kidgogeta
Old 03-27-2014, 11:30 AM   #1709
FR-S89
Originally Posted by BlueDubbinTDI View Post
That will poke ever so slightly in the front. Rear will be tucked just fine
What would you suggest to get a slight tuck all around
FR-S89 is offline   Reply With Quote
Old 03-27-2014, 11:31 AM   #1710
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
I think they have a 18x7.5 et38 out there. Not sure if its the 527 though.
Old 03-27-2014, 11:36 AM   #1711
FR-S89
I basically want to achieve this fitment: Not sure what this guy's wheel specs are though
Old 03-27-2014, 11:44 AM   #1712
BlueDubbinTDI
Probably the 8.75 +35 with a spacer in the rear
Old 03-27-2014, 11:45 AM   #1713
FRSTRM
Baby LFA
FRSTRM's Avatar
Drives: Baby LFA
Flat Black XXR 527 18x8.75 +35 - wrapped in Dunlop Direzza DZ101 225/40R18
FRSTRM is offline   Reply With Quote
Old 03-27-2014, 11:45 AM   #1714
FR-S89
That's what i was thinking too. You think i'll need LCAs?
Old 03-27-2014, 11:48 AM   #1715
BlueDubbinTDI
Do you mind camber? They're expensive but if you have the money I would. Needed? No.
Old 03-27-2014, 02:19 PM   #1716
FR-S89
Well isn't camber required to get that fitment in the pic? It looks like both the back and front are tucked
Old 03-27-2014, 02:31 PM   #1717
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
Here is mine on BC extremes.... 18x8.75 35mm offset. Front can tuck very easily.... It will poke when ran stock but add about 1.5° of camber in the front and you'll be good. Fronts are 225/40 also with no fender mods (no rub) and only running about 1.5-2° of camber in the fronts with stock lcas in the rear
Sent from my HTC One
SMOKETREES is offline   Reply With Quote
The Following User Says Thank You to SMOKETREES For This Useful Post:
FR-S89 (03-27-2014)
Old 03-27-2014, 02:34 PM   #1718
SMOKETREES
Lowered Lifestyle
SMOKETREES's Avatar
Drives: Scion Fr-S
Also I believe he is running a 9.25 in the rear (possibly fronts also) with the concave it appears to be.... Very diff than most 8.75 I've seen
Old 03-27-2014, 02:35 PM   #1719
FR-S89
Thanks for that post, your drop is very nice too. It's my first time getting coilovers on a car so I don't know how to adjust fitment. In fact i don't even trust myself installing them so I'm hoping I can tell my shop to drop it X amount and give X amount of camber and hope to god it turns out like yours.
The Following User Says Thank You to FR-S89 For This Useful Post:
SMOKETREES (03-27-2014)
Old 03-27-2014, 02:37 PM   #1720
dirtymax
Gold Member
dirtymax's Avatar
Drives: 14' SWP BRZ MT limited
I was able to get -1.5* of camber on a 1" drop with just camber bolts, rear ended up at -2* with the drop. Seems nice and tucked to me
dirtymax is offline   Reply With Quote
Old 03-27-2014, 02:38 PM   #1721
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
So, I've almost made up my mind on the 530. If you ask anyone from off-topic I have been debating wheels for a long time, and I think they're just about done with me changing my mind. The only problem is, even if I get these, I don't know what size to get. But, it's really down to a choice between 17x7 and 17x8.25.
Now I searched the whole thread, and maybe I skimmed too much, but I couldn't find anyone running exactly what I would, and whether or not it pokes. Also, no immediate plans to lower the car. So here's my thought process.
17x7 +35 = 215/45/17 tires - Pros: Cheaper (slightly) initial wheel price, cheaper, easy to find tires. Slightly lighter. Cons: Less grip! Stock size = pointless upgrade.
17x8.25 +35 = 235/40/17 tires - Pros: Wider tire, more grip, better looking, justifies the expense of wheels and tires. Cons: Potential poke, wheel/tire costs more, rare tire size limits tire choice, heavier combo.
Basically 17x7 is cheap and simple. 17x8.25 is an actual upgrade, but more expensive. (Though still much cheaper than any combination I've come up with to date.)
Nevermore is offline   Reply With Quote
Old 03-27-2014, 02:53 PM   #1722
BlueDubbinTDI
You can go 225/45/17 on an 8.25" wheel. And no it won't poke. That's an assuredly common tire size
17 wheels
Wheel Directory: ProDrive GC-012L 18x8.5 +48 MarkMash Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 05-12-2013 04:55 PM
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 01:24 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 01:28 PM
