#239 |
Yes, you can then analyse it and "confirm" if you have a problem rather than forever stating everyone else's problem is yours let alone if it's even a problem in the first place.
#240 | |
Drives: Scion FR-S/Toyota Yaris
Exactly if this is chewing uo camshafts and bending valves we can pretty much forget GT-86 NA tuning scene. I guess the next step is to find someone NA with an aggressive VVT who is installing the aftermarket turbo cams for a turbo install. Mic those used NA cams and we should have our answer, When I hear it is sounded like a slight manifold leak or exhaust air related which is usually benign unless the manifold cat is breaking down and the egr nature of the exhaust timing is the culprit. I would expect that more on a stock car than a a catless headered tuned car. Maybe we need to really understand this egr like function and how to avoid it.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#241 |
Drives: UK GT86
The car doesn't have an EGT sensor. It's a calculated value
.: Stealth 86 :.
#242 |
How useful is a calculated EGT? I seriously have no ide, seems like there would be too many variables (E5,E10,Head temp which we know is inaccurate.) add FI to the mix and I just don't know? This could be on or off topic I think more investigation is needed.
#243 |
Drives: UK GT86
It's likely it is used by the ECU for cat and O2 warm up and control and is just output on a standard PID.
.: Stealth 86 :.
#244 |
Drives: car
Even for engines where it's not used for actual engine controls, you need at least a basic EGT model for the cold start strategy diagnostic monitor in California.
#245 | |
Drives: subaru
VVT Noise Catastrophic Engine Failuer Urgent
Please email me on wot you think. |
#246 |
Most important guage to have is an oil pressure gauge, yet so few on this forum have one because the car doesn't come with a sender just a switch. I personally can't imagine forced induction without an oil pressure gauge.
| The Following User Says Thank You to regal For This Useful Post: | wparsons (04-01-2014) |
#247 | |
Grip>Slip
| The Following 4 Users Say Thank You to xjohnx For This Useful Post: |
#248 |
Drives: 2013 FRS Asphalt
I was doing some testing last night and flashed a stock rom. It really does sound more refined that's for sure. I also felt the loss of power
2013 Scion FR-S AT Picked up 5/30/2012
#249 |
#250 |
Addicted
Drives: 2013 Asphalt FR-S 6MT
Installed my OFT today with STG 1 91octane. Injen+Catback and I heard the sound and thought my car was blowing up. Then I ran into this thread.. I agree that it is more pronounced in 3rd gear going up a hill at WOT as that is when I noticed it.
Here is the log for that pull if anyone cares. http://datazap.me/u/l0aded/run2?log=0&data=1-2-5-6-9 Honestly a little sad to hear it as I really enjoy the extra kick but the sound is pretty annoying.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
#251 |
Drives: Scion FR-S
Anyone on here have a delicious stage 1 or 2 na tune? Wondering if these have the quick change in cam phasing as some of these other tunes. I previously had another tune that created this noise that the stock tune did not. Not trying to buy another tune that creates the same potential problem.
Sent from my Nexus 7 using Tapatalk |
#252 |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
This thread needs an update. It is scaring people to think that the noise from the cam phasing is going to cause damage or is bad for the car when it really isn't an issue unless there is a different issue (and it still hasn't proven to cause an issue other the fuel pressure pulsing as far as I know).
| Variable Valve "Butterfly" Exhaust | dlux | Southern California | 19 | 02-22-2016 06:21 PM |
| First tank OFT E85 tuning. Noise? | Tromatic | Software Tuning | 2 | 02-20-2014 05:43 PM |
| Exhaust Cut Off Valve | beagoodruslan | Engine, Exhaust, Transmission | 2 | 01-01-2014 01:47 AM |
| Exhaust Noise that goes away after warmed up | FastLane1000 | Engine, Exhaust, Transmission | 10 | 08-15-2013 10:06 PM |
| Knock/valve slap/crick noise under accel | yomny | Issues | Warranty | Recalls / TSB | 47 | 01-07-2013 08:53 PM |
