Old 03-26-2014, 10:57 PM   #1
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Is understeer harder to regain control with wider tires?
Is this true? Say you run a 215 to a 245, if you happened across understeer, would the 215 be easier to gain back control of the car?
Old 03-27-2014, 12:13 AM   #2
Turdinator
Señor Member
Turdinator's Avatar
This is not something I have personal experience with but I would have thought the break away and then gripping again characteristics would be more to do with the tyre compound than the width.
1974 TA22 Celica
2013 86 GT
Old 03-27-2014, 12:23 AM   #3
mrk1
Drives: Sterling BRZ Ltd
what kind of understeer are we talking, little scrub or full on audi plowing.
I don't think width really makes a difference but more so the tire compound and also how communicative is that tire. I ran NT05's on my M3 and found them to a fast tire but not the greatest in terms of feed back. Now that car is on michelin super sports, maybe not as much overall grip but the better feedback really helped me know what was going on.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following 3 Users Say Thank You to mrk1 For This Useful Post:
Calum (03-27-2014), FR-Slide (03-27-2014), Kido1986 (03-27-2014)
Old 03-27-2014, 12:36 AM   #4
CSG Mike
CSG Mike's Avatar
Wider tires will exaggerate the understeer, yes.
dem00n (03-27-2014), ftc~brz (03-27-2014)
Old 03-27-2014, 01:25 PM   #5
FR-Slide
Drives: 13 Whiteout 6MT
+1 for Audi-plowing. I miss the torque of my B6 S4 with it's v8 hung out past the headlights, but man, the steering wheel was really more of a "suggestion device".
FR-Slide is offline   Reply With Quote
The Following 3 Users Say Thank You to FR-Slide For This Useful Post:
Calum (03-27-2014), Kido1986 (03-27-2014), wheelhaus (03-27-2014)
Old 03-27-2014, 05:59 PM   #6
cactus
cactus's Avatar
Drives: 13 SWP BRZ
I got a laugh out of audi plowing. My B5 feels like a boat when I go back and drive it.
cactus is offline   Reply With Quote
Old 03-27-2014, 06:14 PM   #7
wheelhaus
wheelhaus's Avatar
I imagine the reasons are two fold: (if this is incorrect, I apologize).
The more available grip you have means you would be at a higher limit when the audi plow begins. So I imaging it could be more difficult to regain all that lost grip since the forces causing it are likely higher, even more so as the tire overheats from scrubbing.
Also, a narrow tire can respond a bit more quickly, making it easier to detect and correct understeer.
Old 03-27-2014, 06:34 PM   #8
Calum
That Guy
Drives: 2013 asphalt FRS MT
I always thought wider tires just allowed a tire to wear slower. @CSG Mike?
Old 03-27-2014, 06:43 PM   #9
CSG Mike
CSG Mike's Avatar
THey allow a tire to heat up slower from the increased mass, but it can add grip too if the contact patch is increased.
Old 03-27-2014, 06:56 PM   #10
Calum
That Guy
As the surface area increases (assuming weight doesn't change and while a larger tire will weight more the difference to the totally weight per corner is negligible) the pressure decreases, meaning there is less force on each unit of the contact patch. There are more units of surface area with a larger contact patch though, so the reduced force is canceled out by the increased contact patch. Thus leaving the force due to friction as simply the product of the coefficient of friction and the normal force.
Am I going wrong somewhere?
Old 03-27-2014, 09:00 PM   #11
CSG Mike
CSG Mike's Avatar
The pressure decreases, but the total force necessary to break traction increases, so you can still corner harder. Harder cornering increases the pressure on that corner....
Wider tires on stock wheels buzznasa Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 01-21-2019 02:55 PM
SpectreRT's DMG BRZ Build Thread - Stock Harder SpectreRT Member's Car Journals 16 07-31-2014 05:35 PM
Steering feel with wider tires? TSY Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 07-26-2013 11:32 AM
What would make the rear tires look wider?? Razor Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 02-19-2013 12:16 AM
03/23 Reviews --> No understeer complaints... bloomy116 BRZ First-Gen (2012+) — General Topics 19 03-26-2012 12:06 PM
