding where a new part will come out that changes a lot of things. The stock airbox is designed for the stock air intake and manifold. Once you modify the parts behind it, the effect of the intake changes as well. Who's to say a different intake won't yield more power than just a drop in after the intake runners.
Ultramarine mt FR-S
P&L stage 1 turbo Prime Motoring Flex fuel Jr Tuned 506whp @17psi (e73) |
#33 | |
Drives: GT86
#34 |
Drives: Asphalt FRS
This may be a ridiculous question, but (assuming grimmspeed produces an intake that makes power) would the gains seen here negate the grimmspeed intake, or would they add together? I realize that if I add 2 parts worth 20hp each I won't net 40hp, but are the spacers optimized for the stock intake, or is the intake a completely separate system.
Sorry if this was worded halfassed, I'm a bit hungover.
Current: Nameless Headerback- Crawford BPB - Zeta Intake Duct - Mishimoto Intake |
#35 | |
Drives: Moped
The key that has already been mentioned is to look at a change in results for the same car, on the same dyno, and in roughly the same conditions over several dyno runs. |
#36 |
Resident Gear Head
great write up I am going to pick one of these up. Found this buy that ends friday!
https://www.facebook.com/events/277229732435324/
Subaru BRZ/FRS Facebook News and Tech Page
My FB Build page CLICK AND LIKE! Twitter and Instagram @misairubrz |
#37 | |
Troll Hunter
Drives: fr-s, tundra
#38 | |
That guy
Numbers can also be fudged from Dyno pull to Dyno pull. Third party numbers are always better than manufacturers.
Ultramarine mt FR-S
| The Following User Says Thank You to Hawaiian For This Useful Post: | 86-tundra (03-30-2014) |
#40 |
Drives: Pavement MT GR86
On a dyno that reads our cars around 175...assuming we actually have 200 at the crank and average losses. That is where breaking 200whp comes from but like Hawaiian mentioned every dyno is different and some cars are a little different.
GR86 MT premium
#41 |
Cones are bad
Drives: 2013 BRZ Premium
Awesome. I was waiting to see what the dyno would look like with a tune and the BPB's. I can't wait to get mine. Thank you for taking the time to put in all of the work
#42 |
Cones are bad
Did you actually think about that. Plastic vs Billet. Crawford made a very high quality choice. The engine is made out of metal and the intake manifold originally lines up with that, so there is no change in the set-up or need for insulated materials. There will not be enough heat or time spent in there to have any gains or losses from using a cheaper material
![]() Last edited by RazBRZ; 03-30-2014 at 02:03 PM. |
| The Following User Says Thank You to RazBRZ For This Useful Post: | acro (03-30-2014) |
| Crawford Billet Power Blocks | smbstyle | Engine, Exhaust, Transmission | 799 | 01-18-2016 06:01 PM |
| Crawford Performance Turbo BRZ! Balance Meets Power - Ignition Episode 71 | ZetaVI | BRZ Photos, Videos, Wallpapers, Gallery Forum | 22 | 04-01-2014 06:19 PM |
| Squidbelly wants to know the best way to gut a manifold cat | regal | Engine, Exhaust, Transmission | 14 | 03-07-2014 11:31 AM |
| short blocks? | 350matt | Engine, Exhaust, Transmission | 4 | 11-04-2013 09:37 PM |
| Billet Oil Catch Can #BC-175 by Billet Custom | Tim_Asphalt_FRS | Engine, Exhaust, Transmission | 48 | 10-27-2013 03:29 PM |
