Old 03-30-2014, 11:09 AM   #29
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Originally Posted by StormTrooper View Post
@nelsmar I'd quote the issues I'm having reading your post but I'm on my phone and don't want to quote all of it or mess around.
Where is the 116 and 119whp coming from if stock is 130whp?
Some of your numbers don't make sense.
At redline
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 03-30-2014, 11:52 AM   #30
Pixie_Niner
Drives: GT86
Perrin intake pipe and cold intake kit with the BPB could have good results
Pixie_Niner is offline   Reply With Quote
Old 03-30-2014, 12:03 PM   #31
Mr.
Supra Senior Member
Mr.'s Avatar
Drives: AE86 & BRZ
Another off topic, but I called up Crawford Performance and spoke with "Kelson" for additional information. He said pretty all of the above. Furthermore, there is a group buy going for the first 80-100 people (if the tier gets there) 20% off. Needless to say, this review really influenced me to make the purchase. Thank you.
Build Thread
YouTube Channel
IG - Fwankyhong
Subscribe
Mr. is offline   Reply With Quote
The Following 2 Users Say Thank You to Mr. For This Useful Post:
Boxer-86 (03-30-2014), RazBRZ (03-30-2014)
Old 03-30-2014, 12:04 PM   #32
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
It could, but you will never know until the combination is installed, and tuned. We are hitting that stage of modding where a new part will come out that changes a lot of things. The stock airbox is designed for the stock air intake and manifold. Once you modify the parts behind it, the effect of the intake changes as well. Who's to say a different intake won't yield more power than just a drop in after the intake runners.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 03-30-2014, 12:06 PM   #33
Pixie_Niner
Drives: GT86
Good thing I have the BPBs. On order then. Ecutek mapping will be added after
Old 03-30-2014, 12:40 PM   #34
Craig
Craig's Avatar
Drives: Asphalt FRS
This may be a ridiculous question, but (assuming grimmspeed produces an intake that makes power) would the gains seen here negate the grimmspeed intake, or would they add together? I realize that if I add 2 parts worth 20hp each I won't net 40hp, but are the spacers optimized for the stock intake, or is the intake a completely separate system.
Sorry if this was worded halfassed, I'm a bit hungover.
Current: Nameless Headerback- Crawford BPB - Zeta Intake Duct - Mishimoto Intake
Craig is offline   Reply With Quote
Old 03-30-2014, 12:44 PM   #35
Lonewolf
Lonewolf's Avatar
Drives: Moped
Originally Posted by trevorovert View Post
this may be incredibly off topic, by why do some dynos such as this one read so low (130whp) while others read real high (180whp)? Nelsmar is right in saying we should be looking at percentages, but what is right here? does the car have 140whp or 180whp? Why would we believe one or the other? why isn't this a standard calculation?
Different dyno types (Mustang vs. Dynojet, etc., testing conditions (high temperature, humidity, heat, altitude), and the specific cars tested (automatic vs. manual - power/drivetrain losses) all have a profound effect on dyno results.
The key that has already been mentioned is to look at a change in results for the same car, on the same dyno, and in roughly the same conditions over several dyno runs.
Old 03-30-2014, 12:48 PM   #36
celek
Resident Gear Head
celek's Avatar
great write up I am going to pick one of these up. Found this buy that ends friday!
https://www.facebook.com/events/277229732435324/
celek is offline   Reply With Quote
The Following 2 Users Say Thank You to celek For This Useful Post:
Gilwith1l (03-30-2014), RazBRZ (03-30-2014)
Old 03-30-2014, 12:49 PM   #37
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
right and I understand all of that. but when someone says "break 200whp mark NA" ... well what does that really mean?
86-tundra is offline   Reply With Quote
Old 03-30-2014, 12:58 PM   #38
Hawaiian
That guy
Hawaiian's Avatar
Not much. That dyno might read exceptionaly high. I pointed that out in one of those threads and the tuner got pretty but hurt at me for it, so I stopped. The real # is % gains over baseline. That's why lots of us want to see the baseline as a point of comparison.
Numbers can also be fudged from Dyno pull to Dyno pull. Third party numbers are always better than manufacturers.
Ultramarine mt FR-S
P&L stage 1 turbo
The Following User Says Thank You to Hawaiian For This Useful Post:
86-tundra (03-30-2014)
Old 03-30-2014, 01:04 PM   #39
s0sl0w
Proud of Boxer
Originally Posted by Turdinator View Post
What is with this forum and people asking for cheap knock offs? It's like you want Tony from FA20club back.
I'd rather have them made from a lighter, heat insulating material. Not my fault Crawford chose poorly for their spacer material.
s0sl0w is offline   Reply With Quote
The Following User Says Thank You to s0sl0w For This Useful Post:
GT86meMR2 (03-30-2014)
Old 03-30-2014, 01:07 PM   #40
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
On a dyno that reads our cars around 175...assuming we actually have 200 at the crank and average losses. That is where breaking 200whp comes from but like Hawaiian mentioned every dyno is different and some cars are a little different.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 03-30-2014, 01:08 PM   #41
RazBRZ
Cones are bad
RazBRZ's Avatar
Drives: 2013 BRZ Premium
Awesome. I was waiting to see what the dyno would look like with a tune and the BPB's. I can't wait to get mine. Thank you for taking the time to put in all of the work
RazBRZ is offline   Reply With Quote
Old 03-30-2014, 01:14 PM   #42
RazBRZ
Cones are bad
RazBRZ's Avatar
Did you actually think about that. Plastic vs Billet. Crawford made a very high quality choice. The engine is made out of metal and the intake manifold originally lines up with that, so there is no change in the set-up or need for insulated materials. There will not be enough heat or time spent in there to have any gains or losses from using a cheaper material
The Following User Says Thank You to RazBRZ For This Useful Post:
acro (03-30-2014)
Crawford Billet Power Blocks smbstyle Engine, Exhaust, Transmission 799 01-18-2016 06:01 PM
Crawford Performance Turbo BRZ! Balance Meets Power - Ignition Episode 71 ZetaVI BRZ Photos, Videos, Wallpapers, Gallery Forum 22 04-01-2014 06:19 PM
Squidbelly wants to know the best way to gut a manifold cat regal Engine, Exhaust, Transmission 14 03-07-2014 11:31 AM
short blocks? 350matt Engine, Exhaust, Transmission 4 11-04-2013 09:37 PM
Billet Oil Catch Can #BC-175 by Billet Custom Tim_Asphalt_FRS Engine, Exhaust, Transmission 48 10-27-2013 03:29 PM
